winstatic:winstatic [27/08/2020 13:40] – scorpio810 | winstatic:winstatic [28/08/2020 08:58] – scorpio810 | ||
Ligne 2: | Ligne 2: | ||
(Preliminary) | (Preliminary) | ||
- | Today (2020-08-27) I managed to successfully create a static Windows build. | + | Today (2020-08-27) I // |
Here is a partial description of the final path I took.\\ | Here is a partial description of the final path I took.\\ | ||
Ligne 17: | Ligne 17: | ||
-- Download installer [[https:// | -- Download installer [[https:// | ||
- | == 2. Install build environment with pacman | + | == 2. Install build environment with pacman (" |
- | | + | [[https:// |
+ | <code bash> | ||
+ | pacman -Syuu | ||
+ | pacman -S package_name | ||
Or install packages as required during attempted builds! | Or install packages as required during attempted builds! | ||
== 3. Install Qt5 Static build == | == 3. Install Qt5 Static build == | ||
- | pacman -S mingw-w64-x86_64-qt5-static | + | <code bash> |
+ | pacman -S mingw-w64-x86_64-qt5-static | ||
== 4. Install the extras required for Qet, kcoreaddons and kwidgetaddons == | == 4. Install the extras required for Qet, kcoreaddons and kwidgetaddons == | ||
Ligne 32: | Ligne 38: | ||
Fire up your Msys64 shell and: | Fire up your Msys64 shell and: | ||
- | + | <code bash> | |
- | | + | git clone https:// |
- | | + | cd MINGW-packages |
- | | + | cd mingw-w64-kcoreaddons-qt5 |
- | | + | KF5_VARIANT=static MINGW_INSTALLS=mingw64 makepkg-mingw -sLf |
- | | + | pacman -U mingw-w64-x86_64-kcoreddons-qt5-static-5.68.0-1-any.pkg.tar.zst |
- | | + | cd .. |
- | | + | cd cd mingw-w64-kwidgetsaddons-qt5 |
- | | + | pacman -U mingw-w64-x86_64-kwidgetsaddons-qt5-static-5.68.0-1-any.pkg.tar.zst |
== 5. Clone the qelectrotech main or mirror repo if not already done == | == 5. Clone the qelectrotech main or mirror repo if not already done == | ||
+ | git clone git:// | ||
Details to be added: | Details to be added: | ||
Ligne 54: | Ligne 62: | ||
Attempt a build from qtcreator (which fails for me) (static, release only. debug is HUGE!)\\ | Attempt a build from qtcreator (which fails for me) (static, release only. debug is HUGE!)\\ | ||
cd to the build directory where the qtcreator build failed\\ | cd to the build directory where the qtcreator build failed\\ | ||
- | mingw32-make | + | <code bash> |
+ | mingw32-make | ||
Which (for me) succeeds, despite appearing to run exactly the same commands that failed from qtcreator!\\ | Which (for me) succeeds, despite appearing to run exactly the same commands that failed from qtcreator!\\ | ||
The whole install/ | The whole install/ | ||
