Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
en:doc:changelog_0.22_0.3a [12/05/2012 20:24] – [Element editor] xavier | en:doc:changelog_0.22_0.3a [20/11/2014 14:01] (current) – external edit 127.0.0.1 | ||
Line 1: | Line 1: | ||
+ | ====== ChangeLog from 0.22 to 0.3a ====== | ||
+ | Note: this page aims at providing a summary of all modifications from version 0.22 to version 0.3a of QElectroTech. | ||
+ | ===== Application ===== | ||
+ | * Elements collection: QElectroTech now provides **1465 elements** within 233 categories (0.22 provided **153** elements within 51 categories). Most elements are related to electricity though some relate to chillers, solar, hydraulic and pneumatic | ||
+ | * A new kind of collections appeared to store title block templates; as for elements, there is a distinction between common (system-wide) templates and custom (user-wide) templates. | ||
+ | * Translations: | ||
+ | * English, Spanish, French, Portuguese and Czech translations have been maintained. | ||
+ | * Russian translations have been removed because they are not maintained anymore. | ||
+ | * Polish, German, Italian, Arabic and Croatian translations have been added. | ||
+ | * Following translation to Arabic, some work was done to improve Right-To-Left languages support. | ||
+ | * Elements names are fully translated to English, French, Czech and Polish. | ||
+ | * Main windows: added a " | ||
+ | * QElectroTech now handles *.titleblock files. | ||
+ | ===== Diagram editor ===== | ||
+ | * It is now possible to move and rotate all texts on a diagram : element texts, conductor texts and independent texts. | ||
+ | * When moving a text related to an electrical element, this element is highlighted. | ||
+ | * Texts related to a conductor cannot be moved too far away from it. | ||
+ | * It is now possible to create diagrams with more than 100 rows/ | ||
+ | * Elements panel: | ||
+ | * During a drag and drop operation, the hovered item is now expanded after a short time not moving the mouse. | ||
+ | * Items are now expanded/ | ||
+ | * Common, custom and embedded collections of title block templates are displayed within the elements panel. | ||
+ | * Elements previews and names are now cached into a SQLite database stored in the user configuration directory, thus speeding up the elements panel (re)loading | ||
+ | * The elements panel now displays the folio index before each diagram title. | ||
+ | * UI consistency: | ||
+ | * Freshly integrated elements are now highlighted in the elements panel -- this behaviour can be disabled though. | ||
+ | * When clearing the search field, the panel state is restored to its previous state. | ||
+ | * Title blocks are now rendered using // | ||
+ | * For each diagram, users can choose the template to be used in the diagram properties. | ||
+ | * They may also drag and drop it from the elements panel to the diagram. | ||
+ | * Title block templates are always integrated within the parent project. | ||
+ | * Fixed a bug in the print preview dialog. | ||
+ | * Added a F2 shortcut for the widget "Edit the color of the given conductor" | ||
+ | * As elements, diagrams now have a " | ||
+ | * Better handling of file opening for documents saved with newer versions of QElectroTech. | ||
+ | * Diagram loading: removed an optimization that could lead to conductors not being loaded when several terminals share the same coordinates. | ||
+ | * Users may now enter visualisation mode by pressing Ctrl and Shift. | ||
+ | * Printing: when printing diagrams with no title block, use the space left by the title block. | ||
+ | * Added a few status and " | ||
+ | * Got rid of the green icon used for projects, changed a few other icons. | ||
+ | ===== Element editor ====== | ||
+ | * Both static and dynamic texts can now be rotated | ||
+ | * Added " | ||
+ | * Added white color for texts | ||
+ | * Newly added parts are placed above existing ones. | ||
+ | ===== Title block template editor ===== | ||
+ | A third kind of editor was implemented so users can create their own title block templates: | ||
+ | * It allows users to customize the layout and content of cells that constitute the title block. | ||
+ | * Cells can be merged and splitted. | ||
+ | * Their width can be fixed, relative to the total width or relative to the remaining widths. | ||
+ | * Their height is a simple fixed length. | ||
+ | * They contain either a logo (be it in SVG or a usual bitmap format) or some text. | ||
+ | * The text value is optionally preceded by a label. | ||
+ | * As other texts within QElectroTech, | ||
+ | * Texts and labels may contain variables (e.g. %company-name); | ||
+ | * Those real-world values can be set among the diagram properties. | ||
