| 0000320 | QElectroTech | Diagram Editor | public | 2025-02-06 13:27 | 2025-02-12 13:50 |
| Reporter | Leonardo da Silva | Assigned To | plc-user | ||
| Summary | 0000320: Spacebar no longer rotates components after update | ||||
| Description | After the latest update, pressing the spacebar no longer rotates components in the editor. This makes the editing process slower and less efficient. Pressing the spacebar should rotate the selected component, as it did before the update. | ||||
| Steps To Reproduce | Open the component editor. Try rotating a component using the spacebar. Nothing happens. | ||||
| Additional Information | QElectroTech V 0.100.0-dev Compilação: GCC 13.3.0 Built with Qt 5.15.16 - x86_64 - Date : Feb 4 2025 : 16:58:28 Run with Qt 5.15.16 using 12 thread(s) CPU : NAME 12TH GEN INTEL(R) CORE(TM) I5-12600 RAM Total : 32 GB RAM Available : 17 GB GPU : VideoProcessor NVIDIA T1000 Intel(R) UHD Graphics Family GPU RAM : RAM Total : AdapterRAM 4293918720 1073741824 B OS : winnt - x86_64 - Version : Windows 11 Version 2009 - Kernel : 10.0.22631 *** Qt screens *** ( 1 : 1920 x 1080 ) ( 2 : 1920 x 1080 ) | ||||
Thanks for report this issue, but I can't reproduce it here! |
I recorded a video showing the error. |
I've just tested the latest Windows installer QET 0.100-dev package on my Windows 10 VM, and everything works as expected. According to what I read in Microsoft IT news there are far too many related bugs these days like process slower and less efficient, high cpu usage, etc. |
I discovered that it only doesn't rotate in the 'Portuguese (Brazil)' language. When I changed the language to 'English' restarted the software, and tried again, it rotated. |
Thanks for pointing that out! Very stange! |
If I switch to Portuguese (Brazil)' language, I can rotate with spacebar key and I have the translation in right click menu... |
I noticed that, too: Language-settings (unfortunately) also affect the keyboard shortcuts, e.g. in the menus. That's why I always leave the keyboard shortcuts untouched in the translations I make! If they are set to the local language, many shortcuts do not work! Like now again “space” = “Leertaste” in German. Unfortunately someone edited German translation for shortcuts, so some do not work since then: Rotating with "Leertaste" is one of them on my Debian-Box! |
Only when setting language in QET to English, rotating with "Leertaste" = "space" works! |
Just created a Pull-Request at github: https://github.com/qelectrotech/qelectrotech-source-mirror/pull/353 |
Binary Packages for various systems are available: https://qelectrotech.org/download.php They work for my German installations. @Leonardo da Silva: Please test with your settings and give feedback here. Thank you for your cooperation! |
Sure, i'll test here. |
Very good, it solved the problem, now its rotating like before. Thank you very much! God bless you! |
Thanks for testing, Leonardo! Bug closed! |
| 2025-02-06 13:27 | Leonardo da Silva | New Issue | |
| 2025-02-06 16:10 | scorpio810_mantis | Note Added: 0000766 | |
| 2025-02-06 17:45 | Leonardo da Silva | Note Added: 0000767 | |
| 2025-02-06 17:45 | Leonardo da Silva | File Added: Spacebar.mp4 | |
| 2025-02-07 12:03 | scorpio810_mantis | Note Added: 0000768 | |
| 2025-02-07 15:05 | Leonardo da Silva | Note Added: 0000769 | |
| 2025-02-07 15:23 | scorpio810_mantis | Note Added: 0000770 | |
| 2025-02-07 15:28 | scorpio810_mantis | Note Added: 0000771 | |
| 2025-02-08 21:28 | plc-user | Note Added: 0000772 | |
| 2025-02-08 21:39 | plc-user | Note Edited: 0000772 | |
| 2025-02-08 21:44 | plc-user | Note Added: 0000773 | |
| 2025-02-11 15:37 | plc-user | Note Added: 0000774 | |
| 2025-02-11 19:21 | plc-user | Assigned To | => plc-user |
| 2025-02-11 19:21 | plc-user | Status | new => assigned |
| 2025-02-11 19:22 | plc-user | Status | assigned => confirmed |
| 2025-02-11 19:27 | plc-user | Note Added: 0000776 | |
| 2025-02-11 19:30 | Leonardo da Silva | Note Added: 0000777 | |
| 2025-02-11 19:35 | Leonardo da Silva | Note Added: 0000779 | |
| 2025-02-12 13:50 | plc-user | Status | confirmed => closed |
| 2025-02-12 13:50 | plc-user | Resolution | open => fixed |
| 2025-02-12 13:50 | plc-user | Note Added: 0000780 |
