0000108 | QElectroTech | website | public | 2016-10-20 00:45 | 2021-02-15 00:50 |
Reporter | Morganol | Assigned To | |||
Priority | normal | Severity | block | Reproducibility | always |
Platform | Qt5.6.1, kf5.27.0, Plasma5.8.1, | OS | Linux 4.8.2, gcc 5.4.0, | OS Version | Mageia 6 (devel) |
Summary | 0000108: For wide conductors the automatic joining dot is too small/invisible | ||||
Description | PROBLEM: At conductor width => 6 a cross do not get a visible joining dot. (and a T is not looking very god; blob only on the flat side, not in angles) PROPOSAL: I think the dot diameter should be something like 2 + ( 3 x conductor_width ) This wide conductors are not much used, but right now really nice when I am drawing process piping where some tubes are much bigger than the thin lines. :) | ||||
Thoughts about dot size formula: There must be a ofset so dots on thin conductors are relatively big, for visibility. The multiplication factor must not be too big so joints get clumsy, and not too small. - joint ger invisible at cross if its diameter is smaller than sqrt(2)*line_width. So i change my mind about formula: i guess multiplication factor of about 2 is probably better and add an ofset of about 2 px. (if px is the unit of line width) |
Could you send us a patch? |
2016-10-20 00:45 | Morganol | New Issue | |
2016-10-20 10:18 | Morganol | Note Added: 0000188 | |
2017-01-30 19:44 | scorpio810 | Note Added: 0000233 | |
2021-02-15 00:45 |
2021-02-15 00:49 |
Severity | minor => block |
2021-02-15 00:50 |
