doc:faq [06/04/2010 23:42] – ancienne révision restaurée xavier | doc:faq [21/07/2023 12:24] – download.tuxfamily.org -> download.qelectrotech.org xavier |
| ~~NOCACHE~~ |
| Voir sommaire ci-contre. |
| <code> |
| <?xml version='1.0'?> |
| <fontconfig> |
| <match target="font" > |
| </match> |
| </fontconfig> |
| </code> |
| <code> |
| Xft.lcdfilter: lcddefault |
| Xft.hintstyle: hintslight |
| </code> |
| <code> |
| xrdb -merge ~/.Xresources |
| </code> |
