doc:install_debian [01/10/2018 01:07] – [Step 4 : installation] scorpio810doc:install_debian [02/02/2026 17:14] (Version actuelle) – [Step 3: Debian pinning] scorpio810
 +====== Installation de QElectroTech on Debian ======
 +{{:doc:logo_debian.png|}} This document describes the procedure to follow to install the current development version (0.100) of QElectroTech under Debian GNU/Linux.
 +===== Installing version 0.100 under development  =====
 +:!: Note: Most of the operations presented below must be carried out in a terminal.
 +==== Apt repository key ====
 +download key-file:
 +su -
 +cd /etc/apt/keyrings
 +wget -q https://debian.qelectrotech.org/qet/builds/debian/Qelectrotech_Repository.asc</code>
 +and save (as root) to /etc/apt/keyrings
 +==== Step 2: Add the repository to your sources.list ====
 +==== Debian Stable  ====
 +adjust sources-list entry for QElectroTech
 +file needs the ending ".sources" as in this example:
 +<code> nano /etc/apt/sources.list.d/qelectrotech.sources</code>
 +content of /etc/apt/sources.list.d/qelectrotech.sources:
 +# draw electric diagrams with QElectroTech
 +Types:      deb
 +URIs:       https://debian.qelectrotech.org/qet/builds/debian/
 +Suites:     stable
 +Components: main
 +Enabled:    yes
 +Signed-By:  /etc/apt/keyrings/Qelectrotech_Repository.asc
 +==== Debian Sid ====
 +/etc/apt/sources.list.d/qelectrotech.sources
 +Types:      deb
 +Suites:     unstable
 +Components: main
 +Enabled:    yes
 +You should then update your cache: <code>apt-get update</code>
 +==== Step 3: Debian pinning ====
 +qelectrotech:
 +  Installé : 0.100.0.r8447-1
 +  Candidat : 0.100.0.r8447-1
 + Table de version :
 +     1:0.9-3 500
 +        500 http://ftp.fr.debian.org/debian unstable/main amd64 Packages
 +        500 http://deb.debian.org/debian unstable/main amd64 Packages
 + *** 0.100.0.r8447-1 1001
 +        500 https://debian.qelectrotech.org/qet/builds/debian unstable/main amd64 Packages
 +The following entry assigns high priority to all versions of the QElectroTech package whose version number begins with 0.100.:
 +Package: qelectrotech*
 +Pin: version 0.100.1.*
 +Pin-Priority: 1001
 +As root
 +# echo -e 'Package: qelectrotech* \nPin: version 0.100.1.* \nPin-Priority: 1001' > /etc/apt/preferences.d/40qelectrotech-devel
 +With sudo
 +echo -e 'Package: qelectrotech* \nPin: version 0.100.1.* \nPin-Priority: 1001' | sudo tee /etc/apt/preferences.d/40qelectrotech-devel > /dev/null
 +That's it, QElectroTech should now be installed. You can launch it using the "qelectrotech" command. \\
 +Provided your desktop environment complies with FreeDesktop.org standards, \\
 +QET should also appear in its menus, and .qet and .elmt files should open by default in QElectroTech.
 +And old key:
 +=== NO_PUBKEY BC9F825E1D4FB6C1 - Download for Debian Bookworm ===
 +see :https://qelectrotech.org/forum/viewtopic.php?id=2867
