doc:install_ubuntu [15/10/2017 22:25] – [Ajout du dépôt PPA] scorpio810 | doc:install_ubuntu [13/05/2022 14:00] – [Ajout du dépôt PPA de la version 0.6] scorpio810 | ||
+ | [[https:// | ||
+ | [[http:// | ||
+ | L' | ||
+ | laurent@debian: | ||
+ | Pin: version 0.60.* | ||
+ | Pin-Priority: | ||
+ | ==== Dépôt PPA version de la version 0.9-dev ==== | ||
+ | https:// | ||
+ | Upgrade du pinning : | ||
+ | sudo sed -i ' | ||
