| 0000074 | QElectroTech | website | public | 2015-11-12 20:33 | 2021-02-15 00:52 |
| Reporter | firewalker | Assigned To | scorpio810_mantis | ||
| Priority | high | Severity | crash | Reproducibility | always |
| Platform | GNU/Linux | OS | Archlinux | ||
| Summary | 0000074: Segmentation fault upon launching 0.5-rc1 | ||||
| Description | While I can sucessfully build Qelectrotech under Archlinux, it willl segfault upon launching.
libpng warning: iCCP: known incorrect sRGB profile | ||||
| Additional Information | (gdb) backtrace #0 0x00000000 in ?? () 0000001 0xb79e0f81 in QMenu::actionEvent(QActionEvent*) () from /usr/lib/libQt5Widgets.so.5 0000002 0xb7892cfa in QWidget::event(QEvent*) () from /usr/lib/libQt5Widgets.so.5 0000003 0xb79e798a in QMenu::event(QEvent*) () from /usr/lib/libQt5Widgets.so.5 0000004 0xb784ac6a in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/libQt5Widgets.so.5 0000005 0xb7850330 in QApplication::notify(QObject*, QEvent*) () from /usr/lib/libQt5Widgets.so.5 0000006 0xb6d2a8cf in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/libQt5Core.so.5 0000007 0xb78891c9 in QWidget::insertAction(QAction*, QAction*) () from /usr/lib/libQt5Widgets.so.5 0000008 0xb788933e in QWidget::addAction(QAction*) () from /usr/lib/libQt5Widgets.so.5 0000009 0x081316b5 in ?? () 0000010 0x081362f4 in ?? () 0000011 0x0807d4c9 in ?? () 0000012 0xb6744497 in __libc_start_main () from /usr/lib/libc.so.6 0000013 0x08084aa5 in ?? () | ||||
I forgot to mention that I am using Qt 5.5.1, and that it segfaults while showing the start-up screen. It says Loading... Folios editor. |
The problem is with function buildSystemTrayMenu(); in qetapp.cpp file, line 127.
Program received signal SIGSEGV, Segmentation fault. |
<div>libpng warning: iCCP: known incorrect sRGB profile</div> <div>libpng warning: iCCP: too many profiles</div> <div>libpng warning: iCCP: too many profiles</div> <div>libpng warning: iCCP: too many profiles</div> <div></div> <div>Strange warning for Qet!</div> |
Mainstream problem, not upstream. |
| 2015-11-12 20:33 | firewalker | New Issue | |
| 2015-11-14 12:46 | firewalker | Note Added: 0000127 | |
| 2015-11-14 14:11 | firewalker | Note Added: 0000128 | |
| 2015-11-14 21:38 | scorpio810_mantis | Note Added: 0000129 | |
| 2016-01-02 19:13 | scorpio810_mantis | Note Added: 0000131 | |
| 2016-01-02 19:13 | scorpio810_mantis | Status | new => resolved |
| 2016-01-02 19:13 | scorpio810_mantis | Resolution | open => fixed |
| 2016-01-02 19:13 | scorpio810_mantis | Assigned To | => scorpio810_mantis |
| 2016-05-14 01:52 | scorpio810_mantis | Status | resolved => closed |
| 2021-02-15 00:52 |
