| 0000287 | QElectroTech | other | public | 2023-08-28 17:42 | 2026-08-11 12:58 |
| Reporter | knhorstink | Assigned To | plc-user | ||
| Platform | Qelectrtech 0,90 on windows 10 | ||||
| Summary | 0000287: reverence at motor protection auxiliary contacts does not work | ||||
| Description | When you make an auxiliary contact and connect it to the appropriate motor protection, to turn on a lamp, for example, when the protection turns on. That the name and the reverence come together, this is not convenient and not readable. This makes the reverence useless. | ||||
| Steps To Reproduce | Step 1, grab a motor protection, name it with 3+ letters. step 2, grab an auxiliary contact under the cross-reverence contacts box step 3, place these and connect them together. now you will that the reverence and name are together i used the Motor protection switch GV and a contact normally closed single simple (NC). there are also 2 pictures attached for extra clarity. | ||||
| Attached Files | |||||
Hello, plese send you report bug in English, please, thanks. Cheers, Laurent |
I have updated the file so that it is now in english. |
https://qelectrotech.org/forum/viewtopic.php?id=2362 |
Fixed in sources of 0.100.1-dev |
| 2023-08-28 17:42 | knhorstink | New Issue | |
| 2023-08-28 17:42 | knhorstink | File Added: Schermafbeelding 2023-08-28 174120.png | |
| 2023-08-28 17:42 | knhorstink | File Added: Schermafbeelding 2023-08-28 174202.png | |
| 2023-08-28 20:53 | scorpio810_mantis | Note Added: 0000645 | |
| 2023-08-29 08:34 | knhorstink | Category | Element Editor => other |
| 2023-08-29 08:34 | knhorstink | Platform | Qelectrtech 0,90 op => Qelectrtech 0,90 on windows 10 |
| 2023-08-29 08:34 | knhorstink | Description Updated | |
| 2023-08-29 08:34 | knhorstink | Steps to Reproduce Updated | |
| 2023-08-29 08:35 | knhorstink | Summary | reverentie bij motorbeveiliging hulpcontacten werkt niet => reverence at motor protection auxiliary contacts does not work |
| 2023-08-29 08:36 | knhorstink | Note Added: 0000646 | |
| 2023-08-29 15:40 | scorpio810_mantis | Note Added: 0000647 | |
| 2026-08-11 12:58 | plc-user | Assigned To | => plc-user |
| 2026-08-11 12:58 | plc-user | Status | new => closed |
| 2026-08-11 12:58 | plc-user | Resolution | open => fixed |
| 2026-08-11 12:58 | plc-user | Note Added: 0000852 |
