0000212QElectroTechwebsitepublic2021-02-15 19:03
ReporterBisku Assigned Toblack_sun
PrioritynormalSeverityblockReproducibilityalways
OSWindows 10OS Version20H2
Product VersionSVN/trunk
Fixed in VersionSVN/trunk
Summary0000212: Element editor shows wrong source of text on folio references
DescriptionI have modified folio referencing in my user collection to show not only the link poosition but also mention the voltage/protocoll entry of the connecting wire to give extra information (see elements attached).
When I tried to change the displayed element information I noticed that current RC doesn't recognize the element if I switch between different elements. But when saving the file I noticed it actually wrote the correct information into the file.
Seems like it is just the information show in the element editor, that is not correct.
Steps To Reproduce1. Create a new element
2. Go to element properties and set base type to reference folio following
3. Insert two dynamic text fields
4. Select first text and change the source to element information / voltage/protocol
5. Select second text and change the source to element information / label
6. Click on first element again and it will show element information as "function"
   (but don't do changes)
7. Click on second element - same here.
8. Add a terminal and save the file
9. Open file in text editor: it saved the "original" information "voltage/protocol" and "label".
TagsNo tags attached.
Activities
black_sun
2021-02-15 19:03
developer   ~0000496
Fixed in git 30858f9a4d4f5899744ff7684c6d36c8ad7447c3
https://git.tuxfamily.org/qet/qet.git/commit/?id=30858f9a4d4f5899744ff7684c6d36c8ad7447c3
Issue History
2020-12-03 08:49 Bisku New Issue
2021-02-15 00:44 user245 Product Version SVN/branches/0.x => 0.8
2021-02-15 00:47 user245 Product Version 0.8 => SVN/trunk
2021-02-15 00:51 user245 Category Element Editor => website
2021-02-15 00:54 user245 Severity major => block
2021-02-15 19:03 black_sun Assigned To => black_sun
2021-02-15 19:03 black_sun Status new => resolved
2021-02-15 19:03 black_sun Resolution open => fixed
2021-02-15 19:03 black_sun Note Added: 0000496
