doc:install_debian [08/03/2016 10:48] – [Ubuntu trusty] scorpio810 | doc:install_debian [25/08/2023 17:19] – [Debian pinning] scorpio810 | ||
+ | Ou | ||
+ | ==== Debian Stable | ||
+ | ==== Debian Sid ==== | ||
+ | Debian unstable/ | ||
+ | qelectrotech: | ||
+ | Table de version : | ||
+ | 500 [url]http:// | ||
+ | 100 / | ||
+ | L' | ||
+ | laurent@debian: | ||
+ | Pin: version 0.100.* | ||
+ | Pin-Priority: | ||
+ | # echo -e ' | ||
+ | Now remove in / | ||
+ | And old key: | ||
