doc:install_debian [20/12/2015 21:58] – [Debian Jessie , Ubuntu (15.10)] scorpio810 | doc:install_debian [28/08/2023 13:11] (Version actuelle) – scorpio810 | ||
+ | Ou | ||
+ | ==== Debian Stable | ||
+ | ==== Debian Sid ==== | ||
+ | Debian unstable/ | ||
+ | qelectrotech: | ||
+ | Table de version : | ||
+ | 500 [url]http:// | ||
+ | 100 / | ||
+ | L' | ||
+ | laurent@debian: | ||
+ | Pin: version 0.100.* | ||
+ | Pin-Priority: | ||
+ | # echo -e ' | ||
+ | Now remove in / | ||
+ | And old key: | ||
