roadmap [19/07/2020 21:58] – [Todo] scorpio810 | roadmap [30/12/2022 08:43] – [Todo] scorpio810 | ||
Ligne 27: | Ligne 27: | ||
- | * E/S automate | + | * E/S automate |
* Pile d' | * Pile d' | ||
Ligne 37: | Ligne 37: | ||
- | * Éditeur d' | ||
Ligne 45: | Ligne 44: | ||
+ | <todo #> * Try to add sqlite3 lib for macOS bundle package [[https:// | ||
+ | ===== 0.80 ===== | ||
+ | https:// | ||
+ | https:// | ||
