| 0000323 | QElectroTech | Diagram Editor | public | 2025-05-27 13:53 | 2026-08-10 21:53 |
| Reporter | Leonardo da Silva | Assigned To | plc-user | ||
| Priority | high | Severity | major | Reproducibility | always |
| OS | winnt - x86_64 | OS Version | Windows 11 | ||
| Summary | 0000323: Crash on change label color | ||||
| Description | After saving a project, if I edit the color of a label (text element) and confirm the change by pressing Enter, QElectroTech crashes immediately. This does not happen if I confirm the change by clicking "OK" with the mouse. | ||||
| Steps To Reproduce | Open any project in QElectroTech. Make a change and save the project. Select a label (text element) and open the color settings (font or background). Change the color and confirm the dialog by pressing Enter. The program closes instantly without any error message. | ||||
| Additional Information | Reproducibility: Always, after saving Severity: High (risk of data loss if not saved before the crash) | ||||
| Attached Files | |||||
Including video showing the full screen |
I can reproduce the error with latest QET 0.100-dev on Debian GNU/Linux When starting from commandline, I see this message on screen, when crashing: Warning: QObject::installEventFilter(): Cannot filter events for objects in a different thread. (:0, )followed by "segfault" The message can also be found in log-file. Menu --> Help --> About QElectroTech --> TAB "log" --> scroll back to time of crash |
I can't reproduce the bug on my debian (gnome). plc-user what is it your desktop environment ? |
In May I could reproduce the crash with Debian stable/Bookworm (LXQt) and Debian unstable/Trixie (xfce4). Now on Debian stable/Trixie (LXQt) and unstable/Forky (xfce4) QET does not crash anymore, when changing colour of Textfields as described above. |
In my local copy of sources, I noted this in line 1912 of sources/ui/dynamicelementtextmodel.cpp
but could not figure out, which event(s) are responsible |
Bug is fixed in Source-Code for 0.100.1-dev by ispyisail Thanks for that! |
fixed! |
| 2025-05-27 13:53 | Leonardo da Silva | New Issue | |
| 2025-05-27 13:53 | Leonardo da Silva | File Added: Bug on change color.mp4 | |
| 2025-05-27 14:32 | Leonardo da Silva | Note Added: 0000798 | |
| 2025-05-27 14:32 | Leonardo da Silva | File Added: Bug on change color-2.mp4 | |
| 2025-05-30 08:06 | plc-user | Note Added: 0000799 | |
| 2025-05-30 08:10 | plc-user | Note Edited: 0000799 | |
| 2025-10-20 23:39 | black_sun | Note Added: 0000824 | |
| 2025-10-22 21:03 | plc-user | Note Added: 0000825 | |
| 2025-10-22 23:24 | plc-user | Note Added: 0000826 | |
| 2026-08-10 21:52 | plc-user | Note Added: 0000847 | |
| 2026-08-10 21:53 | plc-user | Assigned To | => plc-user |
| 2026-08-10 21:53 | plc-user | Status | new => closed |
| 2026-08-10 21:53 | plc-user | Resolution | open => fixed |
| 2026-08-10 21:53 | plc-user | Note Added: 0000848 |
