0000103QElectroTechDiagram Editorpublic2017-01-03 23:33
ReporterMorganol Assigned To
PrioritynormalSeverityfeatureReproducibilityalways
Status newResolutionopen
PlatformQt5.6.1, kf5.27.0, Plasma5.8.1, OSLinux 4.7.8, gcc 5.4.0, OS VersionMageia 6
Product VersionSVN/trunk
Target VersionFixed in Version
Summary0000103: Make master location label at slaves be hotlinks to master
DescriptionRegarding master and slave connected elements:
__THIS IS REALLY NICE ALREADY:
In the xref list at the master, the location labels for the slaves are hotlinks; if you click them you are immediately taken to the slaves.
__PROPOSAL:
Correspondingly; At the slaves, make the label for master be clickable to take you to master
This is analoguous with how Sheet referencing "Next folio" and "Previous folio" can take you both directions.
TagsNo tags attached.
Activities
Morganol
2017-01-03 23:33
reporter   ~0000225
Currently you at the slave have to click the label to be taken to the master.
That works OK.
However, for style and coherence:
Maybe it would be better if (also or instead) the xref was clickable -- because at the master as well as at both folio references it is the xref that is to be clicked.
Issue History
2016-10-12 22:53 Morganol New Issue
2017-01-03 23:33 Morganol Note Added: 0000225
