0000324 | QElectroTech | Diagram Editor | public | 2025-05-27 15:27 | 2025-06-22 13:06 |
Reporter | Leonardo da Silva | Assigned To | |||
Priority | high | Severity | major | Reproducibility | always |
OS | winnt - x86_64 | OS Version | Windows 11 | ||
Summary | 0000324: Crash on "Add text" | ||||
Description | When copying a label with Ctrl + C, then editing its text properties, and after that trying to create a new label in the selection properties, QElectroTech crashes immediately. | ||||
Steps To Reproduce | Select an existing label on the diagram. Press Ctrl + C to copy the text of label. Open the label's properties and click inside the text field to edit the text. While the text field is still focused, click on "Add Text" inside the selection properties. The program crashes without any error message. | ||||
Attached Files | |||||
Crashes with segmentation fault when text of element is selected. Does not crash, when only element is selected. |
I think I have found the location in the source code that leads to the crash when adding new text-item. If you can compile QET yourself: Available as binaries since 30.05.2025 in version 0.100-dev. |
2025-05-27 15:27 | Leonardo da Silva | New Issue | |
2025-05-27 15:27 | Leonardo da Silva | File Added: another bug.mp4 | |
2025-05-30 08:28 | plc-user | Note Added: 0000800 | |
2025-05-30 09:49 | plc-user | Note Added: 0000802 | |
2025-06-22 13:06 | plc-user | Note Edited: 0000802 |
