roadmap [12/05/2020 11:50] – [Todo] black_sun_2012 | roadmap [02/06/2023 07:17] – [Todo] scorpio810 | ||
Ligne 24: | Ligne 24: | ||
- | | + | * E/S automate |
* Pile d' | * Pile d' | ||
Ligne 39: | Ligne 37: | ||
- | * Éditeur d' | ||
+ | ===== 0.90 ===== | ||
+ | https:// | ||
+ | https:// | ||
+ | https:// | ||
+ | ===== 0.80 ===== | ||
+ | https:// | ||
+ | https:// | ||
