doc:install_debian [09/10/2017 06:50] – [Debian pinning] scorpio810 | doc:install_debian [13/10/2019 21:47] – [Debian pinning] scorpio810 | ||
+ | ===== Installation de la version 0.70 en cours de développement | ||
+ | Ou | ||
+ | [code]wget -q -O - http:// | ||
+ | ==== Debian Stable | ||
+ | Debian 9, nom de code Stretch | ||
+ | ==== Debian Sid ==== | ||
+ | Debian unstable/ | ||
+ | qelectrotech: | ||
+ | Table de version : | ||
+ | 500 [url]http:// | ||
+ | 100 / | ||
+ | L' | ||
+ | laurent@debian: | ||
+ | Pin: version 0.80.* | ||
+ | Pin-Priority: | ||
+ | # echo -e ' | ||
