| doc:install_debian [06/05/2022 14:50] – [Debian pinning] scorpio810 | doc:install_debian [20/06/2025 16:04] (Version actuelle) – [Debian Stable] scorpio810 | ||
| Ligne 1: | Ligne 1: | ||
| - | ====== Installation de QElectroTech | + | ====== Installation de QElectroTech |
| - | ===== Installation de la version 0.90 en cours de développement | + | ===== Installing |
| - | :!: Note : la plupart des manipulations présentées ci-dessous sont à effectuer dans un terminal. | + | :!: Note: Most of the operations presented below must be carried out in a terminal. |
| - | ==== Clé du dépôt apt ==== | + | |
| + | ==== Apt repository key ==== | ||
| + | download key-file: | ||
| - | $ gpg --keyserver pgpkeys.mit.edu --recv-key 1D4FB6C1 | + | su - |
| - | $ gpg -a --export 1D4FB6C1 | sudo apt-key add - | + | cd / |
| - | </ | + | wget -q https:// |
| - | Ou | + | and save (as root) to / |
| - | [code]wget -q -O - http:// | ||
| - | On vérifie par la commande | ||
| - | [code]sudo apt-key | + | ==== Step 2: Add the repository to your sources.list ==== |
| + | ==== Debian Stable | ||
| + | adjust sources-list entry for QElectroTech | ||
| + | file needs the ending " | ||
| - | + | content of /etc/apt/sources.list.d/ | |
| - | ==== Step 3 : ajouter le dépôt à votre sources.list | + | |
| - | ==== Debian Stable | + | |
| - | Debian 10, nom de code Buster | + | |
| + | # draw electric diagrams with QElectroTech | ||
| + | Types: | ||
| + | URIs: | ||
| + | Suites: | ||
| + | Components: main | ||
| + | Enabled: | ||
| + | Signed-By: | ||
| - | sudo apt-add-repository 'deb http:// | ||
| ==== Debian Sid ==== | ==== Debian Sid ==== | ||
| - | Debian unstable/testing | + | adjust sources-list entry for QElectroTech |
| + | /etc/ | ||
| + | content of / | ||
| - | sudo apt-add-repository 'deb http:// | + | # draw electric diagrams with QElectroTech |
| + | Types: | ||
| + | URIs: https:// | ||
| + | Suites: | ||
| + | Components: | ||
| + | Enabled: | ||
| + | Signed-By: | ||
| Ligne 48: | Ligne 65: | ||
| - | Il convient ensuite de mettre à jour son cache : < | + | You should then update your cache: < |
| - | ==== Step 4 : installation ==== | ||
| - | < | + | ==== Step 3: Debian pinning ==== |
| - | Voilà, QElectroTech devrait désormais être installé. Vous pouvez le lancer via la commande “qelectrotech”. \\ Pour le peu que votre environnement de bureau respecte les standards FreeDesktop.org, | + | |
| - | ==== Debian pinning ==== | + | |
| Ligne 65: | Ligne 76: | ||
| [04:18:09] laurent@debian: | [04:18:09] laurent@debian: | ||
| qelectrotech: | qelectrotech: | ||
| - | Candidat : 0.50.r4025-1 | + | |
| - | | + | Table de version : |
| - | Table de version | + | 1:0.9-3 500 |
| - | 1:0.4-2 1001 | + | 500 http:// |
| - | 500 [url]http:// | + | 500 http:// |
| - | | + | *** 0.100.0.r8447-1 1001 |
| - | 500 [url]http:// | + | 500 https:// |
| - | *** 0.50.r4018-1 1001 | + | |
| 100 / | 100 / | ||
| - | 500 [url]http:// | + | |
| - | L' | + | The following entry assigns high priority to all versions |
| laurent@debian: | laurent@debian: | ||
| Package: qelectrotech* | Package: qelectrotech* | ||
| - | Pin: version 0.90.* | + | Pin: version 0.100.* |
| Pin-Priority: | Pin-Priority: | ||
| + | As root | ||
| - | # echo -e ' | + | # echo -e ' |
| + | With sudo | ||
| + | echo -e ' | ||
| + | ==== Step 4 : installation ==== | ||
| + | That's it, QElectroTech should now be installed. You can launch it using the " | ||
| + | Provided your desktop environment complies with FreeDesktop.org standards, \\ | ||
| + | QET should also appear in its menus, and .qet and .elmt files should open by default in QElectroTech. | ||
| Ligne 102: | Ligne 124: | ||
| sudo apt-key export 1D4FB6C1 | sudo gpg --dearmour -o / | sudo apt-key export 1D4FB6C1 | sudo gpg --dearmour -o / | ||
| - | echo "deb [signed-by=/ | + | echo "deb [signed-by=/ |
| Now remove in / | Now remove in / | ||
| + | And old key: | ||
| + | === NO_PUBKEY BC9F825E1D4FB6C1 - Download for Debian Bookworm === | ||
| + | === NO_PUBKEY B8D8B0B00ADD2851 === | ||
| + | see : | ||
