doc:install_debian [16/05/2025 10:08] – [Debian pinning] scorpio810doc:install_debian [20/06/2025 16:04] (Version actuelle) – [Debian Stable] scorpio810
Ligne 4: Ligne 4:
-===== Installation de la version 0.90 en cours de développement  =====+===== Installing version 0.100 under development  =====
 :!: Note: Most of the operations presented below must be carried out in a terminal. :!: Note: Most of the operations presented below must be carried out in a terminal.
Ligne 11: Ligne 11:
 download key-file: download key-file:
-[code]wget -q https://debian.qelectrotech.org/qet/builds/debian/Qelectrotech_Repository.asc[/code]+<code
 +su -
 +cd /etc/apt/keyrings
 +wget -q https://debian.qelectrotech.org/qet/builds/debian/Qelectrotech_Repository.asc</code>
 and save (as root) to /etc/apt/keyrings and save (as root) to /etc/apt/keyrings
Ligne 17: Ligne 20:
-==== Step 3: Add the repository to your sources.list ====+==== Step 2: Add the repository to your sources.list ====
 ==== Debian Stable  ==== ==== Debian Stable  ====
Ligne 23: Ligne 26:
 file needs the ending ".sources" as in this example: file needs the ending ".sources" as in this example:
-/etc/apt/sources.list.d/qelectrotech.sources+<code> nano /etc/apt/sources.list.d/qelectrotech.sources</code>
 content of /etc/apt/sources.list.d/qelectrotech.sources: content of /etc/apt/sources.list.d/qelectrotech.sources:
Ligne 67: Ligne 70:
-==== Debian pinning ====+==== Step 3: Debian pinning ====
Ligne 73: Ligne 76:
 [04:18:09] laurent@debian:~$ apt-cache policy qelectrotech [04:18:09] laurent@debian:~$ apt-cache policy qelectrotech
 qelectrotech: qelectrotech:
-  Installé : 0.50.r4018-1 +  Installé : 0.100.0.r8447-1
-  Candidat : 0.50.r4025-1 +  Candidat : 0.100.0.r8447-1
-  Épinglage de paquet : 0.50.r4025-1 + Table de version
- Table de version +     1:0.9-3 500
-     1:0.4-2 1001 +        500 http://ftp.fr.debian.org/debian unstable/main amd64 Packages
-        500 [url]http://ftp.fr.debian.org/debian/[/url] sid/main amd64 Packages +        500 http://deb.debian.org/debian unstable/main amd64 Packages
-     0.50.r4025-1 1001 + *** 0.100.0.r8447-1 1001
-        500 [url]http://debian.qelectrotech.org/qet/builds/debian/[/url] unstable/main amd64 Packages +        500 https://debian.qelectrotech.org/qet/builds/debian unstable/main amd64 Packages
- *** 0.50.r4018-1 1001+
-     0.22+svn897-1.1 1001 +
-        500 [url]http://ftp.fr.debian.org/debian/[/url] stable/main amd64 Packages+
 </code>      </code>
-L'entrée suivante affecte une priorité haute à toutes les versions du paquet QElectroTech dont le numéro de version commence par 0.100. : +The following entry assigns high priority to all versions of the QElectroTech package whose version number begins with 0.100.:
 <code> <code>
Ligne 132: Ligne 133:
 === NO_PUBKEY BC9F825E1D4FB6C1 - Download for Debian Bookworm ===  === NO_PUBKEY BC9F825E1D4FB6C1 - Download for Debian Bookworm ===
 see :https://qelectrotech.org/forum/viewtopic.php?id=2867 see :https://qelectrotech.org/forum/viewtopic.php?id=2867
