0000302QElectroTechotherpublic2024-05-09 17:52
ReportereplanerFX Assigned To
PrioritynoneSeverityminorReproducibilityN/A
PlatformAMD Ryzen 2700X/32GB/1TB-SSDOSWindows 10OS Version0.9
Summary0000302: No values are transferred when copying
DescriptionIf I copy and paste a component, it loses all values such as the equipment labelling or formula.
This makes a lot of work if you have identical components where only the BMK changes. It would be cool if one of you could adapt this.
TagsNo tags attached.
Activities
scorpio810
2024-05-04 10:16
administrator   ~0000701
please try Uncheck "do not store the label of items in the copy paste" in settings -> configure QElectroTech -> tab project sttings.
https://download.qelectrotech.org/qet/manual_0.7/build/preferences/settings_general_project.html
eplanerFX
2024-05-09 17:21
reporter   ~0000713
Thanks for the info, I also realised later that there is an option to enable/disable this in the settings.
Unfortunately I did not find the function to delete this post on the bugtracker.
Issue History
2024-05-02 01:45 eplanerFX New Issue
2024-05-02 21:28 eplanerFX Reproducibility always => N/A
2024-05-02 21:28 eplanerFX Priority normal => none
2024-05-04 10:16 scorpio810 Note Added: 0000701
2024-05-04 10:19 scorpio810 Note Edited: 0000701
2024-05-04 10:21 scorpio810 Note Edited: 0000701
2024-05-09 17:21 eplanerFX Note Added: 0000713
2024-05-09 17:52 scorpio810 Status new => resolved
2024-05-09 17:52 scorpio810 Resolution open => fixed
