0000292QElectroTechDiagram Editorpublic2023-11-05 16:11
ReporterTManiac Assigned To
PrioritynormalSeverityfeatureReproducibilityhave not tried
Summary0000292: Change weighting of second conductor color
DescriptionToday the first and second colors are 50/50 used. But so you can't differentiate between color_a/color_b vs color_b/color_a.
For example a red/black will be shown in the same way like black/red.
It schould be changed, maybe to 66/33 or 75/25.
Additional Informationsources/qetgraphicsitem/conductor.cpp [line 540...]:
if(m_properties.m_bicolor)
  final_conductor_pen.setColor(m_properties.m_color_2);
  final_conductor_pen.setStyle(Qt::CustomDashLine);
  QVector<qreal> dash_pattern;
/** this line seams the way to change it: */
  dash_pattern << m_properties.m_dash_size-2 << m_properties.m_dash_size;
/**   dash_pattern << m_properties.m_dash_size * 2 << m_properties.m_dash_size; */
  final_conductor_pen.setDashPattern(dash_pattern);
  painter->save();
  painter->setPen(final_conductor_pen);
  painter->drawPath(path());
  painter->restore();
TagsNo tags attached.
Activities
scorpio810_mantis
2023-10-24 09:05
administrator   ~0000668
Thank you for feedback.
The problem is that the rendering on the QET program will be different from what you see on the screen and after printing or during PDF export.
Example:
original version
https://download.qelectrotech.org/qet/forum_img_2/weneedpolonez-Polonez_MR89_wiring_diagram.pdf
Patched version:
https://download.qelectrotech.org/qet/forum_img_2/patched_weneedpolonez-Polonez_MR89_wiring_diagram.pdf
You can try yourself this example is provided in QET packages.
TManiac
2023-10-24 17:34
reporter   ~0000669
scorpio, sorry I don't understand where is the "patched" version from?
In the QET examples is the non-patched version.
Here at my station, the diagram view is the same like the PDF export and is the same like the printing. There is no change between first and second color.
scorpio810_mantis
2023-10-24 17:38
administrator   ~0000670
The patched version is with your changes, compile and try the same example on PDF export
-dash_pattern << m_properties.m_dash_size-2 << m_properties.m_dash_size;
+dash_pattern << m_properties.m_dash_size * 2 << m_properties.m_dash_size;
TManiac
2023-10-24 17:44
reporter   ~0000671
Your pdf export is good.
The non-patched export has equal pattern. And the patched export is how it should be: the pattern of bi-color conductors shows a different between first and second color.
Where is the problem?
scorpio810_mantis
2023-10-24 17:47
administrator   ~0000672
Ok, also please make a pull request on our github.
TManiac
2023-10-24 17:49
reporter   ~0000673
Ok, I can't test it in full way.
I haven't QT editor or some thing.
So it will be a untest pull.
I do microcontroller programming :-)
Picture should be to the last comment.
scorpio810_mantis
2023-10-24 17:54
administrator   ~0000674
For me, we need to add a option or checkbox to change the bi-color pattern.
It would be up to the user to activate it on each wire.
This way the old diagrams will not be modified.
scorpio810_mantis
2023-10-24 18:00
administrator   ~0000675
On this example author use 1Px for the primary color and 10PX for second color..
TManiac
2023-10-24 19:06
reporter   ~0000676
You have the checkbox for second color allready in the conductor dialog (green mark).
There is a selection for the conductor width, too. This is placed on the first color section (orange mark).
Then there is a setup for the pattern size (red mark).
But this pattern size is today in all cases with a 50/50 weighting. And so this is more or less useless.
If somebode want to use bicolor wire he will decide between first and second color.
In your example the author uses conductors with 1px width. The 10px on the second color is nice but it doesn't show the difference between first and second. So your patched export is more what it should.
TManiac
2023-10-24 19:10
reporter   ~0000677
This is from my example:
TManiac
2023-10-24 19:17
reporter   ~0000678
Ok, this is why it is better to test. In your patch are first and second color switched.
So the doubling should be to the second dash-size.
dash_pattern << m_properties.m_dash_size << m_properties.m_dash_size * 2;
scorpio810_mantis
2023-10-24 21:04
administrator   ~0000679
ok it makes sense now. ;-)
scorpio810_mantis
2023-11-05 16:10
administrator   ~0000680
Merged,
thanks for report.
Issue History
2023-10-23 19:19 TManiac New Issue
2023-10-23 19:19 TManiac File Added: m_bicolor.png
2023-10-24 09:05 scorpio810_mantis Note Added: 0000668
2023-10-24 17:34 TManiac Note Added: 0000669
2023-10-24 17:38 scorpio810_mantis Note Added: 0000670
2023-10-24 17:44 TManiac Note Added: 0000671
2023-10-24 17:47 scorpio810_mantis Note Added: 0000672
2023-10-24 17:49 TManiac Note Added: 0000673
2023-10-24 17:49 TManiac File Added: Bild_2023-10-24_174923886.png
2023-10-24 17:54 scorpio810_mantis Note Added: 0000674
2023-10-24 18:00 scorpio810_mantis Note Added: 0000675
2023-10-24 19:06 TManiac Note Added: 0000676
2023-10-24 19:06 TManiac File Added: Bild_2023-10-24_190457342.png
2023-10-24 19:10 TManiac Note Added: 0000677
2023-10-24 19:10 TManiac File Added: Bild_2023-10-24_191009191.png
2023-10-24 19:17 TManiac Note Added: 0000678
2023-10-24 19:17 TManiac File Added: Bild_2023-10-24_191706495.png
2023-10-24 21:04 scorpio810_mantis Note Added: 0000679
2023-11-05 16:10 scorpio810_mantis Note Added: 0000680
2023-11-05 16:11 scorpio810_mantis Status new => resolved
2023-11-05 16:11 scorpio810_mantis Resolution open => fixed
