| 0000308 | QElectroTech | other | public | 2024-06-21 08:14 | 2026-09-24 10:28 |
| Reporter | Bisku | Assigned To | |||
| Platform | HP Firefly 14 Gen 11 | OS | Windows 11 Pro (64-bit) | ||
| Summary | 0000308: Preset for date is not saved | ||||
| Description | I open the pre-settings for a new project and active the option for the actual date as a new preset. However, that option will not be saved. Every new project will be created without a date information on each folie. | ||||
I can't reproduce the bug, the change was in the config menu -> configure QET -> new project? |
Thanks for clarification. I didn't know that a restart is necessary to make new settings works. Works as intended after a restart. |
That is very strange, here on my Debian or In Windows 11 on my laptop (Win/Kubuntu boot) no need to restart program, same thing with readyToUse version. |
For me, this setting is only saved if the folio tab is active when clicking OK. If any other tab is active while saving the settings, the Date setting falls back to "No date". The same is true for this setting when saving Project properties. Only in Project properties, I cannot change directly between "Current date" and "Fixed date". The change is ignored. If I save the Project properties first with "No date" I can change it to one of the other settings. |
Fixed by GitHub #696, merged on 2026-08-08: https://github.com/qelectrotech/qelectrotech-source-mirror/pull/696 The fix will be in the next release. If you still see the problem in a build that includes it, add a note here and we will reopen this. |
| 2024-06-21 08:14 | Bisku | New Issue | |
| 2024-07-03 12:21 | scorpio810_mantis | Note Added: 0000728 | |
| 2024-07-03 12:26 | scorpio810_mantis | Note Edited: 0000728 | |
| 2024-07-07 09:53 | Bisku | Note Added: 0000729 | |
| 2024-07-07 10:32 | scorpio810_mantis | Note Added: 0000730 | |
| 2024-12-04 18:19 | mjulius | Note Added: 0000760 | |
| 2026-09-24 10:28 | ispyisail | Note Added: 0000867 | |
| 2026-09-24 10:28 | ispyisail | Status | new => resolved |
| 2026-09-24 10:28 | ispyisail | Resolution | open => fixed |
