| 0000313 | QElectroTech | Libraries of elements | public | 2024-08-23 14:02 | 2024-09-01 09:12 |
| Reporter | Marcel73 | Assigned To | |||
| Summary | 0000313: The part: Electric/All-pole/Connections/Jump is not exported proberly as PDF | ||||
| Description | There is a part of wire missing in the PDF Export of the part: Jump | ||||
| Steps To Reproduce | See the attached Picture. There is a part of the wire missing in the pdf version. In the opened project it is not seen. | ||||
| Tags | wires | ||||
| Attached Files | |||||
|  | Thanks to report it, now fixed https://github.com/qelectrotech/qelectrotech-elements/commit/72ac3aa57c9cd260455470704e44a47b245a3ad7 Btw, when you export to PDF on dialog check option print terminal was enabled. ps: I just edited the element and added 2 lines above the terminals, it was admittedly badly drawn. |
| 2024-08-23 14:02 | Marcel73 | New Issue | |
| 2024-08-23 14:02 | Marcel73 | Tag Attached: wires | |
| 2024-08-23 14:02 | Marcel73 | File Added: Jump.png | |
| 2024-08-24 11:04 | scorpio810_mantis | Note Added: 0000745 | |
| 2024-08-24 11:06 | scorpio810_mantis | Note Edited: 0000745 | |
| 2024-09-01 09:12 | scorpio810_mantis | Status | new => resolved |
| 2024-09-01 09:12 | scorpio810_mantis | Resolution | open => fixed |
