0000349QElectroTechElement Editorpublic2026-11-10 16:37
ReporterQET_dude Assigned To
Status newResolutionopen
Platformx86_64OSLinuxOS VersionUbuntu 22.04
Summary0000349: terminals not clickable
DescriptionIf you put several terminals within a distance of 10 from each other in X-direction and in north or south orientation and with shown terminal name, you cant select some terminals afterwards in the drawing.
Workaround is to hide the terminal names and put a textfield with the terminals name to know which is which.
Problem does not occur if you put them with a distance of 10 in y-direction and in west or east orientation.
The attached file shows both cases. The lower terminals have the problem because the terminal names are shown. The above terminals dont have the problem because the terminal names are hidden and the shown terminal names are just text fields.
Additional InformationQElectroTech 0.200.1-dev (Snap, Ubuntu 22.04)
X11
With wayland it never clicks at the current mouse position. therefore I switched to X11
And I use V 0.200.1-dev. I cant upload a file because "invalid version" regardless which version i choose.
TagsNo tags attached.
Activities
There are no notes attached to this issue.
Issue History
2026-11-10 16:36 QET_dude New Issue
