| 0000103 | QElectroTech | website | public | 2016-10-12 22:53 | 2021-02-15 00:52 |
| Reporter | Morganol | Assigned To | black_sun | ||
| Priority | normal | Severity | feature | Reproducibility | always |
| Platform | Qt5.6.1, kf5.27.0, Plasma5.8.1, | OS | Linux 4.7.8, gcc 5.4.0, | OS Version | Mageia 6 |
| Summary | 0000103: Make master location label at slaves be hotlinks to master | ||||
| Description | Regarding master and slave connected elements: __THIS IS REALLY NICE ALREADY: In the xref list at the master, the location labels for the slaves are hotlinks; if you click them you are immediately taken to the slaves. __PROPOSAL: Correspondingly; At the slaves, make the label for master be clickable to take you to master --- This is analoguous with how Sheet referencing "Next folio" and "Previous folio" can take you both directions. | ||||
Currently you at the slave have to click the label to be taken to the master. That works OK. However, for style and coherence: Maybe it would be better if (also or instead) the xref was clickable -- because at the master as well as at both folio references it is the xref that is to be clicked. |
implemented |
| 2016-10-12 22:53 | Morganol | New Issue | |
| 2017-01-03 23:33 | Morganol | Note Added: 0000225 | |
| 2020-09-13 15:50 | black_sun | Assigned To | => black_sun |
| 2020-09-13 15:50 | black_sun | Status | new => closed |
| 2020-09-13 15:50 | black_sun | Resolution | open => fixed |
| 2020-09-13 15:50 | black_sun | Note Added: 0000452 | |
| 2021-02-15 00:52 |
