0000286QElectroTechDiagram Editorpublic2026-09-22 11:23
Reporterbardouy Assigned To
PrioritynormalSeveritycrashReproducibilityhave not tried
Summary0000286: crash after modify the nomenclature contents - can be avoided
Descriptionv0.9 on Windows 7:
on 1st folio, select the table, and in nomenclature property tab "Contents"
- modified the included types to reduce the number of lines,
- update the 1st nomenclature folio page is not complete (with only the elements)
- crash when display next folio. Possibly because table is empty.
The manual on nomenclature explains nothing on configuration,ow are filled the elements information, types of elements and chained pages. Some hints are in several forum topics.
Steps To Reproducecreated diagram with around 15 elts and many connections.
Several linked nomenclature folio, added when msg " veuillez ajouter un nouveau tableau ou régler les tableaux existant...".
modified the nomenclature "Contents" for the columns, and the types => uncheck "borniers" & "simples".
Additional InformationAfter opening the saved project, with linked nomenclature in 4 folios, I cannot select the tables to get to properties.
I deletes all these folios, recreate one and one content with menclature, defining the correct types, and its OK.
So if the configuration is defined BEFORE linkin tables on several folios, the crash is avoided.
Tagsfolio
Activities
scorpio810_mantis
2023-08-16 14:56
administrator   ~0000642
Hello Yves,
thanks for reporting this issue.
Have you tried with last 0.100 devel version?
Regards,
scorpio810_mantis
2023-08-16 14:59
administrator   ~0000643
BTW, since 0.9 was released we fixed these on 0.100 devel version
https://git.tuxfamily.org/qet/qet.git/log/?h=0.8.1
scorpio810_mantis
2023-08-16 15:01
administrator   ~0000644
Opps wrong link, sorry
https://git.tuxfamily.org/qet/qet.git/log/?h=0.9.1
Issue History
2023-08-15 15:32 bardouy New Issue
2023-08-15 15:32 bardouy Tag Attached: folio
2023-08-15 15:32 bardouy File Added: image.png
2023-08-15 15:32 bardouy File Added: image-2.png
2023-08-15 15:32 bardouy File Added: image-3.png
2023-08-16 14:56 scorpio810_mantis Note Added: 0000642
2023-08-16 14:59 scorpio810_mantis Note Added: 0000643
2023-08-16 14:59 scorpio810_mantis Note Edited: 0000643
2023-08-16 15:01 scorpio810_mantis Note Added: 0000644
2023-08-16 15:01 scorpio810_mantis Note Edited: 0000644
2023-08-16 15:02 scorpio810_mantis Note Edited: 0000643
2026-09-22 11:23 scorpio810_mantis Status new => resolved
2026-09-22 11:23 scorpio810_mantis Resolution open => fixed
