| 0000045 | QElectroTech | website | public | 2013-01-02 22:32 | 2021-02-15 00:50 |
| Reporter | xavier | Assigned To | xavier | ||
| Priority | normal | Severity | major | Reproducibility | sometimes |
| Platform | X11 | OS | GNU/Linux | OS Version | latest |
| Summary | 0000045: Crash when moving elements through the elements panel | ||||
| Description | [13:51:46] < joshua> découverte d'un bug [13:52:34] < joshua> dans la collection utilisateur j'ai crée un dossier puis dans ce dossier j'ai crée plusieurs element [13:53:25] < joshua> ensuite a l'interieure de ce 1er dossier j'en ai crée un 2eme et deplacé tout les element du 1er dossier dans le 2eme [13:53:53] < joshua> lors que je déplace les élément QET crash et ce ferme [13:54:01] < joshua> sa ne le fait pas a tout les coup [13:54:10] < joshua> le terminal donne sa [13:54:42] < joshua> joshua@debian:~$ qelectrotech [13:54:42] < joshua> transaction began for "common" [13:54:42] < joshua> transaction commited for "common" [13:54:42] < joshua> transaction began for "custom" [13:54:42] < joshua> transaction commited for "custom" [13:54:43] < joshua> transaction began for "common" [13:54:45] < joshua> transaction commited for "common" [13:54:47] < joshua> transaction began for "custom" [13:54:49] < joshua> transaction commited for "custom" [13:54:51] < joshua> transaction began for "common" [13:54:53] < joshua> transaction commited for "common" [13:54:55] < joshua> transaction began for "custom" [13:54:57] < joshua> transaction commited for "custom" [13:54:59] < joshua> transaction began for "common" [13:55:01] < joshua> transaction commited for "common" [13:55:03] < joshua> transaction began for "custom" [13:55:05] < joshua> transaction commited for "custom" [13:55:07] < joshua> QWidget::repaint: Recursive repaint detected [13:55:09] < joshua> Erreur de segmentation [14:21:26] < joshua> petite precision [14:22:10] < joshua> l'erreur ce produit (d'après les test que j'ai fait) uniquement quand on déplace dans un sous dossier [14:22:54] < joshua> la copie dans un dossier superieur ou de même niveau n'a pas l'air de planter | ||||
| Additional Information | Might be due to rev1966 and rev1968 (refresh triggered in a recursive way?) | ||||
| 2013-01-02 22:32 | xavier | New Issue | |
| 2013-01-02 22:32 | xavier | Status | new => assigned |
| 2013-01-02 22:32 | xavier | Assigned To | => xavier |
| 2013-06-09 14:08 | scorpio810_mantis | Category | Éditeur de schémas => Diagram Editor |
| 2016-10-03 15:09 | Morganol | Note Added: 0000168 | |
| 2016-10-03 16:12 | Morganol | Note Added: 0000169 | |
| 2016-10-22 16:14 | scorpio810_mantis | Status | assigned => resolved |
| 2016-10-22 16:14 | scorpio810_mantis | Resolution | open => fixed |
| 2021-02-15 00:45 |
| 2021-02-15 00:50 |
