| 0000101 | QElectroTech | website | public | 2016-10-12 18:32 | 2026-10-01 02:27 |
| Priority | normal | Severity | block | Reproducibility | always |
| Platform | Qt5.6.1, kf5.27.0, Plasma5.8.1, | OS | Linux 4.7.8, gcc 5.4.0, | OS Version | Mageia 6 |
| Summary | 0000101: Crash and other issues when editing an arc * REPEATABLE * | ||||
| Description | r4736 See Steps To Reproduce | ||||
| Steps To Reproduce | § Create a new element § In that element create an arc, start down-left, end up-right § ESC out of arc tool § Select the arc, so handles are green (problem do not appear when handles are blue) Screenshot 1-ARC_selected-green_handles.png § Then either: A) § click the top left green handle => segmentation fault In Dissassembler QVariant::clear() at line 2: 0x7ffff6e47b41 <+0x0001> f6 47 0b 40 testb $0x40,0xb(%rdi) (unfortunately no source?) B) § click the top center handle ( = arc up-right end) => screenshot 2_B-ARC_vanished_by_clicking_top_center_green_handle-handles_at_down_left.png § arc vanishes from sight § one strange handle appear where lower left end was § I can not select anything in the area - it is gone § also after making a label "label", saving, reopen: it is gone C) § click the middle left handle => only arc is visible, with end handles (OK) screenshot 3_C1-ARC_selected-green_handle_at_middle_left_is_clicked.png § click lower left end handle => arc gets invisible! screenshot 4_C2-ARC_invisible_after_clicking_its_lower_left.png § I can still drag its size by handles § I can select properties such as strong, filled, dashed, etc - still invisible § I can click somewhere else, and then select it again by click-dragging over the area § after making a label "label", saving, reopen: it is still there but invisible ( - and at another location = where i put the label...) § it is also invisible when i put it in the schematic Side note: Editor do not crash from usong symbols generated in B and C above, and then saving shematic. | ||||
| Attached Files | |||||
I could not reproduce this on current master (7f799bb42, Linux, Qt 6). I made a symbol with one arc (start lower left, end upper right), selected it so the handles were green, and tried: A) click the top-left handle: no crash, arc unchanged B) click the top-centre handle: arc stays visible C) click the middle-left handle, then the arc: arc stays visible and switches to the magenta angle handles Dragging the handles in each mode also works. Dragging the top-centre handle onto the centre squashes the arc flat, but it stays visible and selectable. The arc's handle code was rewritten after r4736, which probably fixed this. If you still see it on a recent build, please reopen with the version you used. |
| 2016-10-12 18:32 | Morganol | New Issue | |
| 2016-10-12 18:32 | Morganol | File Added: 1-ARC_selected-green_handles.png | |
| 2016-10-12 18:32 | Morganol | File Added: 2_B-ARC_vanished_by_clicking_top_center_green_handle-handles_at_down_left.png | |
| 2016-10-12 18:33 | Morganol | File Added: 3_C1-ARC_selected-green_handle_at_middle_left_is_clicked.png | |
| 2016-10-12 18:33 | Morganol | File Added: 4_C2-ARC_invisible_after_clicking_its_lower_left.png | |
| 2021-02-15 00:45 |
| 2021-02-15 00:49 |
Severity | crash => block |
| 2021-02-15 00:51 |
| 2026-10-01 02:27 | ispyisail | Note Added: 0000916 | |
| 2026-10-01 02:27 | ispyisail | Status | new => resolved |
| 2026-10-01 02:27 | ispyisail | Resolution | open => fixed |
