doc:install_ubuntu [17/09/2018 00:01] – [Installation] scorpio810 | doc:install_ubuntu [09/04/2020 17:25] – [Dépôt PPA version de la version 0.7-dev] scorpio810 | ||
+ | [[https:// | ||
+ | [[http:// | ||
+ | ==== Ajout du dépôt PPA de la version 0.6==== | ||
+ | L' | ||
+ | laurent@debian: | ||
+ | Pin: version 0.60.* | ||
+ | Pin-Priority: | ||
+ | ==== Dépôt PPA version de la version 0.8-dev ==== | ||
+ | https:// | ||
+ | Upgrade du pinning : | ||
+ | sudo sed -i ' | ||
