| 0000253 | QElectroTech | Diagram Editor | public | 2022-01-27 23:18 | 2026-10-07 09:43 |
| Reporter | hubert@zire.pl | Assigned To | |||
| Priority | immediate | Severity | block | Reproducibility | always |
| Status | resolved | Resolution | open | ||
| Summary | 0000253: Terminals position on each element is random. | ||||
| Description | Hi, On diagram editor terminal positon of elements are "random". In element editor everything is fine. I even reinstalled QET but without effect :( | ||||
| Steps To Reproduce | I don't know :( | ||||
| Attached Files | |||||
What's you monitor resolution (HD, 4K 8K etc...)? Did you set a scale factor on Windows ? We encounter strong difficulty with with hpdi monitor and scale factor. https://qelectrotech.org/forum/viewtopic.php?id=1004 https://qelectrotech.org/forum/viewtopic.php?id=2011 |
Thanks for the screenshot. In it, the terminals are spread 25 % wider than the symbol's lines, which matches Windows display scaling at 125 %. I could not reproduce it on the current version, at 125 % scaling or at 120 DPI. Do you use two screens with different scaling? Does it still happen with a current build (https://qelectrotech.org/download.php)? |
Thank you so much for checking and fixing a lot of issue I reported. I have not created electric nor pipe schemas for a few years, but plan to soon again and then I will use QET again. Will try to remember to check back then :-) (I currently work with repairs and service) Sorry to have missed to reply black_sun. Yes that was on a 4K screen, using Linux (Mageia), KDE Plasma desktop. |
| 2022-01-27 23:18 | hubert@zire.pl | New Issue | |
| 2022-01-27 23:18 | hubert@zire.pl | File Added: QET Terminals bug.png | |
| 2022-03-30 20:01 | black_sun | Note Added: 0000546 | |
| 2026-10-01 05:13 | ispyisail | Note Added: 0000923 | |
| 2026-10-05 08:55 | Morganol | Note Added: 0000940 | |
| 2026-10-07 09:43 | ispyisail | Status | new => resolved |
