Differences
Link to this comparison view
Next revision
Previous revision
en:doc:test_dev_version [09/10/2009 08:00] xavieren:doc:test_dev_version [20/11/2014 14:01] (current) – external edit 127.0.0.1
Line 1: Line 1:
 +======Testing the development version of QElectroTech ======
 +===== Step 1: install the Qt 4.4 library =====
 +QElectroTech uses the OpenSource edition of the Qt 4.4 library.
 +==== Under Windows ====
 +Go to [[http://www.trolltech.com/developer/downloads/qt/windows|that page]] and download the file "qt-win-opensource-4.4.0-mingw.exe". This file allows you to install a C++ compiler, the headers of the Qt 4.3 library (*.h) and the binaries (*.dll, *.a, utilities,...). The installation process is quite straightforward. Make sure that the environment variable PATH has the path to the following directories:
 +  * the MinGW compiler: C:\MinGW\bin
 +  * the Qt utilities: C:\Qt\4.4.0\bin
 +To change your environment variables, go to Start > System > Advanced (a tab) > Environment variables (a button). Edit the PATH variable for your user. Reboot if necessary.
 +If it works, open a prompt (Start > Launch > write 'cmd' and validate) and type: qmake -v. You should get this (or something similar):
 +<code>QMake version 2.01a
 +Using Qt version 4.4.0 in C:\Qt\4.4.0\lib</code>
 +Another test: type mingw32-make. You should see:
 +<code>mingw32-make: *** No targets specified and no makefile found.  Stop.</code>
 +At that stage, you have successfully installed the Qt library.
 +==== Under Debian Lenny/Sid ====
 +Qt 4.4 is available in Debian repositories:
 +apt-get install libqt4-core libqt4-dev libqt4-gui
 +==== Under other Linux/Unix ====
 +If the package system of your system does not provide Qt 4.4, you should compile it yourself. Go to [[http://www.trolltech.com/developer/downloads/qt/x11|that page]] and download the file "qt-x11-opensource-src-4.4.0.tar.gz".
 +Piece of advice: Install the X libraries headers (already installed under some systems like Slackware and PC-BSD).
 +<code bash>
 +# Archive decompression
 +tar xzvf qt-x11-opensource-src-4.4.0.tar.gz
 +# Compilation configuration
 +cd qt-x11-opensource-src-4.4.0
 +./configure
 +# compilation
 +make
 +# installation: switch to root (su) for this last stage
 +make install
 +Edit also your environment variable PATH in order to include the Qt binaries directory (typically: /usr/local/Trolltech/Qt-4.4.0/bin):
 +<code bash>
 +export PATH="/usr/local/Trolltech/Qt-4.4.0/bin:${PATH}"
 +===== Step 2: download the QElectroTech sources=====
 +==== With Subversion (SVN): ====
 +If you already know [[subversion|Subversion]] (or even CVS), you should be familiar with that:
 +<code bash>
 +# version 0.2 official
 +svn export svn://svn.tuxfamily.org/svnroot/qet/qet/tags/0.2 qelectrotech
 +# trunk (version 0.2 + some improvements)
 +svn export svn://svn.tuxfamily.org/svnroot/qet/qet/trunk qelectrotech
 +# branche 0.3 (experimentations version 0.3)
 +svn export svn://svn.tuxfamily.org/svnroot/qet/qet/branches/0.3 qelectrotech
 +Subversion is a version control system, i.e. a tool that allows you to keep track of all changes that have been done to the sources during the development of the project. These commands allow to extract different 'snapshots' of the development. **We recommend you to use the trunk**. Indeed, we try to keep the trunk as stable as possible, in contrast with the 0.3 branch. Moreover, the trunk brings some small improvements and bug fixes since the official 0.2 version.
 +If you plan to recompile QET on a regular basis, substitute co to export (for checkout). That will enable you to update your sources with svn up. You should however remove the directory .svn (or after, but in the installation direcory) before doing a 'make install', using e.g. the command:
 +<code bash>find elements/ -name .svn -type d -print | xargs rm -rf</code>
 +==== Other method: ====
 +It is possible to easily extract the source of Subversion repository in the form of an archive with the tool [[http://svnweb.tuxfamily.org/listing.php?repname=qet/qet|WebSVN]].
 +Load and decompress the desired archive:
 +  * [[http://svnweb.tuxfamily.org/dl.php?repname=qet/qet&amp;path=%2Ftags%2F0.2%2F&amp;rev=0&amp;isdir=1|qelectrotech-0.2.tar.gz]]
 +  * [[http://svnweb.tuxfamily.org/dl.php?repname=qet/qet&amp;path=%2Ftrunk%2F&amp;rev=0&amp;isdir=1|qelectrotech-trunk.tar.gz]]
 +  * [[http://svnweb.tuxfamily.org/dl.php?repname=qet/qet&amp;path=%2Fbranches%2F0.3%2F&amp;rev=0&amp;isdir=1|qelectrotech-0.3.tar.gz]]
 +===== Stage 3: compile and launch QElectroTech =====
 +Open a command prompt:
 +# go to the appropriate directory (there is a *.pro in the name), e.g.:
 +cd /d C:\dossier\autredossier\trunk
 +# generate the Makefile
 +qmake
 +# compile
 +mingw32-make
 +# set up the executable files
 +move /Y release\qelectrotech.exe .
 +copy "misc\Lancer QET.bat" .
 +# run QET
 +"Launch QET.bat"
 +==== Under Debian-based distributions ====
 +The method is the same than the other Linux/UNIX. There is only one difference: the utility qmake is probably named qmake-qt4 (that can be very confusing, if you were wrong, do a 'rm Makefile' and check with 'qmake -v').
 +<code bash>
 +# go to the appropriate directory (ther is *.pro in the name)
 +cd qelectrotech
 +# generate le Makefile
 +qmake
 +# compile
 +make -f Makefile.Release
 +# installation
 +make -f Makefile.Release install
 +# execute QET
 +qelectrotech
 +After that you should be able to test QElectroTech. Do not hesitate to contact us for a bug, a suggestion, or what ever..
Print/export
