0000108QElectroTechwebsitepublic2026-09-22 11:04
ReporterMorganol Assigned To
PrioritynormalSeverityblockReproducibilityalways
PlatformQt5.6.1, kf5.27.0, Plasma5.8.1, OSLinux 4.8.2, gcc 5.4.0, OS VersionMageia 6 (devel)
Summary0000108: For wide conductors the automatic joining dot is too small/invisible
DescriptionPROBLEM:
At conductor width => 6 a cross do not get a visible joining dot.
(and a T is not looking very god; blob only on the flat side, not in angles)
PROPOSAL:
I think the dot diameter should be something like 2 + ( 3 x conductor_width )
This wide conductors are not much used, but right now really nice when I am drawing process piping where some tubes are much bigger than the thin lines. :)
TagsNo tags attached.
Activities
Morganol
2016-10-20 10:18
reporter   ~0000188
Thoughts about dot size formula:
There must be a ofset so dots on thin conductors are relatively big, for visibility.
The multiplication factor must not be too big so joints get clumsy, and not too small.
- joint ger invisible at cross if its diameter is smaller than sqrt(2)*line_width.
So i change my mind about formula: i guess multiplication factor of about 2 is probably better
and add an ofset of about 2 px. (if px is the unit of line width)
scorpio810_mantis
2017-01-30 19:44
administrator   ~0000233
Could you send us a patch?
Issue History
2016-10-20 00:45 Morganol New Issue
2016-10-20 10:18 Morganol Note Added: 0000188
2017-01-30 19:44 scorpio810_mantis Note Added: 0000233
2021-02-15 00:49 user245 Severity minor => block
2026-09-22 11:04 scorpio810_mantis Status new => resolved
2026-09-22 11:04 scorpio810_mantis Resolution open => fixed
