roadmap [31/12/2022 18:22] – [Todo] scorpio810 | roadmap [02/06/2023 07:17] – [Todo] scorpio810 |
* <del>Try to add sqlite3 lib for macOS bundle package </del>[[https://forum.qt.io/topic/122601/sqlite-proper-method-for-calling-sqlite3-directly/18]] need to rebuild Qt 5.X WTF! [[https://gitee.com/dongege/sqlitebrowser/blob/master/BUILDING.md]] [[https://stackoverflow.com/questions/26557293/mac-app-requires-newer-version-of-sqlite-but-uses-the-old-one]] | * <del>Try to add sqlite3 lib for macOS bundle package Arm64 with Homebrew[[https://forum.qt.io/topic/122601/sqlite-proper-method-for-calling-sqlite3-directly/18]] need to rebuild Qt 5.X WTF! [[https://gitee.com/dongege/sqlitebrowser/blob/master/BUILDING.md]] [[https://stackoverflow.com/questions/26557293/mac-app-requires-newer-version-of-sqlite-but-uses-the-old-one]] [[https://givan.se/build-test-deploy-bitcoin-on-monterey/]] [[https://www.reddit.com/r/QtFramework/comments/f812we/macosx_private_api_sqlite/]] |
* Port to Apple Silicon -> [[https://trac.macports.org/ticket/61999|How to cross compile Apple Silicon target under Intel Apple computer ?]] | * Avoir la possibilité d'afficher le numéro de conducteur sur chaque extrémité de celui-ci https://qelectrotech.org/forum/viewtopic.php?id=2447</del> |
| ===== 0.90 ===== |
