| 0000247 | QElectroTech | Diagram Editor | public | 2021-11-18 10:15 | 2026-09-22 11:08 |
| Reporter | ntd | Assigned To | |||
| Priority | normal | Severity | text | Reproducibility | always |
| Platform | Linux x64 | OS | ArchLinux | OS Version | rolling |
| Summary | 0000247: XRef slave reference hidden with dark themes | ||||
| Description | With dark theme, I have the following workaround in my ~/.qet/style.css (see note 0000175:0000372 for the rationale):
Everything seems to work fine but the slave references to master elements. That text is drawn white on white by default but gain proper contrast only when hovering it. I created a video exhibiting this bug. Pay attention to the (1-D3) text in this video: https://youtu.be/pZsLBUMtVqE That would be a minor issue, but the fact that this is present also when printing makes it really inconvenient: every time I need to generate the PDF I have to switch to a light theme. AFAIK this is the only issue I have now with dark themes. I also tried the styles provided by @scorpio810 in this two forum posts with the same results: https://qelectrotech.org/forum/viewtopic.php?pid=10352#p10352 https://qelectrotech.org/forum/viewtopic.php?pid=2411#p2411 | ||||
| Tags | theme | ||||
Already reported in the forum: https://qelectrotech.org/forum/viewtopic.php?id=1549 Sorry for the duplicate: I posted it the past year and then I forgot everything. |
| 2021-11-18 10:15 | ntd | New Issue | |
| 2021-11-18 10:15 | ntd | Tag Attached: theme | |
| 2021-11-18 10:22 | ntd | Description Updated | |
| 2021-11-22 12:00 | ntd | Note Added: 0000528 | |
| 2026-09-22 11:08 | scorpio810_mantis | Status | new => resolved |
| 2026-09-22 11:08 | scorpio810_mantis | Resolution | open => fixed |
