0000175 | QElectroTech | Diagram Editor | public | 2019-08-19 22:20 | 2019-08-20 11:46 |
Reporter | ntd | Assigned To | |||
Platform | OS | ArchLinux | OS Version | ||
Product Version | |||||
Target Version | Fixed in Version | ||||
Summary | 0000175: Symbols not rendered properly with dark theme selected | ||||
Description | When a dark Qt theme is selected, symbols are rendered partly in black and partly in white. As a consecuence, part of the symbols disappears on white background and the diagram seems to be "incomplete". | ||||
Steps To Reproduce | For quickly switching theme I use the following commands: ``` $ QT_QPA_PLATFORMTHEME=gtk2 qelectrotech # Dark because I've a dark GTK+ theme enabled $ QT_QPA_PLATFORMTHEME=fusion qelectrotech # Bright ``` | ||||
Additional Information | In the attached image, on the left you can see a page opened with a bright theme (fusion) while on the right the same page is opened with a dark theme (gtk2, with a dark GTK+ theme selected). I tried some different theme combinations by using `qt5ct` and the problem seems to affect all dark themes. | ||||
