| 0000101 | QElectroTech | website | public | 2016-10-12 18:32 | 2021-02-15 00:51 |
| Priority | normal | Severity | block | Reproducibility | always |
| Platform | Qt5.6.1, kf5.27.0, Plasma5.8.1, | OS | Linux 4.7.8, gcc 5.4.0, | OS Version | Mageia 6 |
| Summary | 0000101: Crash and other issues when editing an arc * REPEATABLE * | ||||
| Description | r4736 See Steps To Reproduce | ||||
| Steps To Reproduce | § Create a new element § In that element create an arc, start down-left, end up-right § ESC out of arc tool § Select the arc, so handles are green (problem do not appear when handles are blue) Screenshot 1-ARC_selected-green_handles.png § Then either: A) § click the top left green handle => segmentation fault In Dissassembler QVariant::clear() at line 2: 0x7ffff6e47b41 <+0x0001> f6 47 0b 40 testb $0x40,0xb(%rdi) (unfortunately no source?) B) § click the top center handle ( = arc up-right end) => screenshot 2_B-ARC_vanished_by_clicking_top_center_green_handle-handles_at_down_left.png § arc vanishes from sight § one strange handle appear where lower left end was § I can not select anything in the area - it is gone § also after making a label "label", saving, reopen: it is gone C) § click the middle left handle => only arc is visible, with end handles (OK) screenshot 3_C1-ARC_selected-green_handle_at_middle_left_is_clicked.png § click lower left end handle => arc gets invisible! screenshot 4_C2-ARC_invisible_after_clicking_its_lower_left.png § I can still drag its size by handles § I can select properties such as strong, filled, dashed, etc - still invisible § I can click somewhere else, and then select it again by click-dragging over the area § after making a label "label", saving, reopen: it is still there but invisible ( - and at another location = where i put the label...) § it is also invisible when i put it in the schematic Side note: Editor do not crash from usong symbols generated in B and C above, and then saving shematic. | ||||
| Attached Files | |||||
| 2016-10-12 18:32 | Morganol | New Issue | |
| 2016-10-12 18:32 | Morganol | File Added: 1-ARC_selected-green_handles.png | |
| 2016-10-12 18:32 | Morganol | File Added: 2_B-ARC_vanished_by_clicking_top_center_green_handle-handles_at_down_left.png | |
| 2016-10-12 18:33 | Morganol | File Added: 3_C1-ARC_selected-green_handle_at_middle_left_is_clicked.png | |
| 2016-10-12 18:33 | Morganol | File Added: 4_C2-ARC_invisible_after_clicking_its_lower_left.png | |
| 2021-02-15 00:45 |
| 2021-02-15 00:49 |
Severity | crash => block |
| 2021-02-15 00:51 |
