| 0000302 | QElectroTech | other | public | 2024-05-02 01:45 | 2024-05-09 17:52 |
| Reporter | eplanerFX | Assigned To | |||
| Priority | none | Severity | minor | Reproducibility | N/A |
| Platform | AMD Ryzen 2700X/32GB/1TB-SSD | OS | Windows 10 | OS Version | 0.9 |
| Summary | 0000302: No values are transferred when copying | ||||
| Description | If I copy and paste a component, it loses all values such as the equipment labelling or formula. This makes a lot of work if you have identical components where only the BMK changes. It would be cool if one of you could adapt this. | ||||
please try Uncheck "do not store the label of items in the copy paste" in settings -> configure QElectroTech -> tab project sttings. https://download.qelectrotech.org/qet/manual_0.7/build/preferences/settings_general_project.html |
Thanks for the info, I also realised later that there is an option to enable/disable this in the settings. Unfortunately I did not find the function to delete this post on the bugtracker. |
| 2024-05-02 01:45 | eplanerFX | New Issue | |
| 2024-05-02 21:28 | eplanerFX | Reproducibility | always => N/A |
| 2024-05-02 21:28 | eplanerFX | Priority | normal => none |
| 2024-05-04 10:16 | scorpio810_mantis | Note Added: 0000701 | |
| 2024-05-04 10:19 | scorpio810_mantis | Note Edited: 0000701 | |
| 2024-05-04 10:21 | scorpio810_mantis | Note Edited: 0000701 | |
| 2024-05-09 17:21 | eplanerFX | Note Added: 0000713 | |
| 2024-05-09 17:52 | scorpio810_mantis | Status | new => resolved |
| 2024-05-09 17:52 | scorpio810_mantis | Resolution | open => fixed |
