| 0000029 | QElectroTech | website | public | 2009-09-13 15:21 | 2021-02-15 00:51 |
| Reporter | xavier | Assigned To | xavier | ||
| Platform | i386 | OS | Windows XP + Qt 4.5.2 | ||
| Summary | 0000029: Crash après avoir double-cliquer sur un onglet | ||||
| Description | L'application se plante (Segmentation Fault) après avoir double-cliquer sur un onglet. | ||||
| Steps To Reproduce | Lancer QElectroTech - on obtient alors un projet par défaut avec un schéma Double-cliquer sur l'onglet du schéma - le dialogue d'édition des propriétés du schéma apparaît alors Faire annuler Double-cliquer à nouveau L'application devrait se crasher | ||||
| Additional Information | Ce bug ne semble se produire que sous Windows avec Qt 4.5.2. BackTrace : #0 0x01cc2b15 in QTabBarPrivate::_q_moveTabFinished (this=0x82c3e58, index=0) at widgets/qtabbar.cpp:1847 0000001 0x01cc1b44 in QTabBar::mousePressEvent (this=0x82c3e18, event=0x22c28c) at widgets/qtabbar.cpp:1699 0000002 0x004fbbe7 in QETTabBar::mousePressEvent (this=0x82c3e18, event=0x22c28c) at sources/qettabbar.cpp:163 0000003 0x018080c9 in QWidget::event (this=0x82c3e18, event=0x22c28c) at kernel/qwidget.cpp:7545 0000004 0x01cc052a in QTabBar::event (this=0x82c3e18, event=0x22c28c) at widgets/qtabbar.cpp:1453 0000005 0x017a85c7 in QApplicationPrivate::notify_helper (this=0x3e76c8, receiver=0x82c3e18, e=0x22c28c) at kernel/qapplication.cpp:4056 0000006 0x017a702e in QApplication::notify (this=0x22fd50, receiver=0x82c3e18, e=0x22c28c) at kernel/qapplication.cpp:3758 0000007 0x6a2427ac in QCoreApplication::notifyInternal (this=0x22fd50, receiver=0x82c3e18, event=0x22c28c) at kernel/qcoreapplication.cpp:610 0000008 0x01f58414 in QCoreApplication::sendSpontaneousEvent (receiver=0x82c3e18, event=0x22c28c) at ../../include/QtCore/../../src/corelib/kernel/qcoreapplication.h:216 0000009 0x017a5369 in QApplicationPrivate::sendMouseEvent (receiver=0x82c3e18, event=0x22c28c, alienWidget=0x82c3e18, nativeWidget=0x69b7458, buttonDown=0x218039c, lastMouseReceiver=@0x21803a0) at kernel/qapplication.cpp:2924 0000010 0x0181efcd in QETWidget::translateMouseEvent (this=0x69b7458, msg=@0x22db0c) at kernel/qapplication_win.cpp:3262 0000011 0x01818f0f in QtWndProc (hwnd=0x30290, message=513, wParam=1, lParam=5505349) at kernel/qapplication_win.cpp:1667 0000012 0x7e398734 in USER32!GetDC () from C:\WINDOWS\system32\user32.dll 0000013 0x00030290 in operator+ () 0000014 0x00000201 in ?? () 0000015 0x00000001 in ?? () 0000016 0x00540145 in PartLine::toXml (this=0x30290, xml_document=@0x201) at sources/editor/partline.cpp:168 0000017 0x7e398816 in USER32!GetDC () from C:\WINDOWS\system32\user32.dll 0000018 0x018182ba in qt_is_translatable_mouse_event (message=0) at kernel/qapplication_win.cpp:1439 0000019 0x7e3989cd in USER32!GetWindowLongW () from C:\WINDOWS\system32\user32.dll 0000020 0x00000000 in ?? () Malgré le passage par une méthode de la classe QETTabBar, il semble bien s'agir d'un bug dans la biliothèque QtGui4. | ||||
Le bug semble avoir été déjà repéré, notamment au sein du projet KDE : * http://osdir.com/ml/kde-bugs-dist/2009-09/msg02277.html * http://osdir.com/ml/kde-bugs-dist/2009-09/msg00661.html * http://reviewboard.kde.org/r/1017/ D'après ce dernier lien, cela serait dû à une certaine confusion entre bouton gauche et bouton du milieu de la souris. Après test, il est possible de ne pas provoquer le crash en utilisant le clic droit (ou le bouton du milieu, mais c'est moins pratique) sur les onglets. Exemple : pour éditer les propriétés du schéma en cours, double-cliquer avec le bouton droit sur l'onglet. |
Le bug semble corrigé sous Qt 4.5.3. Les builds Windows utilisent Qt 4.5.3 à partir de la révision 755 ; sinon il est possible de simplement remplacer les dll de Qt 4.5.2 par celles de Qt 4.5.3. |
| 2009-09-13 15:21 | xavier | New Issue | |
| 2009-09-13 15:21 | xavier | Status | new => assigned |
| 2009-09-13 15:21 | xavier | Assigned To | => xavier |
| 2009-09-13 15:36 | xavier | Note Added: 0000050 | |
| 2009-10-01 21:49 | xavier | Note Added: 0000052 | |
| 2009-10-01 21:49 | xavier | Status | assigned => closed |
| 2009-10-01 21:49 | xavier | Resolution | open => fixed |
| 2009-10-01 21:49 | xavier | Fixed in Version | => 0.21 |
| 2013-06-09 14:06 | scorpio810_mantis | Category | Éditeur d'éléments => Symbol editor |
| 2013-06-09 14:11 | scorpio810_mantis | Category | Symbol editor => Element Editor |
| 2021-02-15 00:51 |
