0000281QElectroTechLibraries of elementspublic2026-08-11 13:03
Reporterdodo Assigned Toplc-user
PrioritynormalSeveritymajorReproducibilityalways
Status closedResolutionfixed
Summary0000281: Cannot create a new part
DescriptionWhen trying to create a new part for the user library, the wizzard appears but after finishing the wizzard, nothing happens. Expecially, no new part in the library gets created.
macOS, QElectroTech V 0.90-DEV r71297a0e4
This seems to be a regression bug because I did already create parts in earlier versions.
Steps To Reproduce1. Open QElectrotech, with or without a project
2. Right click on the user library, select create new part. The wizzard opens.
3. Enter filename and translated part name
4. Close the wizzard in the last step by clicking the "Done" button.
5. Wizzard closes, nothing happens.
Expected behavior:
5. Wizzard closes
6. Parts editor opens with newly created (blank) part.
TagsNo tags attached.
Activities
scorpio810_mantis
2023-01-05 12:00
administrator   ~0000606
Please try latest
https://download.qelectrotech.org/qet/builds/MAC_OS_X/qelectrotech%200.90-DEV%20r7769.dmg
scorpio810_mantis
2023-01-06 13:22
administrator   ~0000607
6. Reduce diagram windows, The element editor is just behind this window
dodo
2023-01-07 11:39
reporter   ~0000608
Thank you for the hint. The element editor opens in the background, indeed. What is crazy though is that the menu bar already shows the menus for the element editor, even though the focus window is still the schematics editor.
Also, when clicking into the schematics editor (so that the menu bar changes its items to the schematics menu), the windows menu does not list the element editor as open window. And right clicking on the qelectrotech icon in the Dock does not show multiple windows, either.
Should I list these as separate bugs?
scorpio810_mantis
2023-01-13 21:23
administrator   ~0000609
https://qelectrotech.org/forum/viewtopic.php?pid=17343#p17343
Yes, for MAC we need a C++ Qt developer familiar with this operating system. We don't have a MAC, I'm running it in virtual environment just to build and package it, my attempts to passtrough GPU for graphics acceleration failed and wasted some free time... It's already a big job for the packaging...
scorpio810
scorpio810_mantis
2023-01-17 14:43
administrator   ~0000610
6. Reduce diagram windows, The element editor is just behind this window or right click on QET in dock and choose view all windows.
scorpio810_mantis
2023-01-20 12:15
administrator   ~0000611
Topic: Financing macOS machine for improving QElectroTech on MAC
https://qelectrotech.org/forum/viewtopic.php?id=2393
scorpio810_mantis
2023-02-06 19:38
administrator   ~0000612
If you have M1 M2 apple silicon please try
https://qelectrotech.org/forum/viewtopic.php?pid=17562#p17562
scorpio810_mantis
2023-02-11 22:15
administrator   ~0000613
https://youtu.be/Gr90uxlt2nA
scorpio810_mantis
2023-02-26 14:59
administrator   ~0000621
Check to open project in terminals:
BTW, we saw you have forgot --args in code
https://github.com/qelectrotech/qelectrotech-source-mirror/issues/218#issuecomment-1146591981
laurent@mini-de-laurent-1 /Applications % open -a qelectrotech.app --args /Users/laurent/Desktop/examples/industrial.qet
laurent@mini-de-laurent-1 /Applications % open -a qelectrotech.app --args /Users/laurent/qet_git/elements/10_electric/20_manufacturers_articles/bamo/bamo_relais_niveau_resistif_es_2001.elmt
scorpio810_mantis
2023-03-10 16:00
administrator   ~0000638
https://stackoverflow.com/questions/29670692/handling-mac-os-x-file-open-event-before-c-main-executes
plc-user
2026-08-11 13:03
developer   ~0000855
Fixed in sources of 0.100.1-dev
Issue History
2023-01-04 22:28 dodo New Issue
2023-01-05 12:00 scorpio810_mantis Note Added: 0000606
2023-01-06 13:22 scorpio810_mantis Note Added: 0000607
2023-01-07 11:39 dodo Note Added: 0000608
2023-01-13 21:23 scorpio810_mantis Note Added: 0000609
2023-01-17 14:43 scorpio810_mantis Note Added: 0000610
2023-01-20 12:15 scorpio810_mantis Note Added: 0000611
2023-02-06 19:38 scorpio810_mantis Note Added: 0000612
2023-02-11 22:15 scorpio810_mantis Note Added: 0000613
2023-02-26 14:59 scorpio810_mantis Note Added: 0000621
2023-02-26 15:02 scorpio810_mantis Note Edited: 0000621
2023-03-10 16:00 scorpio810_mantis Note Added: 0000638
2026-08-11 13:03 plc-user Assigned To => plc-user
2026-08-11 13:03 plc-user Status new => closed
2026-08-11 13:03 plc-user Resolution open => fixed
2026-08-11 13:03 plc-user Note Added: 0000855
