| 0000223 | QElectroTech | website | public | 2021-01-23 16:07 | 2021-02-15 00:50 |
| Reporter | JirkaZ | Assigned To | |||
| Priority | normal | Severity | feature | Reproducibility | always |
| Summary | 0000223: Connection between two wires | ||||
| Description | Suggestion for improvement: the possibility to connect one wire directly to another wire without having to connect to another element. Description: click anywhere on the first wire, drag with the mouse, click anywhere on the second wire. Result: the connection is created (including dots as connection points). The vast majority of schematic editors I've worked with do that. | ||||
| Steps To Reproduce | Description: click anywhere on the first wire, drag with the mouse, click anywhere on the second wire. | ||||
| Tags | conductor, connection, wires | ||||
Have submitted these issues to https://github.com/qelectrotech/qelectrotech-source-mirror/issues so they can be found alongside pull requests |
| 2021-01-23 16:07 | JirkaZ | New Issue | |
| 2021-01-23 16:07 | JirkaZ | Tag Attached: conductor | |
| 2021-01-23 16:07 | JirkaZ | Tag Attached: connection | |
| 2021-01-23 16:07 | JirkaZ | Tag Attached: wires | |
| 2021-01-23 16:09 | JirkaZ | Description Updated | |
| 2021-01-23 16:09 | JirkaZ | Steps to Reproduce Updated | |
| 2021-02-15 00:43 |
Note Added: 0000491 | |
| 2021-02-15 00:44 |
Product Version | SVN/branches/0.x => 0.8 |
| 2021-02-15 00:45 |
| 2021-02-15 00:46 |
| 2021-02-15 00:50 |
