| 0000173 | QElectroTech | website | public | 2019-07-20 18:28 | 2021-02-15 00:52 |
| Reporter | mberntsen | Assigned To | black_sun | ||
| Status | closed | Resolution | no change required | ||
| Platform | Ubuntu | ||||
| Summary | 0000173: List of folios overwriting changes | ||||
| Description | Hi, When I insert a list of folios page, and change the title block, folioname/author/date, this information is lost when saving and reopening the file. Might this be because it is regenerated? I would expect the changed to be kept, and only the index regenerated (or not be regenerated unless requested). | ||||
| Steps To Reproduce | - insert list of folios - change title block (to custom adaptation of the default, but with the name 'sheet') - change folioname/author/date - save document - close document - open document - now the list of folios is named 'list of folios' again and the titleblock is set to the default qet titleblock | ||||
| Additional Information | QElectroTech V 0.70-dev+svn5685 Compilation: GCC 5.4.0 20160609 - built with Qt 5.5.1 - run with Qt 5.9.5 using 4 thread(s) | ||||
Hi, yes folios page is generated on the fly and not saved, make your changes in title block folios. folios page use titleblock new folio setting in your project config. |
Btw, you could use search and replace widget for big changes in your project. vidéo |
Not a bug, this is the normal behavior (even if it's not perfect). |
| 2019-07-20 18:28 | mberntsen | New Issue | |
| 2019-07-20 20:01 | scorpio810_mantis | Note Added: 0000369 | |
| 2019-07-20 20:03 | scorpio810_mantis | Note Added: 0000370 | |
| 2019-07-20 20:06 | scorpio810_mantis | Note Edited: 0000369 | |
| 2019-12-10 21:01 | black_sun | Assigned To | => black_sun |
| 2019-12-10 21:01 | black_sun | Status | new => closed |
| 2019-12-10 21:01 | black_sun | Resolution | open => no change required |
| 2019-12-10 21:01 | black_sun | Note Added: 0000406 | |
| 2021-02-15 00:52 |
