| 0000044 | QElectroTech | website | public | 2013-01-02 22:28 | 2021-02-15 00:51 |
| Reporter | xavier | Assigned To | xavier | ||
| Status | closed | Resolution | open | ||
| Summary | 0000044: Non-integer coordinates generated when copying and pasting a set of primitives having only integer primitives | ||||
| Description | 21:51 < caligula> Hello Gentlemen 21:52 < caligula> I have a question on the Editeur d'elements 21:52 < caligula> I need to cut and past several elements (quite a bit of repetitive art work to build) and the paste function rarely pastes it on the right spot 21:52 < caligula> i.e. instead of pasting on integer values 21:53 < caligula> (like 90, 100, etc.) it pastes at values like 10.2, 10.95, etc. 21:53 < caligula> which means I have to edit post-pasting EACH element to fix it 21:53 < caligula> which kinda negates the productivity I was getting by pasting in the first place 21:53 < caligula> bug? "feature"? 21:54 < caligula> using 0.30a on W7 (within Parallels on a Mac) 21:54 < caligula> (side note: I am about to go nuts with this behavior) 21:57 < xavier> hello 21:59 < xavier> caligula: which kind of paste do you use? There are several ways to paste stuff 21:59 < caligula> Hello Xavier. So, in the editor, I am using CTRL+C followed by CTRL+V 21:59 < caligula> I tried the CTRL+SHIFT+V, same result 21:59 < caligula> i.e. I can't adjust the box to a fixed integer position either with CTRL+SHIFT+V 22:01 < caligula> hint: I started this component by pasting an auto-generated file from the convert_dxf_elmt.py script (to convert a DXF from the KNX ABB library) 22:01 < caligula> so maybe the underlying component definition is unclean 22:01 < xavier> oh that might be the root cause of your problems 22:01 < caligula> should I first try from a blank sheet before whining here? 22:01 < caligula> k 22:01 < xavier> provided the primitives you copy have a "round" width 22:02 < xavier> they should be copied and pasted to round coordinates 22:02 < xavier> mainly because the default Ctrl+V behaviour is "paste it right next to the copy" 22:02 < caligula> I'll try that. Strange thing is that I created brand new elements within that possibly-corrupted sheet, just lines, and when I copy them, they land on non-integer values 22:02 < xavier> and the "right next" simply means += total_width to x cooridnates 22:02 < xavier> coordinates* 22:03 < caligula> k 22:03 < caligula> let me try something clean then... 22:04 < xavier> But I am glad to see someone confirming that getting floating coordinates when working with primitives is a non-expected behaviour 22:05 < xavier> I am currently working on a "decorator" feature (you know, with clickable little squares to resize primitives, etc.) 22:05 < xavier> and this is among the remaining issues 22:05 < caligula> OK, I see, ok 22:05 < caligula> yes, I could imagine non-integer values once you zoom 22:06 < caligula> or by using a CTRL feature when moving with cursors (a la Visio) 22:06 < caligula> but not as a std behavior in a 1:1 mode 22:07 < xavier> actually, all primitives are snapped to the grid 22:07 < xavier> unless you press Ctrl while moving them 22:09 < caligula> OK, I think I found the "bug" 22:09 < caligula> on a clean sheet, same behavior 22:09 < caligula> once you CTRL+V, it seems to work IF you move it with the mouse 22:10 < caligula> but if you start moving with the keyboard, using the keys on the keyboard (arrows), it starts putting it on non-integer values 22:10 < caligula> let me try on the supposedly corrupted one... 22:11 < caligula> yep, seems to work on that one as well! 22:11 < caligula> => use the mouse, not the keyboard 22:11 < xavier> I'm afraid I either do not understand or do not reproduce that bug 22:11 < caligula> ok, here is what I did in details: 22:11 < xavier> could you send me your guilty elements alongs with the shortest procedure required to reproduce the bug 22:12 < caligula> 1) created a X with two lines 22:12 < caligula> 2) copy with CTRL+C 22:12 < caligula> 3) paste with CTRL+V 22:13 < caligula> 4) without first touching the mouse (!), use the keyboard arrow-keys to try moving it to a different place (like a multiple of 10) 22:13 < caligula> => on the X-axis at least (not sure about the Y-axis), it starts putting it on non-Integer values 22:13 < xavier> I am afraid it is much simpler than that 22:14 < xavier> I guess you can't reproduce it with a bunch of rectangles? 22:14 < caligula> let me try 22:14 < xavier> well perhaps it could still happen with rectangles 22:15 < xavier> My guess is: it is related to the total width of the selected primitives 22:15 < caligula> rectancles seems fine, indeed 22:16 < xavier> I may be able to solve that by reviewing how the target coordinates are determined 22:17 < caligula> first line is: {X1: 9; X2: 14; Y1: 8; Y2: 13; Fin 1: Normale - 1.5; Fin 2: Normale - 1.5} 22:17 < caligula> Second line is identical, just swap X1 and X2 | ||||
| 2013-01-02 22:28 | xavier | New Issue | |
| 2013-01-02 22:28 | xavier | Status | new => assigned |
| 2013-01-02 22:28 | xavier | Assigned To | => xavier |
| 2013-06-09 14:06 | scorpio810_mantis | Category | Éditeur d'éléments => Symbol editor |
| 2013-06-09 14:11 | scorpio810_mantis | Category | Symbol editor => Element Editor |
| 2017-02-11 13:01 | black_sun | Status | assigned => closed |
| 2021-02-15 00:51 |
