0000027QElectroTechwebsitepublic2021-02-15 00:52
Reporterscorpio810_mantis Assigned To
PrioritynormalSeveritycrashReproducibilityalways
Status closedResolutionfixed
Summary0000027: FTBS on arm arch
Descriptionsources/borderinset.cpp: In member function 'void BorderInset::setColumnsHeaderHeight(const qreal&)':
sources/borderinset.cpp:354: error: no matching function for call to 'qBound(double, const float&, double)'
sources/borderinset.cpp: In member function 'void BorderInset::setRowsHeaderWidth(const qreal&)':
sources/borderinset.cpp:391: error: no matching function for call to 'qBound(double, const float&, double)'
sources/borderinset.cpp: In member function 'void BorderInset::setInsetHeight(const qreal&)':
sources/borderinset.cpp:418: error: no matching function for call to 'qMax(double, const float&)'
make[2]: *** [release/borderinset.o] Error 1
make[1]: *** [release] Error 2
make: *** [debian/stamp-makefile-build] Error 2
TagsNo tags attached.
Activities
scorpio810_mantis
2009-09-10 12:32
administrator   ~0000045
denis patch
http://scorpio810.blogdns.net/generation-debian/qelectrotech/patchs/04_fix_FTBFS_on_armel.diff
xavier
2009-09-12 12:10
reporter   ~0000046
Cause : Utilisation conjointe du typedef qreal (= float sous ARM, double sur les autres architectures) et du type double, menant à des incompatibilités d'argument double vs float.
Solution : patch autorisant la compilation de QElectroTech :
https://download.qelectrotech.org/qet/temp/qelectrotech-arm.diff
Issue History
2009-09-08 15:45 scorpio810_mantis New Issue
2009-09-10 12:32 scorpio810_mantis Note Added: 0000045
2009-09-10 12:33 scorpio810_mantis Note Edited: 0000045
2009-09-12 12:10 xavier Note Added: 0000046
2009-09-12 12:10 xavier Status new => closed
2009-09-12 12:10 xavier Resolution open => fixed
2009-09-12 12:10 xavier Fixed in Version => 0.21
2013-06-09 14:08 scorpio810_mantis Category Éditeur de schémas => Diagram Editor
2021-02-15 00:52 user245 Category Diagram Editor => website
