| 0000311 | QElectroTech | Diagram Editor | public | 2024-07-23 21:09 | 2026-08-30 09:54 |
| Reporter | intcircuit | Assigned To | |||
| Priority | normal | Severity | tweak | Reproducibility | always |
| Platform | Linux x64/Flatpak | OS | Debian Bookworm / Fedora | OS Version | 12.5 / 41 |
| Summary | 0000311: options contexts are not glued to top of window when opening "file", "edition" menus | ||||
| Description | When using latest V0.100 Qelectrotech version, I get this visual bug (see attached file) The menus are getting a space every time they are highlighted. | ||||
| Steps To Reproduce | 1) Launch QET 2) Highlight first menu which renders correctly 3) All menus are after that displaying like attached file | ||||
| Additional Information | Qelectrotech V0.100 dev flatpak Wayland session | ||||
| Tags | menu, wayland | ||||
| Attached Files | |||||
https://qelectrotech.org/bugtracker/view.php?id=305 |
After modifying the .desktop file, I still get this. |
Using Flatseal, you're able to add environment variables. https://github.com/flathub/org.kde.ktouch/issues/27#issuecomment-1561415140 |
I did it like it was showed in the link and now the app doesnt even launch. |
Cosmetic bug still appears in Qet master version. Using the Flatseal setup makes the app crash and without it menus and windows do not appear correctly |
A bit more info, it happens on my primary screen which has scaling and the flicker goes away after clicking the tobbar of the window |
Thanks for pointing out. |
Fixed with last 0.200.1 Qer version with Qt 6.11 |
| 2024-07-23 21:09 | intcircuit | New Issue | |
| 2024-07-23 21:09 | intcircuit | Tag Attached: menu | |
| 2024-07-23 21:09 | intcircuit | Tag Attached: wayland | |
| 2024-07-23 21:09 | intcircuit | File Added: 348541899-1c248689-cf28-495d-8af4-474131bccbe6.png | |
| 2024-07-26 11:26 | scorpio810_mantis | Note Added: 0000735 | |
| 2024-07-26 18:42 | intcircuit | Note Added: 0000736 | |
| 2024-07-27 12:20 | scorpio810_mantis | Note Added: 0000737 | |
| 2024-07-27 12:23 | scorpio810_mantis | Note Edited: 0000737 | |
| 2024-07-27 20:53 | intcircuit | Note Added: 0000738 | |
| 2024-07-27 20:53 | intcircuit | File Added: Capture d’écran du 2024-07-27 20-51-51.png | |
| 2025-02-23 17:54 | intcircuit | Note Added: 0000781 | |
| 2025-02-23 17:54 | intcircuit | File Added: Capture vidéo du 2025-02-23 17-47-22.webm | |
| 2025-02-23 17:54 | intcircuit | File Added: Capture vidéo du 2025-02-23 17-51-26.webm | |
| 2025-02-23 17:56 | intcircuit | OS | Debian Bookworm => Debian Bookworm / Fedora |
| 2025-02-23 17:56 | intcircuit | OS Version | 12.5 => 12.5 / 41 |
| 2025-02-23 17:56 | intcircuit | Platform | Linux x64 => Linux x64/Flatpak |
| 2025-02-25 19:33 | intcircuit | Note Added: 0000783 | |
| 2025-02-28 15:15 | scorpio810_mantis | Note Added: 0000784 | |
| 2026-08-30 09:53 | scorpio810_mantis | Note Added: 0000861 | |
| 2026-08-30 09:54 | scorpio810_mantis | Status | new => resolved |
| 2026-08-30 09:54 | scorpio810_mantis | Resolution | open => fixed |
