| 0000282 | QElectroTech | other | public | 2023-02-17 20:51 | 2026-09-22 11:28 |
| Reporter | sorin | Assigned To | |||
| Summary | 0000282: When opening file to load, freezing and crashing | ||||
| Description | Open the program, go to open file, open file, window is open, (not load file) immediately after window file its open, freeze and crash in few seconds | ||||
| Steps To Reproduce | 1.Open the program, 2. open file, 3. window is open, (not load file) immediately after window file its open, freeze and crash in few seconds | ||||
| Additional Information | If I go to the folder with save project and open the save project file from there, it will open and work normally., edit save, all normal. But if you want to open from program file another file, open folder, crash in the same way. | ||||
| Tags | open file crash | ||||
| Attached Files | |||||
You could try with devel version 0.100.0 ? https://download.qelectrotech.org/qet/builds/nightly/2023-02-16-1/ |
Hi, I have the same problem. I tried newest version 0.100.0 it is the same. |
https://qelectrotech.org/forum/viewtopic.php?id=2416 |
https://qelectrotech.org/forum/viewtopic.php?pid=17612#p17612 |
Hi. I have the same issue since 2023.02.19. It started to work wierd right after 22H2 Windows 11 update was installed. Explorer related tasks not working at all. ( open file , save as, etc). If file is opened with doubleclick from desktop (for example) it starts and can be used but major speed loss experienced. I mean one click take 2 sec. Now I use version 0.100 on a Windows 10 HyperV virtual machine without any problem. |
@HUGABI: thanks for your feed back. |
Hi I'm running Windows 10 and still have the same issue as above. Anything related to file explorer like save as etc just crashes the program. I've tried both v0.9 and v0.100.it crashes running it from a USB drive too. |
https://qelectrotech.org/forum/viewtopic.php?pid=17675#p17675 |
https://qelectrotech.org/forum/viewtopic.php?pid=17693#p17693 |
Same here. All operations related to explorer are freezeng right after opening explorer window. Save as... Open file export as pdf ...all of them. After first crash the next attempts are veeery slow. Program load, library load, project load - everything takes much more time. QET log: not sure if there is any error visible - I've tried to "export as" and it works (because there is no explorer window called?) --uploaded as file Windows log: Faulting application name: qelectrotech.exe, version: 0.0.0.0, time stamp: 0x63b80c6d Faulting module name: ntdll.dll, version: 10.0.19041.2130, time stamp: 0xb5ced1c6 Exception code: 0xc0000005 Fault offset: 0x0000000000051cbe Faulting process id: 0x24e4 Faulting application start time: 0x01d94db7a5da36f7 Faulting application path: C:\Program Files\QElectroTech\bin\qelectrotech.exe Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll Report Id: a0135bd5-4f14-4627-95f1-da00b9318a4c Faulting package full name: Faulting package-relative application ID: 20230303.log (11,948 bytes)
11:17:27.384 Info: Start-up 11:17:27.724 Info: debugging enabled: false 11:17:27.725 Info: Qt library version: 5.15.7 11:17:27.725 Info: Qt library location default prefix: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5" 11:17:27.726 Info: Qt library location documentation: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/doc" 11:17:27.726 Info: Qt library location headers: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/include" 11:17:27.726 Info: Qt library location libraries: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/lib" 11:17:27.740 Info: Qt library location executables: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin" 11:17:27.740 Info: Qt library location Qt binaries: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/bin" 11:17:27.740 Info: Qt library location Qt plugins: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/plugins" 11:17:27.741 Info: Qt library location installed QML extensions: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/imports" 11:17:27.741 Info: Qt library location installed QML extensions: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/qml" 11:17:27.742 Info: Qt library location dependent Qt data: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5" 11:17:27.742 Info: Qt library location independent Qt data: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5" 11:17:27.742 Info: Qt library location translation: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/translations" 11:17:27.743 Info: Qt library location examples: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/examples" 11:17:27.743 Info: Qt library location Qt testcases: "/home/laurent/digikam3333/project/bundles/mxe/build.win64/usr/x86_64-w64-mingw32.static/qt5/tests" 11:17:27.744 Info: "QElectroTech V 0.90+c7891bc4cb0a58100c957a06d79751d3" 11:17:27.744 Info: "Sestaven�: GCC 11.3.0" 11:17:27.744 Info: "Built with Qt 5.15.7 - x86_64 - Date : Jan 6 2023 : 12:55:49" 11:17:27.745 Info: "Run with Qt 5.15.7 using 16 thread(s)" 11:17:27.745 Info: "CPU : NAME \r\r\nINTEL(R) CORE(TM) I9-9900KF CPU @ 3.60GHZ \r\r\n\r\r\n" 11:17:27.745 Info: "RAM Total : 32 GB" 11:17:27.746 Info: "RAM Available : 27 GB" 11:17:27.746 Info: "GPU : VideoProcessor \r\r\nNVIDIA GeForce GTX 1080 Ti \r\r\n\r\r\n" 11:17:27.746 Info: "GPU RAM : RAM Total : AdapterRAM \r\r\n4293918720 \r\r\n\r\r\n B" 11:17:27.747 Info: "OS : winnt - x86_64 - Version : Windows 10 Version 2009 - Kernel : 10.0.19045" 11:17:27.747 Info: *** Qt screens *** 11:17:27.747 Info: "( 1 : 3840 x 2160 )" 11:17:27.748 Info: "( 2 : 1920 x 1080 )" 11:17:27.758 Info: DISK : C:/ 11:17:27.758 Info: FileSystemType: "NTFS" 11:17:27.758 Info: SizeTotal: 511 GB 11:17:27.759 Info: AvailableSize: 300 GB 11:17:27.759 Info: DISK : D:/ 11:17:27.759 Info: FileSystemType: "NTFS" 11:17:27.760 Info: SizeTotal: 3000 GB 11:17:27.760 Info: AvailableSize: 605 GB 11:17:27.761 Info: DISK : E:/ 11:17:27.761 Info: FileSystemType: "" 11:17:27.761 Info: SizeTotal: 0 GB 11:17:27.761 Info: AvailableSize: 0 GB 11:17:27.762 Info: DISK : H:/ 11:17:27.762 Info: FileSystemType: "" 11:17:27.763 Info: SizeTotal: 0 GB 11:17:27.763 Info: AvailableSize: 0 GB 11:17:27.763 Info: DISK : I:/ 11:17:27.764 Info: FileSystemType: "" 11:17:27.764 Info: SizeTotal: 0 GB 11:17:27.764 Info: AvailableSize: 0 GB 11:17:27.765 Info: DISK : J:/ 11:17:27.765 Info: FileSystemType: "" 11:17:27.765 Info: SizeTotal: 0 GB 11:17:27.766 Info: AvailableSize: 0 GB 11:17:27.766 Info: DISK : Z:/ 11:17:27.766 Info: FileSystemType: "" 11:17:27.767 Info: SizeTotal: 0 GB 11:17:27.767 Info: AvailableSize: 0 GB 11:17:27.768 Info: DISK USED: C:/ 11:17:27.768 Info: FileSystemType: "NTFS" 11:17:27.769 Info: SizeTotal: 511 GB 11:17:27.769 Info: AvailableSize: 300 GB 11:18:50.088 Debug: is QRegularExpression ok? (../sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString&)) 11:18:50.094 Debug: is QRegularExpression ok? (../sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString&)) 11:19:00.410 Debug: Export XML de 7 schemas (../sources/qetproject.cpp:916, QDomDocument QETProject::toXml()) 11:19:00.410 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a4510) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:19:00.439 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3e30) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:19:00.590 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3ac0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:19:00.730 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a33e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:19:00.802 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a2990) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:19:00.870 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a2d00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:19:00.964 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3750) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:19:07.014 Info: Elements collection finished to be loaded 11:20:31.619 Debug: Export XML de 7 schemas (../sources/qetproject.cpp:916, QDomDocument QETProject::toXml()) 11:20:31.619 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a4510) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:20:31.650 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3e30) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:20:31.812 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3ac0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:20:31.954 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a33e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:20:32.020 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a2990) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:20:32.089 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a2d00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:20:32.182 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3750) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:20:33.526 Warning: QString::arg: Argument missing: Projekt 1% ulo�en� v adres�ri: RP-C., D:/Downloads/007 Zakazky/Zamek Lisno/Rozvadec/RP2-3_StredniKridlo.qet (:0, ) 11:20:43.208 Debug: Leave mouse over (../sources/qetgraphicsitem/conductortextitem.cpp:254, virtual void ConductorTextItem::hoverLeaveEvent(QGraphicsSceneHoverEvent*)) 11:20:43.257 Debug: Leave mouse over (../sources/qetgraphicsitem/conductortextitem.cpp:254, virtual void ConductorTextItem::hoverLeaveEvent(QGraphicsSceneHoverEvent*)) 11:20:44.197 Debug: Leave mouse over (../sources/qetgraphicsitem/conductortextitem.cpp:254, virtual void ConductorTextItem::hoverLeaveEvent(QGraphicsSceneHoverEvent*)) 11:21:00.411 Debug: Export XML de 7 schemas (../sources/qetproject.cpp:916, QDomDocument QETProject::toXml()) 11:21:00.415 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a4510) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:21:00.444 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3e30) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:21:00.588 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3ac0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:21:00.723 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a33e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:21:00.786 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a2990) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:21:00.849 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a2d00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:21:00.944 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3750) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:23:00.406 Debug: Export XML de 7 schemas (../sources/qetproject.cpp:916, QDomDocument QETProject::toXml()) 11:23:00.407 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a4510) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:23:00.435 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3e30) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:23:00.591 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3ac0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:23:00.732 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a33e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:23:00.796 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a2990) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:23:00.857 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a2d00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:23:00.945 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3750) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:25:00.420 Debug: Export XML de 7 schemas (../sources/qetproject.cpp:916, QDomDocument QETProject::toXml()) 11:25:00.423 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a4510) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:25:00.458 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3e30) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:25:00.606 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3ac0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:25:00.751 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a33e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:25:00.817 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a2990) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:25:00.883 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a2d00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 11:25:00.972 Debug: "exporting diagram \"Zamek Lisno - Saly stredni kridlo\"" [ Diagram(0x2c6c81a3750) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) |
@scorpio810 - I can not activate account on the forums ("Sorry, but we think you are bot. You can not activate account on this forum.") - is there any progress with this error? Export to PDF is essential function for my job. DEV 0.100 do not work either. |
Thanks for these informations, if you could try this? https://forums.flightsimulator.com/t/this-again-ntdll/550750/2 |
@r-man@seznam.cz I added you on forum |
@scorpio810 - I've tried this...will restart now... Log: C:\WINDOWS\system32>Dism.exe /online /Cleanup-Image /checkhealth Deployment Image Servicing and Management tool Version: 10.0.19041.844 Image Version: 10.0.19045.2604 No component store corruption detected. The operation completed successfully. C:\WINDOWS\system32>Dism.exe /online /Cleanup-Image /scanhealth Deployment Image Servicing and Management tool Version: 10.0.19041.844 Image Version: 10.0.19045.2604 [==========================100.0%==========================] No component store corruption detected. The operation completed successfully. C:\WINDOWS\system32>Dism.exe /online /Cleanup-Image /Restorehealth Deployment Image Servicing and Management tool Version: 10.0.19041.844 Image Version: 10.0.19045.2604 [==========================100.0%==========================] The restore operation completed successfully. The operation completed successfully. C:\WINDOWS\system32>sfc /scannow Beginning system scan. This process will take some time. Beginning verification phase of system scan. Verification 100% complete. Windows Resource Protection did not find any integrity violations. C:\WINDOWS\system32>Dism.exe /Online /Cleanup-Image /AnalyzeComponentStore Deployment Image Servicing and Management tool Version: 10.0.19041.844 Image Version: 10.0.19045.2604 [==========================100.0%==========================] Component Store (WinSxS) information: Windows Explorer Reported Size of Component Store : 9.87 GB Actual Size of Component Store : 9.61 GB Shared with Windows : 5.91 GB Backups and Disabled Features : 3.69 GB Cache and Temporary Data : 0 bytes Date of Last Cleanup : 2023-02-28 18:02:36 Number of Reclaimable Packages : 2 Component Store Cleanup Recommended : Yes The operation completed successfully. C:\WINDOWS\system32>Dism.exe /Online /Cleanup-Image /StartComponentCleanup Deployment Image Servicing and Management tool Version: 10.0.19041.844 Image Version: 10.0.19045.2604 [===== 10.0% ] [==========================100.0%==========================] The operation completed successfully. C:\WINDOWS\system32>try this? 'try' is not recognized as an internal or external command, operable program or batch file. C:\WINDOWS\system32> |
Did not help :-( |
thanks for feed back. Nvidia GPU? https://appuals.com/call-of-duty-black-ops-cold-war-error-code-0xc0000005/ |
Hi all. I uninstalled antivirus Avast and it helped!!! Bullshit.. I hope you the same problem. |
Thanks Burak, the various of Friskolon tests on the forum show the same thing, AVAST seems to be responsible for this problem which makes QET crash at what seems ... https://qelectrotech.org/forum/viewtopic.php?pid=17730#p17730 |
I had Avast as well. After I uninstalled it everything works fine, so the solution works. What to use instead? :) |
Friskolon at forum use avira, https://www.avira.com/en/free-antivirus-windows but you could use Microsoft defender installed by default on your Windows. |
Avast antivirus: Installing clean newest version - did not help. Turn off all shields - did not help. Uninstall completely - did help. Avira antivirus: Installed and QET is working - did help. Unfortunately I need Avast due to company rules. Is there any option how to determine exact error cause? I can send it to Avast for their investigation. |
I started Avast topic on their forum: https://forum.avast.com/index.php?topic=322947.0 |
| 2023-02-17 20:51 | sorin | New Issue | |
| 2023-02-17 20:51 | sorin | Tag Attached: open file crash | |
| 2023-02-17 20:51 | sorin | File Added: 20230217_214915.mp4 | |
| 2023-02-18 05:25 | scorpio810_mantis | Note Added: 0000614 | |
| 2023-02-18 13:57 | burak | Note Added: 0000615 | |
| 2023-02-19 13:41 | scorpio810_mantis | Note Added: 0000616 | |
| 2023-02-19 19:01 | scorpio810_mantis | Note Added: 0000617 | |
| 2023-02-21 19:53 | HUGABI | Note Added: 0000618 | |
| 2023-02-22 19:26 | scorpio810_mantis | Note Added: 0000619 | |
| 2023-02-24 08:54 | Mrturbo | Note Added: 0000620 | |
| 2023-02-26 18:31 | scorpio810_mantis | Note Added: 0000622 | |
| 2023-02-28 10:43 | scorpio810_mantis | Note Added: 0000624 | |
| 2023-03-03 11:27 | r-man@seznam.cz | Note Added: 0000625 | |
| 2023-03-03 11:27 | r-man@seznam.cz | File Added: 20230303.log | |
| 2023-03-03 11:42 | r-man@seznam.cz | Note Added: 0000626 | |
| 2023-03-03 11:50 | scorpio810_mantis | Note Added: 0000627 | |
| 2023-03-03 12:00 | scorpio810_mantis | Note Added: 0000628 | |
| 2023-03-03 13:04 | r-man@seznam.cz | Note Added: 0000629 | |
| 2023-03-03 13:08 | r-man@seznam.cz | Note Added: 0000630 | |
| 2023-03-03 20:45 | scorpio810_mantis | Note Added: 0000631 | |
| 2023-03-03 22:39 | burak | Note Added: 0000632 | |
| 2023-03-05 07:41 | scorpio810_mantis | Note Added: 0000633 | |
| 2023-03-05 09:05 | HUGABI | Note Added: 0000634 | |
| 2023-03-05 09:42 | scorpio810_mantis | Note Added: 0000635 | |
| 2023-03-07 22:37 | r-man@seznam.cz | Note Added: 0000636 | |
| 2023-03-07 22:44 | r-man@seznam.cz | Note Added: 0000637 | |
| 2026-09-22 11:28 | scorpio810_mantis | Status | new => resolved |
| 2026-09-22 11:28 | scorpio810_mantis | Resolution | open => fixed |
