| 0000115 | QElectroTech | website | public | 2016-10-30 20:13 | 2021-02-15 00:48 |
| Priority | normal | Severity | feature | Reproducibility | have not tried |
| Platform | Qt5.6.1, kf5.27.0, Plasma5.8.2, | OS | 64 bit, Linux 4.8.5, gcc 5.4.0, | OS Version | Mageia 6 (devel) |
| Summary | 0000115: Make master&slave elements xref clickable ( like folio referencing links are ) | ||||
| Description | Ref: https://qelectrotech.org/forum/viewtopic.php?pid=5839#p5839 | ||||
I see the first step :) Now at master clicking a contact xref, takes you to that contact. (Works for view as contacts, not as cross) 4784 3t 29m blacksun /trunk/ Cross ref item : Double click in a contact of the Xref, go to the real contact. (only available for Xref draw as contacts) |
Reopening... "In the works" i wrote in forum, meaning it is being worked upon but not yet finished. Current state is that double-clicking an xref at a master, take you to that slave, nice :) I reopen because the xref at the slaves are not yet live. (should take you to its master) ----- Strange here in Mantis: I pressed button "Reopen" but got this form with button "Request feedback" that i now press. |
Ah... OKOK it is implemented this way: on slave double click LABEL (not xref) I learned it by mistake at slave double click the *label" and that brought me to master ;) SO: I see the logic: the label is the name of the MASTER device. It would be more intuitive though if it would react to double cliking on the xref (also) |
| 2016-10-30 20:13 | Morganol | New Issue | |
| 2016-11-16 23:41 | Morganol | Note Added: 0000204 | |
| 2016-11-17 22:00 | scorpio810_mantis | Status | new => resolved |
| 2016-11-17 22:00 | scorpio810_mantis | Resolution | open => fixed |
| 2016-11-17 22:00 | scorpio810_mantis | Fixed in Version | => SVN/trunk |
| 2016-11-17 23:52 | Morganol | Status | resolved => feedback |
| 2016-11-17 23:52 | Morganol | Resolution | fixed => reopened |
| 2016-11-17 23:52 | Morganol | Note Added: 0000205 | |
| 2016-11-18 01:24 | Morganol | Note Added: 0000206 | |
| 2016-11-18 01:24 | Morganol | Status | feedback => new |
| 2016-11-20 18:45 | scorpio810_mantis | Status | new => resolved |
| 2016-11-20 18:45 | scorpio810_mantis | Resolution | reopened => fixed |
| 2021-02-15 00:48 |
