0000253QElectroTechDiagram Editorpublic2026-10-05 08:55
Reporterhubert@zire.pl Assigned To
PriorityimmediateSeverityblockReproducibilityalways
Status newResolutionopen
Summary0000253: Terminals position on each element is random.
DescriptionHi,
On diagram editor terminal positon of elements are "random". In element editor everything is fine.
I even reinstalled QET but without effect :(
Steps To ReproduceI don't know :(
TagsNo tags attached.
QET Terminals bug.png (129,520 bytes)
Activities
black_sun
2022-03-30 20:01
developer   ~0000546
What's you monitor resolution (HD, 4K 8K etc...)?
Did you set a scale factor on Windows ?
We encounter strong difficulty with with hpdi monitor and scale factor.
https://qelectrotech.org/forum/viewtopic.php?id=1004
https://qelectrotech.org/forum/viewtopic.php?id=2011
ispyisail
2026-10-01 05:13
developer   ~0000923
Thanks for the screenshot. In it, the terminals are spread 25 % wider than the symbol's lines, which matches Windows display scaling at 125 %. I could not reproduce it on the current version, at 125 % scaling or at 120 DPI. Do you use two screens with different scaling? Does it still happen with a current build (https://qelectrotech.org/download.php)?
Morganol
2026-10-05 08:55
reporter   ~0000940
Thank you so much for checking and fixing a lot of issue I reported.
I have not created electric nor pipe schemas for a few years, but plan to soon again and then I will use QET again. Will try to remember to check back then :-)
(I currently work with repairs and service)
Sorry to have missed to reply black_sun. Yes that was on a 4K screen, using Linux (Mageia), KDE Plasma desktop.
Issue History
2022-01-27 23:18 hubert@zire.pl New Issue
2022-01-27 23:18 hubert@zire.pl File Added: QET Terminals bug.png
2022-03-30 20:01 black_sun Note Added: 0000546
2026-10-01 05:13 ispyisail Note Added: 0000923
2026-10-05 08:55 Morganol Note Added: 0000940
