0000192 | QElectroTech | website | public | 2020-06-22 10:42 | 2021-02-15 00:51 |
Reporter | Byrmistr | Assigned To | |||
Priority | normal | Severity | text | Reproducibility | always |
OS | Windows | OS Version | 7 | ||
Summary | 0000192: QET 0,8 | ||||
Description | Good day. In the program version 0.8, I drew the simplest power scheme for the garage from the pillar. Printed on two printers: laser HP LJ P1005 and ink jet Canon Pichma 3300. In both cases, the top (in landscape orientation) frame line is not printed. I struggled with the page settings in the program and in printers - it was useless. He killed a bunch of paper. What to do? | ||||
Attached Files | |||||
Good day. Maybe create a PDF and print after if PDF is okay. |
There is no export to PDF. I tried to print BMP, JPG, PNG it turns out, but the print quality is poor. Elements have a point structure. |
https://download.qelectrotech.org/qet/manual_0.7/build/export&print/create_pdf.html |
scorpio810. Thank you friend! To get acquainted with QET, I used the Russian version 0.4 description. There is no about PDF. And in English I'm a sucker. I use Google translator. |
2020-06-22 10:42 | Byrmistr | New Issue | |
2020-06-25 08:11 | scorpio810 | Note Added: 0000422 | |
2020-06-25 23:22 | Byrmistr | Note Added: 0000423 | |
2020-06-26 11:51 | scorpio810 | Note Added: 0000424 | |
2020-06-28 20:49 | Byrmistr | Note Added: 0000425 | |
2020-06-28 20:50 | Byrmistr | Note Edited: 0000425 | |
2020-06-29 07:34 | scorpio810 | File Added: pdf_print.png | |
2021-02-15 00:44 |
Product Version | => 0.8 |
2021-02-15 00:45 |
2021-02-15 00:47 |
2021-02-15 00:51 |
