| 0000277 | QElectroTech | Diagram Editor | public | 2022-11-22 10:40 | 2022-11-24 14:04 |
| Reporter | mies-bvd | Assigned To | |||
| Priority | high | Severity | trivial | Reproducibility | always |
| Platform | Windows | OS | Windows 10 | OS Version | 10.0.19041.0 |
| Summary | 0000277: Version 0.9 crashes when saving the project | ||||
| Description | I have been running Qelectrotech 0.8 for a while without issues. Now I would like to move to version 0.9 because of the new features. The problem is that I cannot move to version 0.9 because the bigger projects that I try to save crash on saving. On version 0.8 there is no problem. I have tried multiple builds of 0.9 but that makes no difference. This only happens with bigger projects not small ones. - Smaller than 100 folios it is working - Bigger than 100 folios it is crashing Environment: - OS: Windows 10 - Qelectrotech version: Installer_QElectroTech-0.90-DEV+git7722-1.exe | ||||
| Steps To Reproduce | Steps: 1. Start Qelectrotch 2. Open an existing project 3. Add for example the word "test" somewhere. 4. Click save and it crashes after a couple of seconds. | ||||
| Additional Information | Log dump: 10:34:59.067 Info: Start-up 10:34:59.599 Info: debugging enabled: false 10:34:59.600 Info: Qt library version: 5.15.3 10:34:59.600 Info: Qt library location default prefix: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5" 10:34:59.601 Info: Qt library location documentation: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/doc" 10:34:59.602 Info: Qt library location headers: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/include" 10:34:59.602 Info: Qt library location libraries: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/lib" 10:34:59.603 Info: Qt library location executables: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/bin" 10:34:59.604 Info: Qt library location Qt binaries: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/bin" 10:34:59.604 Info: Qt library location Qt plugins: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/plugins" 10:34:59.605 Info: Qt library location installed QML extensions: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/imports" 10:34:59.606 Info: Qt library location installed QML extensions: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/qml" 10:34:59.606 Info: Qt library location dependent Qt data: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5" 10:34:59.607 Info: Qt library location independent Qt data: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5" 10:34:59.608 Info: Qt library location translation: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/translations" 10:34:59.608 Info: Qt library location examples: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/examples" 10:34:59.609 Info: Qt library location Qt testcases: "/home/laurent/digikam3/project/bundles/mxe/build.win32/usr/i686-w64-mingw32.static/qt5/tests" 10:34:59.609 Info: "QElectroTech V 0.90-DEV+300440454b0a58100c957a06d79751d3" 10:34:59.610 Info: "Compilation: GCC 9.4.0" 10:34:59.611 Info: "Built with Qt 5.15.3 - i386 - Date : Nov 17 2022 : 00:08:32" 10:34:59.611 Info: "Run with Qt 5.15.3 using 8 thread(s)" 10:34:59.612 Info: "CPU : NAME \r\r\nINTEL(R) CORE(TM) I7-3770 CPU @ 3.40GHZ \r\r\n\r\r\n" 10:34:59.612 Info: "RAM Total : 32 GB" 10:34:59.613 Info: "RAM Available : 21 GB" 10:34:59.614 Info: "GPU : VideoProcessor \r\r\nNVIDIA GeForce GTX 1650 \r\r\nIntel(R) HD Graphics Family \r\r\n\r\r\n" 10:34:59.614 Info: "GPU RAM : RAM Total : AdapterRAM \r\r\n4293918720 \r\r\n2181038080 \r\r\n\r\r\n B" 10:34:59.615 Info: "OS : winnt - x86_64 - Version : Windows 10 Version 2009 - Kernel : 10.0.19044" 10:34:59.615 Info: *** Qt screens *** 10:34:59.616 Info: "( 1 : 3840 x 2160 )" 10:34:59.617 Info: "( 2 : 3840 x 2160 )" 10:34:59.641 Info: DISK : C:/ 10:34:59.642 Info: FileSystemType: "NTFS" 10:34:59.643 Info: SizeTotal: 252 GB 10:34:59.643 Info: AvailableSize: 83 GB 10:34:59.644 Info: DISK : D:/ 10:34:59.645 Info: FileSystemType: "NTFS" 10:34:59.645 Info: SizeTotal: 500 GB 10:34:59.646 Info: AvailableSize: 247 GB 10:34:59.647 Info: DISK : M:/ 10:34:59.647 Info: FileSystemType: "NTFS" 10:34:59.648 Info: SizeTotal: 11515 GB 10:34:59.649 Info: AvailableSize: 1778 GB 10:34:59.650 Info: DISK : S:/ 10:34:59.650 Info: FileSystemType: "NTFS" 10:34:59.651 Info: SizeTotal: 11515 GB 10:34:59.651 Info: AvailableSize: 1778 GB 10:34:59.653 Info: DISK USED: D:/ 10:34:59.653 Info: FileSystemType: "NTFS" 10:34:59.654 Info: SizeTotal: 500 GB 10:34:59.655 Info: AvailableSize: 247 GB 10:34:59.709 Info: Elements collection reload 10:35:02.821 Info: Elements collection finished to be loaded in 3.11 seconds 10:35:30.673 Debug: is QRegularExpression ok? (../sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString&)) 10:35:30.675 Debug: is QRegularExpression ok? (../sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString&)) 10:35:31.840 Debug: is QRegularExpression ok? (../sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString&)) 10:35:31.846 Debug: is QRegularExpression ok? (../sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString&)) 10:36:12.881 Warning: libpng warning: iCCP: known incorrect sRGB profile (:0, ) 10:36:13.248 Warning: libpng warning: iCCP: known incorrect sRGB profile (:0, ) 10:36:17.129 Debug: Export XML de 345 schemas (../sources/qetproject.cpp:916, QDomDocument QETProject::toXml()) 10:36:17.130 Debug: "exporting diagram \"Startpagina\"" [ Diagram(0x9fd5fe8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.145 Debug: "exporting diagram \"--- Globale Legenda's ---\"" [ Diagram(0x9fd5da0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.147 Debug: "exporting diagram \"Legenda - Montagedraad Kleuren\"" [ Diagram(0x9fd6b50) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.160 Debug: "exporting diagram \"Legenda - Nummering Componenten\"" [ Diagram(0x9fd6908) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.164 Debug: "exporting diagram \"--- Aanzichttekening ---\"" [ Diagram(0x9fd6d98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.165 Debug: "exporting diagram \"Behuizing - Overzicht\"" [ Diagram(0x9fd6fe0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.172 Debug: "exporting diagram \"Behuizing - Basisplaat Ontwerp\"" [ Diagram(0x9fd7228) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.187 Debug: "exporting diagram \"Behuizing - Basisplaat Naamgeving\"" [ Diagram(0x9fd66c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.201 Debug: "exporting diagram \"Behuizing - Extern\"" [ Diagram(0x9fd76b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.211 Debug: "exporting diagram \"Behuizing - Invoerplaat Globaal\"" [ Diagram(0x9fd7470) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.215 Debug: "exporting diagram \"Behuizing - Invoerplaat B01/L\"" [ Diagram(0x9fd7900) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.219 Debug: "exporting diagram \"Behuizing - Invoerplaat B01/R\"" [ Diagram(0x18b01520) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.224 Debug: "exporting diagram \"Behuizing - Invoerplaat B02/L\"" [ Diagram(0x18b00098) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.229 Debug: "exporting diagram \"Behuizing - Invoerplaat B02/R\"" [ Diagram(0x18b019b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.233 Debug: "exporting diagram \"Behuizing - Materiaal - Bedradingskokers\"" [ Diagram(0x18b00528) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.287 Debug: "exporting diagram \"Behuizing - Materiaal - DIN Rails\"" [ Diagram(0x18b009b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.366 Debug: "exporting diagram \"Behuizing - Specs - Montage Materialen\"" [ Diagram(0x18b01768) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.381 Debug: "exporting diagram \"Behuizing - Verlichting\"" [ Diagram(0x18b00c00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.447 Debug: "exporting diagram \"--- Hoofdstroom (230V) ---\"" [ Diagram(0x18b012d8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.448 Debug: "exporting diagram \"Hoofdstroom (230V) - Legenda\"" [ Diagram(0x18b01bf8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.456 Debug: "exporting diagram \"Hoofdstroom (230V) - Blokschema\"" [ Diagram(0x18b002e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.460 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (1/6)\"" [ Diagram(0x18b00770) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.466 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (2/6)\"" [ Diagram(0x18b01090) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.486 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (3/6)\"" [ Diagram(0x113cc8e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.512 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (4/6)\"" [ Diagram(0x113cc208) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.541 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (5/6)\"" [ Diagram(0x113cb210) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.569 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (6/6)\"" [ Diagram(0x113cb458) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.585 Debug: "exporting diagram \"--- Hoofdstroom (24V) ---\"" [ Diagram(0x113cd200) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.586 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Control\"" [ Diagram(0x113ccd70) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.590 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Peripherals\"" [ Diagram(0x113cbb30) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.597 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Lighting01\"" [ Diagram(0x113cab38) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.602 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Lighting02\"" [ Diagram(0x113cd448) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.607 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Lighting03\"" [ Diagram(0x113cb6a0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.612 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Lighting04\"" [ Diagram(0x113cb8e8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.614 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Control\"" [ Diagram(0x113ca460) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.624 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Peripherals\"" [ Diagram(0x113ccfb8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.631 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Lighting01\"" [ Diagram(0x113ca8f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.644 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Lighting02\"" [ Diagram(0x113cbd78) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.657 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Lighting03\"" [ Diagram(0x113ccb28) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.670 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Lighting04\"" [ Diagram(0x113cafc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.676 Debug: "exporting diagram \"--- Terminal Block ---\"" [ Diagram(0x113cd690) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.677 Debug: "exporting diagram \"Terminal Block - Algemene Legenda\"" [ Diagram(0x113cbfc0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.683 Debug: "exporting diagram \"Terminal Block - X01 - Overzicht\"" [ Diagram(0x113cad80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.747 Debug: "exporting diagram \"Terminal Block - X01 - Deelschema (1/2)\"" [ Diagram(0x113c9fd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.839 Debug: "exporting diagram \"Terminal Block - X01 - Deelschema (2/2)\"" [ Diagram(0x113cdb20) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.934 Debug: "exporting diagram \"Terminal Block - X02 - Overzicht\"" [ Diagram(0x113cc450) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.963 Debug: "exporting diagram \"Terminal Block - X03 - Overzicht\"" [ Diagram(0x113cdd68) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:18.994 Debug: "exporting diagram \"Terminal Block - X04 - Legenda (1/3)\"" [ Diagram(0x113cd8d8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.001 Debug: "exporting diagram \"Terminal Block - X04 - Legenda (2/3)\"" [ Diagram(0x113ca218) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.006 Debug: "exporting diagram \"Terminal Block - X04 - Legenda (3/3)\"" [ Diagram(0x113cc698) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.012 Debug: "exporting diagram \"Terminal Block - X04 - Overzicht (1/2\"" [ Diagram(0x1da35948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.103 Debug: "exporting diagram \"Terminal Block - X04 - Overzicht (2/2)\"" [ Diagram(0x1da34278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.163 Debug: "exporting diagram \"Terminal Block - X05 - Overzicht\"" [ Diagram(0x1da34de0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.181 Debug: "exporting diagram \"Terminal Block - X06 - Overzicht\"" [ Diagram(0x1da35b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.200 Debug: "exporting diagram \"Terminal Block - X51 - Overzicht\"" [ Diagram(0x1da34708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.295 Debug: "exporting diagram \"Terminal Block - X51 - Deelschema (1/2)\"" [ Diagram(0x1da35dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.394 Debug: "exporting diagram \"Terminal Block - X51 - Deelschema (2/2)\"" [ Diagram(0x1da35028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.491 Debug: "exporting diagram \"Terminal Block - X52 - Overzicht\"" [ Diagram(0x1da34b98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.531 Debug: "exporting diagram \"Terminal Block - X53 - Overzicht\"" [ Diagram(0x1da334c8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.573 Debug: "exporting diagram \"Terminal Block - X54 - Overzicht\"" [ Diagram(0x1da36020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.681 Debug: "exporting diagram \"Terminal Block - X55 - Overzicht\"" [ Diagram(0x1da36940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.708 Debug: "exporting diagram \"Terminal Block - X56 - Overzicht\"" [ Diagram(0x1da36268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.725 Debug: "exporting diagram \"Terminal Block - X57 - Overzicht\"" [ Diagram(0x1da33de8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.750 Debug: "exporting diagram \"Terminal Block - X57 - Legenda (1/2)\"" [ Diagram(0x1da36b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.757 Debug: "exporting diagram \"Terminal Block - X57 - Legenda (2/2)\"" [ Diagram(0x1da364b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.760 Debug: "exporting diagram \"Terminal Block - X57 - Deelschema (1/4)\"" [ Diagram(0x1da366f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.817 Debug: "exporting diagram \"Terminal Block - X57 - Deelschema (2/4)\"" [ Diagram(0x1da36dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.873 Debug: "exporting diagram \"Terminal Block - X57 - Deelschema (3/4)\"" [ Diagram(0x1da354b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.929 Debug: "exporting diagram \"Terminal Block - X57 - Deelschema (4/4)\"" [ Diagram(0x1da33038) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.990 Debug: "exporting diagram \"--- Zekering ---\"" [ Diagram(0x1da33280) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:19.991 Debug: "exporting diagram \"Zekering - Legenda\"" [ Diagram(0x1da33958) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.000 Debug: "exporting diagram \"Zekering - F01\"" [ Diagram(0x1da33710) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.029 Debug: "exporting diagram \"Zekering - F02\"" [ Diagram(0x1da33ba0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.099 Debug: "exporting diagram \"Zekering - F03 (1/2)\"" [ Diagram(0x1da34030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.133 Debug: "exporting diagram \"Zekering - F03 (2/2)\"" [ Diagram(0x1da344c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.167 Debug: "exporting diagram \"Zekering - F04 (1/2)\"" [ Diagram(0x1da35270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.200 Debug: "exporting diagram \"Zekering - F04 (2/2)\"" [ Diagram(0x1da34950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.244 Debug: "exporting diagram \"--- Power Supply Unit ---\"" [ Diagram(0x1da35700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.245 Debug: "exporting diagram \"PSU - Principeschema - Control\"" [ Diagram(0x25d0c050) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.250 Debug: "exporting diagram \"PSU - Principeschema - Peripherals\"" [ Diagram(0x25d0c298) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.256 Debug: "exporting diagram \"PSU - Principeschema - Lighting01\"" [ Diagram(0x25d0c970) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.259 Debug: "exporting diagram \"PSU - Principeschema - Lighting02\"" [ Diagram(0x25d0c728) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.263 Debug: "exporting diagram \"PSU - Principeschema - Lighting03\"" [ Diagram(0x25d0cbb8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.266 Debug: "exporting diagram \"PSU - Principeschema - Lighting04\"" [ Diagram(0x25d0be08) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.269 Debug: "exporting diagram \"PSU - Berekening - Control\"" [ Diagram(0x25d0c4e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.275 Debug: "exporting diagram \"PSU - Berekening - Peripherals\"" [ Diagram(0x25d0b2a0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.281 Debug: "exporting diagram \"PSU - Berekening - Lighting01\"" [ Diagram(0x25d0b058) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.285 Debug: "exporting diagram \"PSU - Berekening - Lighting02\"" [ Diagram(0x25d0b4e8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.291 Debug: "exporting diagram \"PSU - Berekening - Lighting03\"" [ Diagram(0x25d0b730) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.294 Debug: "exporting diagram \"PSU - Berekening - Lighting04\"" [ Diagram(0x25d0b978) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.298 Debug: "exporting diagram \"--- Aansluitschema Loxone ---\"" [ Diagram(0x25d0bbc0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.299 Debug: "exporting diagram \"Loxone - Componenten - Legenda\"" [ Diagram(0x20aae298) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.305 Debug: "exporting diagram \"ASS - Loxone Power (1/3)\"" [ Diagram(0x20aae4e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.308 Debug: "exporting diagram \"ASS - Loxone Power (2/3)\"" [ Diagram(0x20aae728) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.315 Debug: "exporting diagram \"ASS - Loxone Power (3/3)\"" [ Diagram(0x20aae970) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.321 Debug: "exporting diagram \"ASS - Loxone Link (1/2)\"" [ Diagram(0x20aaebb8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.329 Debug: "exporting diagram \"ASS - Loxone Link (2/2)\"" [ Diagram(0x20aaee00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.335 Debug: "exporting diagram \"ASS - 100 - Loxone Miniserver v2 (1/5)\"" [ Diagram(0x20aaf048) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.466 Debug: "exporting diagram \"ASS - 100 - Loxone Miniserver v2 - DI (2/5)\"" [ Diagram(0x20aaf968) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.488 Debug: "exporting diagram \"ASS - 100 - Loxone Miniserver v2 - AI (3/5)\"" [ Diagram(0x20aaf290) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.507 Debug: "exporting diagram \"ASS - 100 - Loxone Miniserver v2 - Tree (4/5)\"" [ Diagram(0x20aafbb0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.510 Debug: "exporting diagram \"ASS - 100 - Loxone Miniserver v2 - DO (5/5)\"" [ Diagram(0x20aae050) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.520 Debug: "exporting diagram \"ASS - 101 - Loxone Tree\"" [ Diagram(0x20aaf4d8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.527 Debug: "exporting diagram \"ASS - 102 - Loxone Tree\"" [ Diagram(0x20aaf720) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.537 Debug: "exporting diagram \"ASS - 103 - Loxone Modbus\"" [ Diagram(0x26793700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.556 Debug: "exporting diagram \"ASS - 104 - Loxone DI\"" [ Diagram(0x26795260) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.600 Debug: "exporting diagram \"ASS - 105 - Loxone Air\"" [ Diagram(0x267924c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.628 Debug: "exporting diagram \"ASS - 106 - Loxone Extension - DI (1/4)\"" [ Diagram(0x26794b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.653 Debug: "exporting diagram \"ASS - 106 - Loxone Extension - AI (2/4)\"" [ Diagram(0x267946f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.670 Debug: "exporting diagram \"ASS - 106 - Loxone Extension - AO (3/4)\"" [ Diagram(0x26792278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.687 Debug: "exporting diagram \"ASS - 106 - Loxone Extension - DO (4/4)\"" [ Diagram(0x26794268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.696 Debug: "exporting diagram \"ASS - 107 - Loxone 1-Wire\"" [ Diagram(0x26793028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.705 Debug: "exporting diagram \"ASS - 108 - Loxone Extension - DI (1/4)\"" [ Diagram(0x26795018) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.728 Debug: "exporting diagram \"ASS - 108 - Loxone Extension - AI (2/4)\"" [ Diagram(0x26794dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.744 Debug: "exporting diagram \"ASS - 108 - Loxone Extension - AO (3/4)\"" [ Diagram(0x26792708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.762 Debug: "exporting diagram \"ASS - 108 - Loxone Extension - DO (4/4)\"" [ Diagram(0x26794940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.771 Debug: "exporting diagram \"ASS - 201 - Loxone Tree\"" [ Diagram(0x267954a8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.785 Debug: "exporting diagram \"ASS - 202 - Loxone Dimmer - DI (1/2)\"" [ Diagram(0x267956f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.802 Debug: "exporting diagram \"ASS - 202 - Loxone Dimmer - PWM (2/2)\"" [ Diagram(0x26795938) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.812 Debug: "exporting diagram \"ASS - 203 - Loxone Dimmer - DI (1/2)\"" [ Diagram(0x26792de0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.829 Debug: "exporting diagram \"ASS - 203 - Loxone Dimmer - PWM (2/2)\"" [ Diagram(0x26795b80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.839 Debug: "exporting diagram \"ASS - 204 - Loxone Relay Extension\"" [ Diagram(0x26795dc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.877 Debug: "exporting diagram \"ASS - 205 - Loxone Relay Extension\"" [ Diagram(0x26793270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.901 Debug: "exporting diagram \"ASS - 206 - Loxone Modbus\"" [ Diagram(0x26792030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.911 Debug: "exporting diagram \"--- Aansluitschema Relais ---\"" [ Diagram(0x26794020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.912 Debug: "exporting diagram \"ASS - K01/K04 - Wago 788-304\"" [ Diagram(0x26792950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.925 Debug: "exporting diagram \"ASS - K05/K08 - Wago 788-304\"" [ Diagram(0x26792b98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.937 Debug: "exporting diagram \"ASS - K09/K12 - Wago 788-304\"" [ Diagram(0x267934b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.950 Debug: "exporting diagram \"ASS - K13/K16 - Wago 788-304\"" [ Diagram(0x26793948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.962 Debug: "exporting diagram \"ASS - K17/K20 - Wago 788-304\"" [ Diagram(0x26793b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.975 Debug: "exporting diagram \"ASS - K21/K24 - Wago 788-304\"" [ Diagram(0x26793dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.987 Debug: "exporting diagram \"--- Aansluitschema Tree Intern ---\"" [ Diagram(0x267944b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.989 Debug: "exporting diagram \"Tree Intern - Legenda\"" [ Diagram(0x281f34c8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:20.992 Debug: "exporting diagram \"ASS - 251/252 - Loxone RGBW 24v Dimmer Tree\"" [ Diagram(0x281f2288) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.007 Debug: "exporting diagram \"ASS - 253/254 - Loxone RGBW 24v Dimmer Tree\"" [ Diagram(0x281f3710) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.023 Debug: "exporting diagram \"ASS - 255/256 - Loxone RGBW 24v Dimmer Tree\"" [ Diagram(0x281f5270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.039 Debug: "exporting diagram \"ASS - 257/258 - Loxone RGBW 24v Dimmer Tree\"" [ Diagram(0x281f4de0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.055 Debug: "exporting diagram \"ASS - 259/260 - Loxone RGBW 24v Dimmer Tree\"" [ Diagram(0x281f2040) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.069 Debug: "exporting diagram \"--- Eendraadschema Tree ---\"" [ Diagram(0x281f2718) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.070 Debug: "exporting diagram \"EDS - Tree - Overzicht\"" [ Diagram(0x281f24d0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.072 Debug: "exporting diagram \"EDS - Tree - Legenda\"" [ Diagram(0x281f4030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.080 Debug: "exporting diagram \"EDS - Tree - Symbolen\"" [ Diagram(0x281f5dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.086 Debug: "exporting diagram \"EDS - Tree - Kabel\"" [ Diagram(0x281f4278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.110 Debug: "exporting diagram \"EDS - Tree - Stroomverbruik - Peripheral\"" [ Diagram(0x281f2960) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.115 Debug: "exporting diagram \"EDS - Tree - Stroomverbruik - Lighting\"" [ Diagram(0x281f4b98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.118 Debug: "exporting diagram \"EDS - Tree - 01\"" [ Diagram(0x281f3958) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.125 Debug: "exporting diagram \"EDS - Tree - 02\"" [ Diagram(0x281f2ba8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.127 Debug: "exporting diagram \"EDS - Tree - 03\"" [ Diagram(0x281f5948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.132 Debug: "exporting diagram \"EDS - Tree - 04\"" [ Diagram(0x281f2df0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.135 Debug: "exporting diagram \"EDS - Tree - 05\"" [ Diagram(0x281f4950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.137 Debug: "exporting diagram \"EDS - Tree - 06\"" [ Diagram(0x281f3038) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.143 Debug: "exporting diagram \"EDS - Tree - 07\"" [ Diagram(0x281f3280) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.148 Debug: "exporting diagram \"EDS - Tree - 08\"" [ Diagram(0x281f5700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.152 Debug: "exporting diagram \"EDS - Tree - 09\"" [ Diagram(0x281f3ba0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.155 Debug: "exporting diagram \"EDS - Tree - 10\"" [ Diagram(0x281f5b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.157 Debug: "exporting diagram \"EDS - Tree - 11\"" [ Diagram(0x281f44c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.159 Debug: "exporting diagram \"EDS - Tree - 12\"" [ Diagram(0x281f3de8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.160 Debug: "exporting diagram \"EDS - Tree - 13\"" [ Diagram(0x281f4708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.165 Debug: "exporting diagram \"EDS - Tree - 14\"" [ Diagram(0x281f5028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.167 Debug: "exporting diagram \"EDS - Tree - 15\"" [ Diagram(0x281f54b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.168 Debug: "exporting diagram \"EDS - Tree - 16\"" [ Diagram(0x2904d4c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.172 Debug: "exporting diagram \"EDS - Tree - Internal\"" [ Diagram(0x2904db98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.174 Debug: "exporting diagram \"--- Eendraadschema Air ---\"" [ Diagram(0x2904d708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.176 Debug: "exporting diagram \"EDS - Air - Overzicht\"" [ Diagram(0x2904cde8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.177 Debug: "exporting diagram \"EDS - Air - Legenda\"" [ Diagram(0x2904c4c8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.185 Debug: "exporting diagram \"EDS - Air - Symbolen\"" [ Diagram(0x2904c038) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.192 Debug: "exporting diagram \"EDS - Air - 105\"" [ Diagram(0x2904d030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.211 Debug: "exporting diagram \"--- Kabeldoorvoer ---\"" [ Diagram(0x2904d950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.212 Debug: "exporting diagram \"Kabeldoorvoer - Muur - Kelder/Keuken (1/2)\"" [ Diagram(0x2904d278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.214 Debug: "exporting diagram \"Kabeldoorvoer - Muur - Kelder/Keuken (2/2)\"" [ Diagram(0x2904c280) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.216 Debug: "exporting diagram \"Kabeldoorvoer - Muur - Kelder/Meterkast\"" [ Diagram(0x2904c710) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.217 Debug: "exporting diagram \"Kabeldoorvoer - Muur - Kelder/Tuin\"" [ Diagram(0x2904c958) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.220 Debug: "exporting diagram \"--- Protocol ---\"" [ Diagram(0x2904cba0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.222 Debug: "exporting diagram \"Protocol - 1-Wire\"" [ Diagram(0x294f1bb0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.285 Debug: "exporting diagram \"Protocol - Loxone Air\"" [ Diagram(0x294f14d8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.337 Debug: "exporting diagram \"Protocol - Loxone Link\"" [ Diagram(0x294f1290) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:21.360 Debug: "exporting diagram \"Protocol - Loxone Tree\"" [ Diagram(0x294f1048) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.323 Debug: "exporting diagram \"Protocol - Modbus\"" [ Diagram(0x294f0970) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.392 Debug: "exporting diagram \"--- Decentrale Kasten ---\"" [ Diagram(0x294f0e00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.393 Debug: "exporting diagram \"Decentrale Kasten - Overzicht\"" [ Diagram(0x294f1968) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.398 Debug: "exporting diagram \"B100 - Aansluitschema (1/2)\"" [ Diagram(0x294f0728) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.435 Debug: "exporting diagram \"B100 - Aansluitschema (2/2)\"" [ Diagram(0x294f0298) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.449 Debug: "exporting diagram \"B101 - Aansluitschema Trap\"" [ Diagram(0x294f1720) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.460 Debug: "exporting diagram \"B101 - Aansluitschema WC Ventilatie\"" [ Diagram(0x294f0bb8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.488 Debug: "exporting diagram \"B101 - Terminal Block - X01\"" [ Diagram(0x294f0050) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.529 Debug: "exporting diagram \"B101 - Terminal Block - X02\"" [ Diagram(0x294f04e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.570 Debug: "exporting diagram \"B101 - Terminal Block - X03\"" [ Diagram(0x29bb26f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.594 Debug: "exporting diagram \"B101 - Terminal Block - X04\"" [ Diagram(0x29bb0028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.638 Debug: "exporting diagram \"B102 - Blokschema\"" [ Diagram(0x29bb0700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.642 Debug: "exporting diagram \"B102 - Kabelinvoer Schema\"" [ Diagram(0x29bafb98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.663 Debug: "exporting diagram \"B102 - Terminal Block - X01\"" [ Diagram(0x29baf708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.681 Debug: "exporting diagram \"B102 - Terminal Block - X02\"" [ Diagram(0x29bb1020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.708 Debug: "exporting diagram \"B103 - Blokschema\"" [ Diagram(0x29bb0948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.712 Debug: "exporting diagram \"B103 - Kabelschema\"" [ Diagram(0x29bb2dc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.783 Debug: "exporting diagram \"B103 - X01\"" [ Diagram(0x29bafde0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.843 Debug: "exporting diagram \"B104 - Calculatie\"" [ Diagram(0x29bb16f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.849 Debug: "exporting diagram \"B104 - Blokschema\"" [ Diagram(0x29bb1268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.911 Debug: "exporting diagram \"B104 - Terminal Block - F01\"" [ Diagram(0x29bb1b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.959 Debug: "exporting diagram \"B105 - Aansluitschema\"" [ Diagram(0x29baf278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.963 Debug: "exporting diagram \"B106 - Blokschema\"" [ Diagram(0x29bb1dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:23.965 Debug: "exporting diagram \"B108 - Behuizing\"" [ Diagram(0x29bb2018) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.045 Debug: "exporting diagram \"B108 - Kabelinvoer schema - Voorkant\"" [ Diagram(0x29baf030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.071 Debug: "exporting diagram \"B108 - Kabelinvoer schema - Zijkant\"" [ Diagram(0x29baf950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.096 Debug: "exporting diagram \"B108 - Loxone Multi Extension Air\"" [ Diagram(0x29baf4c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.130 Debug: "exporting diagram \"B108 - Loxone Nano Motor Controller Tree\"" [ Diagram(0x29bb24a8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.160 Debug: "exporting diagram \"B108 - Aansluitschema - Dakraam\"" [ Diagram(0x29bb1940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.192 Debug: "exporting diagram \"B108 - Aansluitschema - Digital Input\"" [ Diagram(0x29bb0270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.193 Debug: "exporting diagram \"B108 - Aansluitschema - Temperatuur\"" [ Diagram(0x29bb2938) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.196 Debug: "exporting diagram \"B108 - Aansluitschema - Verlichting\"" [ Diagram(0x29bb2260) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.239 Debug: "exporting diagram \"B109 - Aansluitschema\"" [ Diagram(0x29bb2b80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.393 Debug: "exporting diagram \"B110 - Aansluitschema\"" [ Diagram(0x29bb04b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.405 Debug: "exporting diagram \"B110 - Uitleg\"" [ Diagram(0x29bb14b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.406 Debug: "exporting diagram \"B111 - Behuizing\"" [ Diagram(0x29bb0b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.421 Debug: "exporting diagram \"B111 - Kabelinvoer schema - Voorkant\"" [ Diagram(0x29bb0dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.425 Debug: "exporting diagram \"B111 - Kabelinvoer schema - Achterkant\"" [ Diagram(0x342644c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.428 Debug: "exporting diagram \"B111 - Terminal Block - X01\"" [ Diagram(0x34267260) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.428 Debug: "exporting diagram \"B111 - Terminal Block - X02\"" [ Diagram(0x34265dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.429 Debug: "exporting diagram \"B111 - Terminal Block - X03\"" [ Diagram(0x342654b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.430 Debug: "exporting diagram \"B111 - Terminal Block - X04\"" [ Diagram(0x34264278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.431 Debug: "exporting diagram \"B113 - Behuizing\"" [ Diagram(0x34265948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.491 Debug: "exporting diagram \"B113 - Kabelinvoer schema\"" [ Diagram(0x342674a8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.517 Debug: "exporting diagram \"B113 - Terminal Block - X01\"" [ Diagram(0x34264708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.550 Debug: "exporting diagram \"B113 - Terminal Block - X02\"" [ Diagram(0x34267dc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.569 Debug: "exporting diagram \"B113 - Terminal Block - X03\"" [ Diagram(0x34266b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.596 Debug: "exporting diagram \"B115 - Behuizing\"" [ Diagram(0x34265700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.660 Debug: "exporting diagram \"B115 - Kabelinvoer Schema - Voorkant\"" [ Diagram(0x34264950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.682 Debug: "exporting diagram \"B115 - Kabelinvoer Schema - Achterkant\"" [ Diagram(0x34264b98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.703 Debug: "exporting diagram \"B115 - K01 - Legenda\"" [ Diagram(0x34264de0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.709 Debug: "exporting diagram \"B115 - K01 - Aansluitschema\"" [ Diagram(0x34264030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.743 Debug: "exporting diagram \"B115 - Terminal Block - X01\"" [ Diagram(0x34267b80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.772 Debug: "exporting diagram \"B115 - Terminal Block - X02\"" [ Diagram(0x34267938) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.807 Debug: "exporting diagram \"B115 - Terminal Block - X03\"" [ Diagram(0x342676f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.829 Debug: "exporting diagram \"B115 - Terminal Block - X04\"" [ Diagram(0x34265028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.864 Debug: "exporting diagram \"B115 - Terminal Block - X05\"" [ Diagram(0x34265b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.878 Debug: "exporting diagram \"B115 - Terminal Block - X06\"" [ Diagram(0x34266020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.897 Debug: "exporting diagram \"B115 - Terminal Block - X21\"" [ Diagram(0x34265270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.910 Debug: "exporting diagram \"B116 - Kabelinvoer schema (1/3)\"" [ Diagram(0x34266268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.944 Debug: "exporting diagram \"B116 - Kabelinvoer schema (2/3)\"" [ Diagram(0x342666f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:24.980 Debug: "exporting diagram \"B116 - Kabelinvoer schema (3/3)\"" [ Diagram(0x34267018) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.007 Debug: "exporting diagram \"B117 - Behuizing\"" [ Diagram(0x342664b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.023 Debug: "exporting diagram \"B117 - Kabelinvoer schema (1/2)\"" [ Diagram(0x34266940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.026 Debug: "exporting diagram \"B117 - Kabelinvoer schema (2/2)\"" [ Diagram(0x34266dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.027 Debug: "exporting diagram \"B117 - Terminal Block - X01\"" [ Diagram(0x34fb6260) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.045 Debug: "exporting diagram \"B117 - Terminal Block - X02\"" [ Diagram(0x34fb66f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.059 Debug: "exporting diagram \"B117 - Terminal Block - X03\"" [ Diagram(0x34fb5940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.075 Debug: "exporting diagram \"B117 - Terminal Block - X04\"" [ Diagram(0x34fb6dc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.095 Debug: "exporting diagram \"B118 - Aansluitschema\"" [ Diagram(0x34fb7930) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.098 Debug: "exporting diagram \"B118 - Behuizing\"" [ Diagram(0x34fb8b70) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.138 Debug: "exporting diagram \"B119 - Behuizing\"" [ Diagram(0x34fb8250) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.250 Debug: "exporting diagram \"B119 - Aansluitschema\"" [ Diagram(0x34fb5b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.278 Debug: "exporting diagram \"B120 - Behuizing - Info\"" [ Diagram(0x34fb86e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.341 Debug: "exporting diagram \"B120 - Behuizing - Indeling\"" [ Diagram(0x34fb7b78) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.386 Debug: "exporting diagram \"B120 - Behuizing - Kabelinvoer\"" [ Diagram(0x34fb6018) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.421 Debug: "exporting diagram \"B120 - Voeding Calculatie\"" [ Diagram(0x34fb74a0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.424 Debug: "exporting diagram \"B120 - Terminal Blocks\"" [ Diagram(0x34fb8928) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.427 Debug: "exporting diagram \"B120 - ASS - Hoofdbekabeling\"" [ Diagram(0x34fb8db8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.455 Debug: "exporting diagram \"B120 - ASS - Intern\"" [ Diagram(0x34fb76e8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.492 Debug: "exporting diagram \"B120 - ASS - Licht helderheid sensor\"" [ Diagram(0x34fb7dc0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.527 Debug: "exporting diagram \"B120 - ASS - Regensensor\"" [ Diagram(0x34fb8008) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.737 Debug: "exporting diagram \"B120 - ASS - Temp & vochtsensor\"" [ Diagram(0x34fb8498) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.832 Debug: "exporting diagram \"RTK - Zolder - Legplan\"" [ Diagram(0x34fb5dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.839 Debug: "exporting diagram \"--- Sensoren & Actuatoren ---\"" [ Diagram(0x34fb64a8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.842 Debug: "exporting diagram \"Actuator - Elektrische Kogelkraan\"" [ Diagram(0x34fb6938) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.888 Debug: "exporting diagram \"Actuator - Jaloezie Blinds Motor (1/4)\"" [ Diagram(0x34fb6b80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:25.992 Debug: "exporting diagram \"Actuator - Jaloezie Blinds Motor (2/4)\"" [ Diagram(0x34fb7010) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:26.064 Debug: "exporting diagram \"Actuator - Jaloezie Blinds Motor (3/4)\"" [ Diagram(0x34fb7258) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:26.351 Debug: "exporting diagram \"Actuator - Jaloezie Blinds Motor (4/4)\"" [ Diagram(0x34fb1960) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:26.447 Debug: "exporting diagram \"Sensor - 1-Wire - DS18B20\"" [ Diagram(0x34fb56f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:26.496 Debug: "exporting diagram \"Sensor - 1-Wire - DS18B20 adapter\"" [ Diagram(0x34fb2710) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:26.556 Debug: "exporting diagram \"Sensor - 1-Wire - DS18B20Z+\"" [ Diagram(0x34fb3030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:26.684 Debug: "exporting diagram \"Sensor - B+B Luchtvochtigheid (1/2)\"" [ Diagram(0x34fb1ba8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:26.802 Debug: "exporting diagram \"Sensor - B+B Luchtvochtigheid (2/2)\"" [ Diagram(0x34fb4dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:26.857 Debug: "exporting diagram \"Sensor - Faradite Motion Sensor\"" [ Diagram(0x34fb5020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:26.944 Debug: "exporting diagram \"Sensor - Firaco Watersensor\"" [ Diagram(0x34fb4028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:26.982 Debug: "exporting diagram \"Sensor - Sensus HRI Pulssensor\"" [ Diagram(0x34fb24c8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.070 Debug: "exporting diagram \"Sensor - VH400 Vegetronix\"" [ Diagram(0x34fb5268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.228 Debug: "exporting diagram \"Sensor/Actuator - Remeha CV Sturing (1/3)\"" [ Diagram(0x34fb2958) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.269 Debug: "exporting diagram \"Sensor/Actuator - Remeha CV Sturing (2/3)\"" [ Diagram(0x34fb4270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.364 Debug: "exporting diagram \"Sensor/Actuator - Remeha CV Sturing (3/3)\"" [ Diagram(0x34fb2ba0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.387 Debug: "exporting diagram \"--- Materiaal ---\"" [ Diagram(0x34fb34c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.388 Debug: "exporting diagram \"Materiaal - ABB Bedieningsvergrendeling\"" [ Diagram(0x34fb2de8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.451 Debug: "exporting diagram \"Materiaal - Cimco Adereindhulzen\"" [ Diagram(0x34fb3de0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.555 Debug: "exporting diagram \"Materiaal - ComPro ROLP\"" [ Diagram(0x34fb3278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.603 Debug: "exporting diagram \"Materiaal - Digitus DIN Rail UTP\"" [ Diagram(0x34fb44b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.617 Debug: "exporting diagram \"Materiaal - Dymo D1 Labels\"" [ Diagram(0x34fb3708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.700 Debug: "exporting diagram \"Materiaal - Eastron Modbus kWh Meter (1/3)\"" [ Diagram(0x34fb4700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.738 Debug: "exporting diagram \"Materiaal - Eastron Modbus kWh Meter (2/3)\"" [ Diagram(0x34fb1df0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.740 Debug: "exporting diagram \"Materiaal - Eastron Modbus kWh Meter (3/3)\"" [ Diagram(0x34fb1718) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.762 Debug: "exporting diagram \"Materiaal - Eaton Automaten\"" [ Diagram(0x34fb2280) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.855 Debug: "exporting diagram \"Materiaal - Eaton Hoofdschakelaar\"" [ Diagram(0x34fb2038) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:27.950 Debug: "exporting diagram \"Materiaal - ESKA Zekeringen\"" [ Diagram(0x34fb1040) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:28.254 Debug: "exporting diagram \"Materiaal - Eupen Montagedraad\"" [ Diagram(0x34fb3950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:28.261 Debug: "exporting diagram \"Materiaal - Finder Interfacerelais - 4C.01\"" [ Diagram(0x34fb3b98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:28.608 Debug: "exporting diagram \"Materiaal - Finder Interfacerelais - 4C.02\"" [ Diagram(0x34fb4948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:28.881 Debug: "exporting diagram \"Materiaal - Finder Toebehoren\"" [ Diagram(0x34fb4b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:28.906 Debug: "exporting diagram \"Materiaal - Markering - Wago (1/3)\"" [ Diagram(0x34fb54b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:29.032 Debug: "exporting diagram \"Materiaal - Markering - Wago (2/3)\"" [ Diagram(0x34fb1288) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:29.039 Debug: "exporting diagram \"Materiaal - Markering - Wago (3/3)\"" [ Diagram(0x34fb14d0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:29.238 Debug: "exporting diagram \"Materiaal - Markering - Weidmüller Dekafix\"" [ Diagram(0x3c395490) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:29.302 Debug: "exporting diagram \"Materiaal - Mean Well SDR Series (1/2)\"" [ Diagram(0x3c3956d8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:29.695 Debug: "exporting diagram \"Materiaal - Mean Well SDR Series (2/2)\"" [ Diagram(0x3c394db8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:29.697 Debug: "exporting diagram \"Materiaal - SEP Kamrail\"" [ Diagram(0x3c394008) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:29.752 Debug: "exporting diagram \"Materiaal - WAGO - 209 Series\"" [ Diagram(0x3c394498) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:29.804 Debug: "exporting diagram \"Materiaal - WAGO - 788 Series\"" [ Diagram(0x3c393dc0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.034 Debug: "exporting diagram \"--- Intercom ---\"" [ Diagram(0x3c393930) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.035 Debug: "exporting diagram \"Intercom - Akuvox - Overzicht\"" [ Diagram(0x3c395920) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.068 Debug: "exporting diagram \"Intercom - Akuvox - Bekabeling\"" [ Diagram(0x3c393b78) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.108 Debug: "exporting diagram \"Intercom - Akuvox - Montage\"" [ Diagram(0x3c394250) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.151 Debug: "exporting diagram \"Intercom - Akuvox - API\"" [ Diagram(0x3c394b70) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.153 Debug: "exporting diagram \"Intercom - Akuvox - Probleem oplossen\"" [ Diagram(0x3c395000) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.165 Debug: "exporting diagram \"--- HMI ---\"" [ Diagram(0x3c3946e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.166 Debug: "exporting diagram \"HMI - Uitleg & Eisen\"" [ Diagram(0x3c3934a0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.167 Debug: "exporting diagram \"HMI - Ontwerp Behuizing\"" [ Diagram(0x3c395b68) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.169 Debug: "exporting diagram \"HMI - Aansluiting - Computer\"" [ Diagram(0x3c394928) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.175 Warning: libpng warning: known incorrect sRGB profile (:0, ) 10:36:30.176 Warning: libpng warning: profile matches sRGB but writing iCCP instead (:0, ) 10:36:30.241 Debug: "exporting diagram \"HMI - Aansluiting - Scherm\"" [ Diagram(0x3c395db0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.313 Debug: "exporting diagram \"HMI - Materiaal - Behuizing\"" [ Diagram(0x3c395248) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.314 Debug: "exporting diagram \"HMI - Materiaal - Computer\"" [ Diagram(0x3c392938) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.335 Debug: "exporting diagram \"HMI - Materiaal - Kabels\"" [ Diagram(0x3c392b80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.336 Debug: "exporting diagram \"HMI - Materiaal - Microfoon\"" [ Diagram(0x3c392dc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.402 Debug: "exporting diagram \"HMI - Materiaal - Scherm\"" [ Diagram(0x3c393010) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.443 Debug: "exporting diagram \"HMI - Materiaal - Speaker\"" [ Diagram(0x3c393258) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.450 Warning: libpng warning: known incorrect sRGB profile (:0, ) 10:36:30.450 Warning: libpng warning: profile matches sRGB but writing iCCP instead (:0, ) 10:36:30.460 Debug: "exporting diagram \"HMI - Materiaal - Voeding\"" [ Diagram(0x3c3936e8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.493 Debug: "exporting diagram \"--- Product ---\"" [ Diagram(0x3c38e710) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.495 Debug: "exporting diagram \"Product - Loxone - Miniserver v2\"" [ Diagram(0x3c391020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.557 Debug: "exporting diagram \"Product - Loxone - 1-Wire\"" [ Diagram(0x3c38ede8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.588 Debug: "exporting diagram \"Product - Loxone - Air\"" [ Diagram(0x3c390b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.649 Debug: "exporting diagram \"Product - Loxone - DI\"" [ Diagram(0x3c38f278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.702 Debug: "exporting diagram \"Product - Loxone - Dimmer\"" [ Diagram(0x3c38f030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.807 Debug: "exporting diagram \"Product - Loxone - Extension\"" [ Diagram(0x3c38e958) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.911 Debug: "exporting diagram \"Product - Loxone - Modbus\"" [ Diagram(0x3c3926f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:30.945 Debug: "exporting diagram \"Product - Loxone - Multi Extension Air\"" [ Diagram(0x3c390270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.165 Debug: "exporting diagram \"Product - Loxone - Relay\"" [ Diagram(0x3c38fde0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.334 Debug: "exporting diagram \"Product - Loxone - Tree\"" [ Diagram(0x3c38f4c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.368 Debug: "exporting diagram \"--- Zelfbouw ---\"" [ Diagram(0x3c38f708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.370 Debug: "exporting diagram \"Badkamer - Spiegel - Berekening\"" [ Diagram(0x3c391940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.372 Debug: "exporting diagram \"Badkamer - Spiegel - Deelschema\"" [ Diagram(0x3c38f950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.402 Debug: "exporting diagram \"--- Problemen ---\"" [ Diagram(0x3c391268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.403 Debug: "exporting diagram \"Problemen - Opstarten Installatie\"" [ Diagram(0x3c38fb98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.414 Debug: "exporting diagram \"Problemen - Afsluiten Installatie\"" [ Diagram(0x3c390028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.422 Debug: "exporting diagram \"Problemen - SD Kaart\"" [ Diagram(0x3c3904b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.423 Debug: "exporting diagram \"Problemen - Led-Status - Miniserver\"" [ Diagram(0x3c390700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.427 Debug: "exporting diagram \"Problemen - Led-Status - Extensions\"" [ Diagram(0x3c391dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.431 Debug: "exporting diagram \"Problemen - Led-Status - Air\"" [ Diagram(0x3c391b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.434 Debug: "exporting diagram \"Problemen - Led-Status - Tree\"" [ Diagram(0x3c390948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:31.439 Debug: "exporting diagram \"Problemen - 1-Wire\"" [ Diagram(0x3c3916f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:36:34.457 Info: Elements collection finished to be loaded 10:38:12.768 Debug: Export XML de 345 schemas (../sources/qetproject.cpp:916, QDomDocument QETProject::toXml()) 10:38:12.769 Debug: "exporting diagram \"Startpagina\"" [ Diagram(0x9fd5fe8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.755 Debug: "exporting diagram \"--- Globale Legenda's ---\"" [ Diagram(0x9fd5da0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.756 Debug: "exporting diagram \"Legenda - Montagedraad Kleuren\"" [ Diagram(0x9fd6b50) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.768 Debug: "exporting diagram \"Legenda - Nummering Componenten\"" [ Diagram(0x9fd6908) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.772 Debug: "exporting diagram \"--- Aanzichttekening ---\"" [ Diagram(0x9fd6d98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.773 Debug: "exporting diagram \"Behuizing - Overzicht\"" [ Diagram(0x9fd6fe0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.779 Debug: "exporting diagram \"Behuizing - Basisplaat Ontwerp\"" [ Diagram(0x9fd7228) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.799 Debug: "exporting diagram \"Behuizing - Basisplaat Naamgeving\"" [ Diagram(0x9fd66c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.813 Debug: "exporting diagram \"Behuizing - Extern\"" [ Diagram(0x9fd76b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.821 Debug: "exporting diagram \"Behuizing - Invoerplaat Globaal\"" [ Diagram(0x9fd7470) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.826 Debug: "exporting diagram \"Behuizing - Invoerplaat B01/L\"" [ Diagram(0x9fd7900) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.830 Debug: "exporting diagram \"Behuizing - Invoerplaat B01/R\"" [ Diagram(0x18b01520) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.834 Debug: "exporting diagram \"Behuizing - Invoerplaat B02/L\"" [ Diagram(0x18b00098) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.838 Debug: "exporting diagram \"Behuizing - Invoerplaat B02/R\"" [ Diagram(0x18b019b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.843 Debug: "exporting diagram \"Behuizing - Materiaal - Bedradingskokers\"" [ Diagram(0x18b00528) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.891 Debug: "exporting diagram \"Behuizing - Materiaal - DIN Rails\"" [ Diagram(0x18b009b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.973 Debug: "exporting diagram \"Behuizing - Specs - Montage Materialen\"" [ Diagram(0x18b01768) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:13.986 Debug: "exporting diagram \"Behuizing - Verlichting\"" [ Diagram(0x18b00c00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.050 Debug: "exporting diagram \"--- Hoofdstroom (230V) ---\"" [ Diagram(0x18b012d8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.052 Debug: "exporting diagram \"Hoofdstroom (230V) - Legenda\"" [ Diagram(0x18b01bf8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.059 Debug: "exporting diagram \"Hoofdstroom (230V) - Blokschema\"" [ Diagram(0x18b002e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.062 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (1/6)\"" [ Diagram(0x18b00770) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.069 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (2/6)\"" [ Diagram(0x18b01090) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.089 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (3/6)\"" [ Diagram(0x113cc8e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.116 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (4/6)\"" [ Diagram(0x113cc208) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.143 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (5/6)\"" [ Diagram(0x113cb210) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.169 Debug: "exporting diagram \"Hoofdstroom (230V) - Deelschema (6/6)\"" [ Diagram(0x113cb458) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.184 Debug: "exporting diagram \"--- Hoofdstroom (24V) ---\"" [ Diagram(0x113cd200) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.185 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Control\"" [ Diagram(0x113ccd70) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.188 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Peripherals\"" [ Diagram(0x113cbb30) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.196 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Lighting01\"" [ Diagram(0x113cab38) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.201 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Lighting02\"" [ Diagram(0x113cd448) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.205 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Lighting03\"" [ Diagram(0x113cb6a0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.211 Debug: "exporting diagram \"Hoofdstroom (24V) - Blokschema - Lighting04\"" [ Diagram(0x113cb8e8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.213 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Control\"" [ Diagram(0x113ca460) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.223 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Peripherals\"" [ Diagram(0x113ccfb8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.232 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Lighting01\"" [ Diagram(0x113ca8f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.245 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Lighting02\"" [ Diagram(0x113cbd78) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.257 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Lighting03\"" [ Diagram(0x113ccb28) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.270 Debug: "exporting diagram \"Hoofdstroom (24V) - Deelschema - Lighting04\"" [ Diagram(0x113cafc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.275 Debug: "exporting diagram \"--- Terminal Block ---\"" [ Diagram(0x113cd690) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.276 Debug: "exporting diagram \"Terminal Block - Algemene Legenda\"" [ Diagram(0x113cbfc0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.282 Debug: "exporting diagram \"Terminal Block - X01 - Overzicht\"" [ Diagram(0x113cad80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.347 Debug: "exporting diagram \"Terminal Block - X01 - Deelschema (1/2)\"" [ Diagram(0x113c9fd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.441 Debug: "exporting diagram \"Terminal Block - X01 - Deelschema (2/2)\"" [ Diagram(0x113cdb20) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.535 Debug: "exporting diagram \"Terminal Block - X02 - Overzicht\"" [ Diagram(0x113cc450) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.565 Debug: "exporting diagram \"Terminal Block - X03 - Overzicht\"" [ Diagram(0x113cdd68) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.596 Debug: "exporting diagram \"Terminal Block - X04 - Legenda (1/3)\"" [ Diagram(0x113cd8d8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.602 Debug: "exporting diagram \"Terminal Block - X04 - Legenda (2/3)\"" [ Diagram(0x113ca218) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.607 Debug: "exporting diagram \"Terminal Block - X04 - Legenda (3/3)\"" [ Diagram(0x113cc698) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.613 Debug: "exporting diagram \"Terminal Block - X04 - Overzicht (1/2\"" [ Diagram(0x1da35948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.705 Debug: "exporting diagram \"Terminal Block - X04 - Overzicht (2/2)\"" [ Diagram(0x1da34278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.765 Debug: "exporting diagram \"Terminal Block - X05 - Overzicht\"" [ Diagram(0x1da34de0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.782 Debug: "exporting diagram \"Terminal Block - X06 - Overzicht\"" [ Diagram(0x1da35b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.800 Debug: "exporting diagram \"Terminal Block - X51 - Overzicht\"" [ Diagram(0x1da34708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.887 Debug: "exporting diagram \"Terminal Block - X51 - Deelschema (1/2)\"" [ Diagram(0x1da35dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:14.994 Debug: "exporting diagram \"Terminal Block - X51 - Deelschema (2/2)\"" [ Diagram(0x1da35028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.102 Debug: "exporting diagram \"Terminal Block - X52 - Overzicht\"" [ Diagram(0x1da34b98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.153 Debug: "exporting diagram \"Terminal Block - X53 - Overzicht\"" [ Diagram(0x1da334c8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.199 Debug: "exporting diagram \"Terminal Block - X54 - Overzicht\"" [ Diagram(0x1da36020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.318 Debug: "exporting diagram \"Terminal Block - X55 - Overzicht\"" [ Diagram(0x1da36940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.370 Debug: "exporting diagram \"Terminal Block - X56 - Overzicht\"" [ Diagram(0x1da36268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.389 Debug: "exporting diagram \"Terminal Block - X57 - Overzicht\"" [ Diagram(0x1da33de8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.437 Debug: "exporting diagram \"Terminal Block - X57 - Legenda (1/2)\"" [ Diagram(0x1da36b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.444 Debug: "exporting diagram \"Terminal Block - X57 - Legenda (2/2)\"" [ Diagram(0x1da364b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.449 Debug: "exporting diagram \"Terminal Block - X57 - Deelschema (1/4)\"" [ Diagram(0x1da366f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.536 Debug: "exporting diagram \"Terminal Block - X57 - Deelschema (2/4)\"" [ Diagram(0x1da36dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.628 Debug: "exporting diagram \"Terminal Block - X57 - Deelschema (3/4)\"" [ Diagram(0x1da354b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.688 Debug: "exporting diagram \"Terminal Block - X57 - Deelschema (4/4)\"" [ Diagram(0x1da33038) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.762 Debug: "exporting diagram \"--- Zekering ---\"" [ Diagram(0x1da33280) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.763 Debug: "exporting diagram \"Zekering - Legenda\"" [ Diagram(0x1da33958) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.773 Debug: "exporting diagram \"Zekering - F01\"" [ Diagram(0x1da33710) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.804 Debug: "exporting diagram \"Zekering - F02\"" [ Diagram(0x1da33ba0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.881 Debug: "exporting diagram \"Zekering - F03 (1/2)\"" [ Diagram(0x1da34030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.918 Debug: "exporting diagram \"Zekering - F03 (2/2)\"" [ Diagram(0x1da344c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.959 Debug: "exporting diagram \"Zekering - F04 (1/2)\"" [ Diagram(0x1da35270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:15.995 Debug: "exporting diagram \"Zekering - F04 (2/2)\"" [ Diagram(0x1da34950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.046 Debug: "exporting diagram \"--- Power Supply Unit ---\"" [ Diagram(0x1da35700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.048 Debug: "exporting diagram \"PSU - Principeschema - Control\"" [ Diagram(0x25d0c050) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.055 Debug: "exporting diagram \"PSU - Principeschema - Peripherals\"" [ Diagram(0x25d0c298) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.060 Debug: "exporting diagram \"PSU - Principeschema - Lighting01\"" [ Diagram(0x25d0c970) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.064 Debug: "exporting diagram \"PSU - Principeschema - Lighting02\"" [ Diagram(0x25d0c728) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.068 Debug: "exporting diagram \"PSU - Principeschema - Lighting03\"" [ Diagram(0x25d0cbb8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.071 Debug: "exporting diagram \"PSU - Principeschema - Lighting04\"" [ Diagram(0x25d0be08) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.075 Debug: "exporting diagram \"PSU - Berekening - Control\"" [ Diagram(0x25d0c4e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.082 Debug: "exporting diagram \"PSU - Berekening - Peripherals\"" [ Diagram(0x25d0b2a0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.087 Debug: "exporting diagram \"PSU - Berekening - Lighting01\"" [ Diagram(0x25d0b058) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.092 Debug: "exporting diagram \"PSU - Berekening - Lighting02\"" [ Diagram(0x25d0b4e8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.096 Debug: "exporting diagram \"PSU - Berekening - Lighting03\"" [ Diagram(0x25d0b730) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.101 Debug: "exporting diagram \"PSU - Berekening - Lighting04\"" [ Diagram(0x25d0b978) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.108 Debug: "exporting diagram \"--- Aansluitschema Loxone ---\"" [ Diagram(0x25d0bbc0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.110 Debug: "exporting diagram \"Loxone - Componenten - Legenda\"" [ Diagram(0x20aae298) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.115 Debug: "exporting diagram \"ASS - Loxone Power (1/3)\"" [ Diagram(0x20aae4e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.119 Debug: "exporting diagram \"ASS - Loxone Power (2/3)\"" [ Diagram(0x20aae728) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.125 Debug: "exporting diagram \"ASS - Loxone Power (3/3)\"" [ Diagram(0x20aae970) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.131 Debug: "exporting diagram \"ASS - Loxone Link (1/2)\"" [ Diagram(0x20aaebb8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.139 Debug: "exporting diagram \"ASS - Loxone Link (2/2)\"" [ Diagram(0x20aaee00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.148 Debug: "exporting diagram \"ASS - 100 - Loxone Miniserver v2 (1/5)\"" [ Diagram(0x20aaf048) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.294 Debug: "exporting diagram \"ASS - 100 - Loxone Miniserver v2 - DI (2/5)\"" [ Diagram(0x20aaf968) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.316 Debug: "exporting diagram \"ASS - 100 - Loxone Miniserver v2 - AI (3/5)\"" [ Diagram(0x20aaf290) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.336 Debug: "exporting diagram \"ASS - 100 - Loxone Miniserver v2 - Tree (4/5)\"" [ Diagram(0x20aafbb0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.341 Debug: "exporting diagram \"ASS - 100 - Loxone Miniserver v2 - DO (5/5)\"" [ Diagram(0x20aae050) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.351 Debug: "exporting diagram \"ASS - 101 - Loxone Tree\"" [ Diagram(0x20aaf4d8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.361 Debug: "exporting diagram \"ASS - 102 - Loxone Tree\"" [ Diagram(0x20aaf720) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.371 Debug: "exporting diagram \"ASS - 103 - Loxone Modbus\"" [ Diagram(0x26793700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.394 Debug: "exporting diagram \"ASS - 104 - Loxone DI\"" [ Diagram(0x26795260) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.466 Debug: "exporting diagram \"ASS - 105 - Loxone Air\"" [ Diagram(0x267924c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.496 Debug: "exporting diagram \"ASS - 106 - Loxone Extension - DI (1/4)\"" [ Diagram(0x26794b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.525 Debug: "exporting diagram \"ASS - 106 - Loxone Extension - AI (2/4)\"" [ Diagram(0x267946f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.544 Debug: "exporting diagram \"ASS - 106 - Loxone Extension - AO (3/4)\"" [ Diagram(0x26792278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.566 Debug: "exporting diagram \"ASS - 106 - Loxone Extension - DO (4/4)\"" [ Diagram(0x26794268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.577 Debug: "exporting diagram \"ASS - 107 - Loxone 1-Wire\"" [ Diagram(0x26793028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.587 Debug: "exporting diagram \"ASS - 108 - Loxone Extension - DI (1/4)\"" [ Diagram(0x26795018) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.614 Debug: "exporting diagram \"ASS - 108 - Loxone Extension - AI (2/4)\"" [ Diagram(0x26794dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.633 Debug: "exporting diagram \"ASS - 108 - Loxone Extension - AO (3/4)\"" [ Diagram(0x26792708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.651 Debug: "exporting diagram \"ASS - 108 - Loxone Extension - DO (4/4)\"" [ Diagram(0x26794940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.663 Debug: "exporting diagram \"ASS - 201 - Loxone Tree\"" [ Diagram(0x267954a8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.678 Debug: "exporting diagram \"ASS - 202 - Loxone Dimmer - DI (1/2)\"" [ Diagram(0x267956f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.695 Debug: "exporting diagram \"ASS - 202 - Loxone Dimmer - PWM (2/2)\"" [ Diagram(0x26795938) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.705 Debug: "exporting diagram \"ASS - 203 - Loxone Dimmer - DI (1/2)\"" [ Diagram(0x26792de0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.723 Debug: "exporting diagram \"ASS - 203 - Loxone Dimmer - PWM (2/2)\"" [ Diagram(0x26795b80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.736 Debug: "exporting diagram \"ASS - 204 - Loxone Relay Extension\"" [ Diagram(0x26795dc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.776 Debug: "exporting diagram \"ASS - 205 - Loxone Relay Extension\"" [ Diagram(0x26793270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.804 Debug: "exporting diagram \"ASS - 206 - Loxone Modbus\"" [ Diagram(0x26792030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.816 Debug: "exporting diagram \"--- Aansluitschema Relais ---\"" [ Diagram(0x26794020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.817 Debug: "exporting diagram \"ASS - K01/K04 - Wago 788-304\"" [ Diagram(0x26792950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.834 Debug: "exporting diagram \"ASS - K05/K08 - Wago 788-304\"" [ Diagram(0x26792b98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.848 Debug: "exporting diagram \"ASS - K09/K12 - Wago 788-304\"" [ Diagram(0x267934b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.863 Debug: "exporting diagram \"ASS - K13/K16 - Wago 788-304\"" [ Diagram(0x26793948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.878 Debug: "exporting diagram \"ASS - K17/K20 - Wago 788-304\"" [ Diagram(0x26793b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.899 Debug: "exporting diagram \"ASS - K21/K24 - Wago 788-304\"" [ Diagram(0x26793dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.917 Debug: "exporting diagram \"--- Aansluitschema Tree Intern ---\"" [ Diagram(0x267944b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.919 Debug: "exporting diagram \"Tree Intern - Legenda\"" [ Diagram(0x281f34c8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.923 Debug: "exporting diagram \"ASS - 251/252 - Loxone RGBW 24v Dimmer Tree\"" [ Diagram(0x281f2288) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.941 Debug: "exporting diagram \"ASS - 253/254 - Loxone RGBW 24v Dimmer Tree\"" [ Diagram(0x281f3710) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.959 Debug: "exporting diagram \"ASS - 255/256 - Loxone RGBW 24v Dimmer Tree\"" [ Diagram(0x281f5270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.977 Debug: "exporting diagram \"ASS - 257/258 - Loxone RGBW 24v Dimmer Tree\"" [ Diagram(0x281f4de0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:16.997 Debug: "exporting diagram \"ASS - 259/260 - Loxone RGBW 24v Dimmer Tree\"" [ Diagram(0x281f2040) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.014 Debug: "exporting diagram \"--- Eendraadschema Tree ---\"" [ Diagram(0x281f2718) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.015 Debug: "exporting diagram \"EDS - Tree - Overzicht\"" [ Diagram(0x281f24d0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.017 Debug: "exporting diagram \"EDS - Tree - Legenda\"" [ Diagram(0x281f4030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.025 Debug: "exporting diagram \"EDS - Tree - Symbolen\"" [ Diagram(0x281f5dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.031 Debug: "exporting diagram \"EDS - Tree - Kabel\"" [ Diagram(0x281f4278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.059 Debug: "exporting diagram \"EDS - Tree - Stroomverbruik - Peripheral\"" [ Diagram(0x281f2960) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.063 Debug: "exporting diagram \"EDS - Tree - Stroomverbruik - Lighting\"" [ Diagram(0x281f4b98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.066 Debug: "exporting diagram \"EDS - Tree - 01\"" [ Diagram(0x281f3958) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.072 Debug: "exporting diagram \"EDS - Tree - 02\"" [ Diagram(0x281f2ba8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.075 Debug: "exporting diagram \"EDS - Tree - 03\"" [ Diagram(0x281f5948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.081 Debug: "exporting diagram \"EDS - Tree - 04\"" [ Diagram(0x281f2df0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.084 Debug: "exporting diagram \"EDS - Tree - 05\"" [ Diagram(0x281f4950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.085 Debug: "exporting diagram \"EDS - Tree - 06\"" [ Diagram(0x281f3038) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.092 Debug: "exporting diagram \"EDS - Tree - 07\"" [ Diagram(0x281f3280) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.097 Debug: "exporting diagram \"EDS - Tree - 08\"" [ Diagram(0x281f5700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.102 Debug: "exporting diagram \"EDS - Tree - 09\"" [ Diagram(0x281f3ba0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.105 Debug: "exporting diagram \"EDS - Tree - 10\"" [ Diagram(0x281f5b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.107 Debug: "exporting diagram \"EDS - Tree - 11\"" [ Diagram(0x281f44c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.111 Debug: "exporting diagram \"EDS - Tree - 12\"" [ Diagram(0x281f3de8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.112 Debug: "exporting diagram \"EDS - Tree - 13\"" [ Diagram(0x281f4708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.117 Debug: "exporting diagram \"EDS - Tree - 14\"" [ Diagram(0x281f5028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.119 Debug: "exporting diagram \"EDS - Tree - 15\"" [ Diagram(0x281f54b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.120 Debug: "exporting diagram \"EDS - Tree - 16\"" [ Diagram(0x2904d4c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.123 Debug: "exporting diagram \"EDS - Tree - Internal\"" [ Diagram(0x2904db98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.126 Debug: "exporting diagram \"--- Eendraadschema Air ---\"" [ Diagram(0x2904d708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.128 Debug: "exporting diagram \"EDS - Air - Overzicht\"" [ Diagram(0x2904cde8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.129 Debug: "exporting diagram \"EDS - Air - Legenda\"" [ Diagram(0x2904c4c8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.140 Debug: "exporting diagram \"EDS - Air - Symbolen\"" [ Diagram(0x2904c038) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.148 Debug: "exporting diagram \"EDS - Air - 105\"" [ Diagram(0x2904d030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.206 Debug: "exporting diagram \"--- Kabeldoorvoer ---\"" [ Diagram(0x2904d950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.211 Debug: "exporting diagram \"Kabeldoorvoer - Muur - Kelder/Keuken (1/2)\"" [ Diagram(0x2904d278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.214 Debug: "exporting diagram \"Kabeldoorvoer - Muur - Kelder/Keuken (2/2)\"" [ Diagram(0x2904c280) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.217 Debug: "exporting diagram \"Kabeldoorvoer - Muur - Kelder/Meterkast\"" [ Diagram(0x2904c710) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.219 Debug: "exporting diagram \"Kabeldoorvoer - Muur - Kelder/Tuin\"" [ Diagram(0x2904c958) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.223 Debug: "exporting diagram \"--- Protocol ---\"" [ Diagram(0x2904cba0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.226 Debug: "exporting diagram \"Protocol - 1-Wire\"" [ Diagram(0x294f1bb0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.332 Debug: "exporting diagram \"Protocol - Loxone Air\"" [ Diagram(0x294f14d8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.397 Debug: "exporting diagram \"Protocol - Loxone Link\"" [ Diagram(0x294f1290) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:17.459 Debug: "exporting diagram \"Protocol - Loxone Tree\"" [ Diagram(0x294f1048) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:19.819 Debug: "exporting diagram \"Protocol - Modbus\"" [ Diagram(0x294f0970) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:19.907 Debug: "exporting diagram \"--- Decentrale Kasten ---\"" [ Diagram(0x294f0e00) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:19.908 Debug: "exporting diagram \"Decentrale Kasten - Overzicht\"" [ Diagram(0x294f1968) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:19.914 Debug: "exporting diagram \"B100 - Aansluitschema (1/2)\"" [ Diagram(0x294f0728) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:19.955 Debug: "exporting diagram \"B100 - Aansluitschema (2/2)\"" [ Diagram(0x294f0298) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:19.972 Debug: "exporting diagram \"B101 - Aansluitschema Trap\"" [ Diagram(0x294f1720) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:19.982 Debug: "exporting diagram \"B101 - Aansluitschema WC Ventilatie\"" [ Diagram(0x294f0bb8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.011 Debug: "exporting diagram \"B101 - Terminal Block - X01\"" [ Diagram(0x294f0050) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.055 Debug: "exporting diagram \"B101 - Terminal Block - X02\"" [ Diagram(0x294f04e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.108 Debug: "exporting diagram \"B101 - Terminal Block - X03\"" [ Diagram(0x29bb26f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.138 Debug: "exporting diagram \"B101 - Terminal Block - X04\"" [ Diagram(0x29bb0028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.186 Debug: "exporting diagram \"B102 - Blokschema\"" [ Diagram(0x29bb0700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.197 Debug: "exporting diagram \"B102 - Kabelinvoer Schema\"" [ Diagram(0x29bafb98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.260 Debug: "exporting diagram \"B102 - Terminal Block - X01\"" [ Diagram(0x29baf708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.282 Debug: "exporting diagram \"B102 - Terminal Block - X02\"" [ Diagram(0x29bb1020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.312 Debug: "exporting diagram \"B103 - Blokschema\"" [ Diagram(0x29bb0948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.316 Debug: "exporting diagram \"B103 - Kabelschema\"" [ Diagram(0x29bb2dc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.388 Debug: "exporting diagram \"B103 - X01\"" [ Diagram(0x29bafde0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.449 Debug: "exporting diagram \"B104 - Calculatie\"" [ Diagram(0x29bb16f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.457 Debug: "exporting diagram \"B104 - Blokschema\"" [ Diagram(0x29bb1268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.519 Debug: "exporting diagram \"B104 - Terminal Block - F01\"" [ Diagram(0x29bb1b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.571 Debug: "exporting diagram \"B105 - Aansluitschema\"" [ Diagram(0x29baf278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.576 Debug: "exporting diagram \"B106 - Blokschema\"" [ Diagram(0x29bb1dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.578 Debug: "exporting diagram \"B108 - Behuizing\"" [ Diagram(0x29bb2018) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.663 Debug: "exporting diagram \"B108 - Kabelinvoer schema - Voorkant\"" [ Diagram(0x29baf030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.692 Debug: "exporting diagram \"B108 - Kabelinvoer schema - Zijkant\"" [ Diagram(0x29baf950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.718 Debug: "exporting diagram \"B108 - Loxone Multi Extension Air\"" [ Diagram(0x29baf4c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.753 Debug: "exporting diagram \"B108 - Loxone Nano Motor Controller Tree\"" [ Diagram(0x29bb24a8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.781 Debug: "exporting diagram \"B108 - Aansluitschema - Dakraam\"" [ Diagram(0x29bb1940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.835 Debug: "exporting diagram \"B108 - Aansluitschema - Digital Input\"" [ Diagram(0x29bb0270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.839 Debug: "exporting diagram \"B108 - Aansluitschema - Temperatuur\"" [ Diagram(0x29bb2938) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.847 Debug: "exporting diagram \"B108 - Aansluitschema - Verlichting\"" [ Diagram(0x29bb2260) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:20.903 Debug: "exporting diagram \"B109 - Aansluitschema\"" [ Diagram(0x29bb2b80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.077 Debug: "exporting diagram \"B110 - Aansluitschema\"" [ Diagram(0x29bb04b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.088 Debug: "exporting diagram \"B110 - Uitleg\"" [ Diagram(0x29bb14b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.089 Debug: "exporting diagram \"B111 - Behuizing\"" [ Diagram(0x29bb0b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.105 Debug: "exporting diagram \"B111 - Kabelinvoer schema - Voorkant\"" [ Diagram(0x29bb0dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.112 Debug: "exporting diagram \"B111 - Kabelinvoer schema - Achterkant\"" [ Diagram(0x342644c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.114 Debug: "exporting diagram \"B111 - Terminal Block - X01\"" [ Diagram(0x34267260) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.115 Debug: "exporting diagram \"B111 - Terminal Block - X02\"" [ Diagram(0x34265dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.116 Debug: "exporting diagram \"B111 - Terminal Block - X03\"" [ Diagram(0x342654b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.117 Debug: "exporting diagram \"B111 - Terminal Block - X04\"" [ Diagram(0x34264278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.117 Debug: "exporting diagram \"B113 - Behuizing\"" [ Diagram(0x34265948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.179 Debug: "exporting diagram \"B113 - Kabelinvoer schema\"" [ Diagram(0x342674a8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.214 Debug: "exporting diagram \"B113 - Terminal Block - X01\"" [ Diagram(0x34264708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.251 Debug: "exporting diagram \"B113 - Terminal Block - X02\"" [ Diagram(0x34267dc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.287 Debug: "exporting diagram \"B113 - Terminal Block - X03\"" [ Diagram(0x34266b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.320 Debug: "exporting diagram \"B115 - Behuizing\"" [ Diagram(0x34265700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.407 Debug: "exporting diagram \"B115 - Kabelinvoer Schema - Voorkant\"" [ Diagram(0x34264950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.440 Debug: "exporting diagram \"B115 - Kabelinvoer Schema - Achterkant\"" [ Diagram(0x34264b98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.477 Debug: "exporting diagram \"B115 - K01 - Legenda\"" [ Diagram(0x34264de0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.487 Debug: "exporting diagram \"B115 - K01 - Aansluitschema\"" [ Diagram(0x34264030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.544 Debug: "exporting diagram \"B115 - Terminal Block - X01\"" [ Diagram(0x34267b80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.592 Debug: "exporting diagram \"B115 - Terminal Block - X02\"" [ Diagram(0x34267938) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.661 Debug: "exporting diagram \"B115 - Terminal Block - X03\"" [ Diagram(0x342676f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.687 Debug: "exporting diagram \"B115 - Terminal Block - X04\"" [ Diagram(0x34265028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.749 Debug: "exporting diagram \"B115 - Terminal Block - X05\"" [ Diagram(0x34265b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.770 Debug: "exporting diagram \"B115 - Terminal Block - X06\"" [ Diagram(0x34266020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.800 Debug: "exporting diagram \"B115 - Terminal Block - X21\"" [ Diagram(0x34265270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.814 Debug: "exporting diagram \"B116 - Kabelinvoer schema (1/3)\"" [ Diagram(0x34266268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.857 Debug: "exporting diagram \"B116 - Kabelinvoer schema (2/3)\"" [ Diagram(0x342666f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.908 Debug: "exporting diagram \"B116 - Kabelinvoer schema (3/3)\"" [ Diagram(0x34267018) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.934 Debug: "exporting diagram \"B117 - Behuizing\"" [ Diagram(0x342664b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.952 Debug: "exporting diagram \"B117 - Kabelinvoer schema (1/2)\"" [ Diagram(0x34266940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.955 Debug: "exporting diagram \"B117 - Kabelinvoer schema (2/2)\"" [ Diagram(0x34266dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.956 Debug: "exporting diagram \"B117 - Terminal Block - X01\"" [ Diagram(0x34fb6260) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.976 Debug: "exporting diagram \"B117 - Terminal Block - X02\"" [ Diagram(0x34fb66f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:21.999 Debug: "exporting diagram \"B117 - Terminal Block - X03\"" [ Diagram(0x34fb5940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.016 Debug: "exporting diagram \"B117 - Terminal Block - X04\"" [ Diagram(0x34fb6dc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.043 Debug: "exporting diagram \"B118 - Aansluitschema\"" [ Diagram(0x34fb7930) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.049 Debug: "exporting diagram \"B118 - Behuizing\"" [ Diagram(0x34fb8b70) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.131 Debug: "exporting diagram \"B119 - Behuizing\"" [ Diagram(0x34fb8250) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.259 Debug: "exporting diagram \"B119 - Aansluitschema\"" [ Diagram(0x34fb5b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.284 Debug: "exporting diagram \"B120 - Behuizing - Info\"" [ Diagram(0x34fb86e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.359 Debug: "exporting diagram \"B120 - Behuizing - Indeling\"" [ Diagram(0x34fb7b78) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.419 Debug: "exporting diagram \"B120 - Behuizing - Kabelinvoer\"" [ Diagram(0x34fb6018) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.463 Debug: "exporting diagram \"B120 - Voeding Calculatie\"" [ Diagram(0x34fb74a0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.468 Debug: "exporting diagram \"B120 - Terminal Blocks\"" [ Diagram(0x34fb8928) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.471 Debug: "exporting diagram \"B120 - ASS - Hoofdbekabeling\"" [ Diagram(0x34fb8db8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.503 Debug: "exporting diagram \"B120 - ASS - Intern\"" [ Diagram(0x34fb76e8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.543 Debug: "exporting diagram \"B120 - ASS - Licht helderheid sensor\"" [ Diagram(0x34fb7dc0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.589 Debug: "exporting diagram \"B120 - ASS - Regensensor\"" [ Diagram(0x34fb8008) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.840 Debug: "exporting diagram \"B120 - ASS - Temp & vochtsensor\"" [ Diagram(0x34fb8498) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.945 Debug: "exporting diagram \"RTK - Zolder - Legplan\"" [ Diagram(0x34fb5dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.949 Debug: "exporting diagram \"--- Sensoren & Actuatoren ---\"" [ Diagram(0x34fb64a8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.950 Debug: "exporting diagram \"Actuator - Elektrische Kogelkraan\"" [ Diagram(0x34fb6938) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:22.999 Debug: "exporting diagram \"Actuator - Jaloezie Blinds Motor (1/4)\"" [ Diagram(0x34fb6b80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:23.119 Debug: "exporting diagram \"Actuator - Jaloezie Blinds Motor (2/4)\"" [ Diagram(0x34fb7010) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:23.202 Debug: "exporting diagram \"Actuator - Jaloezie Blinds Motor (3/4)\"" [ Diagram(0x34fb7258) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:23.511 Debug: "exporting diagram \"Actuator - Jaloezie Blinds Motor (4/4)\"" [ Diagram(0x34fb1960) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:23.627 Debug: "exporting diagram \"Sensor - 1-Wire - DS18B20\"" [ Diagram(0x34fb56f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:23.682 Debug: "exporting diagram \"Sensor - 1-Wire - DS18B20 adapter\"" [ Diagram(0x34fb2710) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:23.750 Debug: "exporting diagram \"Sensor - 1-Wire - DS18B20Z+\"" [ Diagram(0x34fb3030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:23.887 Debug: "exporting diagram \"Sensor - B+B Luchtvochtigheid (1/2)\"" [ Diagram(0x34fb1ba8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.013 Debug: "exporting diagram \"Sensor - B+B Luchtvochtigheid (2/2)\"" [ Diagram(0x34fb4dd8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.066 Debug: "exporting diagram \"Sensor - Faradite Motion Sensor\"" [ Diagram(0x34fb5020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.165 Debug: "exporting diagram \"Sensor - Firaco Watersensor\"" [ Diagram(0x34fb4028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.203 Debug: "exporting diagram \"Sensor - Sensus HRI Pulssensor\"" [ Diagram(0x34fb24c8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.295 Debug: "exporting diagram \"Sensor - VH400 Vegetronix\"" [ Diagram(0x34fb5268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.460 Debug: "exporting diagram \"Sensor/Actuator - Remeha CV Sturing (1/3)\"" [ Diagram(0x34fb2958) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.505 Debug: "exporting diagram \"Sensor/Actuator - Remeha CV Sturing (2/3)\"" [ Diagram(0x34fb4270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.588 Debug: "exporting diagram \"Sensor/Actuator - Remeha CV Sturing (3/3)\"" [ Diagram(0x34fb2ba0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.613 Debug: "exporting diagram \"--- Materiaal ---\"" [ Diagram(0x34fb34c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.615 Debug: "exporting diagram \"Materiaal - ABB Bedieningsvergrendeling\"" [ Diagram(0x34fb2de8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.682 Debug: "exporting diagram \"Materiaal - Cimco Adereindhulzen\"" [ Diagram(0x34fb3de0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.793 Debug: "exporting diagram \"Materiaal - ComPro ROLP\"" [ Diagram(0x34fb3278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.842 Debug: "exporting diagram \"Materiaal - Digitus DIN Rail UTP\"" [ Diagram(0x34fb44b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.857 Debug: "exporting diagram \"Materiaal - Dymo D1 Labels\"" [ Diagram(0x34fb3708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.937 Debug: "exporting diagram \"Materiaal - Eastron Modbus kWh Meter (1/3)\"" [ Diagram(0x34fb4700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.977 Debug: "exporting diagram \"Materiaal - Eastron Modbus kWh Meter (2/3)\"" [ Diagram(0x34fb1df0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:24.979 Debug: "exporting diagram \"Materiaal - Eastron Modbus kWh Meter (3/3)\"" [ Diagram(0x34fb1718) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:25.000 Debug: "exporting diagram \"Materiaal - Eaton Automaten\"" [ Diagram(0x34fb2280) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:25.092 Debug: "exporting diagram \"Materiaal - Eaton Hoofdschakelaar\"" [ Diagram(0x34fb2038) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:25.187 Debug: "exporting diagram \"Materiaal - ESKA Zekeringen\"" [ Diagram(0x34fb1040) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:25.480 Debug: "exporting diagram \"Materiaal - Eupen Montagedraad\"" [ Diagram(0x34fb3950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:25.487 Debug: "exporting diagram \"Materiaal - Finder Interfacerelais - 4C.01\"" [ Diagram(0x34fb3b98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:25.831 Debug: "exporting diagram \"Materiaal - Finder Interfacerelais - 4C.02\"" [ Diagram(0x34fb4948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:26.100 Debug: "exporting diagram \"Materiaal - Finder Toebehoren\"" [ Diagram(0x34fb4b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:26.123 Debug: "exporting diagram \"Materiaal - Markering - Wago (1/3)\"" [ Diagram(0x34fb54b0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:26.293 Debug: "exporting diagram \"Materiaal - Markering - Wago (2/3)\"" [ Diagram(0x34fb1288) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:26.305 Debug: "exporting diagram \"Materiaal - Markering - Wago (3/3)\"" [ Diagram(0x34fb14d0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:26.516 Debug: "exporting diagram \"Materiaal - Markering - Weidmüller Dekafix\"" [ Diagram(0x3c395490) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:26.583 Debug: "exporting diagram \"Materiaal - Mean Well SDR Series (1/2)\"" [ Diagram(0x3c3956d8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.015 Debug: "exporting diagram \"Materiaal - Mean Well SDR Series (2/2)\"" [ Diagram(0x3c394db8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.016 Debug: "exporting diagram \"Materiaal - SEP Kamrail\"" [ Diagram(0x3c394008) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.076 Debug: "exporting diagram \"Materiaal - WAGO - 209 Series\"" [ Diagram(0x3c394498) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.134 Debug: "exporting diagram \"Materiaal - WAGO - 788 Series\"" [ Diagram(0x3c393dc0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.381 Debug: "exporting diagram \"--- Intercom ---\"" [ Diagram(0x3c393930) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.382 Debug: "exporting diagram \"Intercom - Akuvox - Overzicht\"" [ Diagram(0x3c395920) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.412 Debug: "exporting diagram \"Intercom - Akuvox - Bekabeling\"" [ Diagram(0x3c393b78) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.452 Debug: "exporting diagram \"Intercom - Akuvox - Montage\"" [ Diagram(0x3c394250) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.494 Debug: "exporting diagram \"Intercom - Akuvox - API\"" [ Diagram(0x3c394b70) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.496 Debug: "exporting diagram \"Intercom - Akuvox - Probleem oplossen\"" [ Diagram(0x3c395000) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.509 Debug: "exporting diagram \"--- HMI ---\"" [ Diagram(0x3c3946e0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.511 Debug: "exporting diagram \"HMI - Uitleg & Eisen\"" [ Diagram(0x3c3934a0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.512 Debug: "exporting diagram \"HMI - Ontwerp Behuizing\"" [ Diagram(0x3c395b68) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.514 Debug: "exporting diagram \"HMI - Aansluiting - Computer\"" [ Diagram(0x3c394928) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.520 Warning: libpng warning: known incorrect sRGB profile (:0, ) 10:38:27.521 Warning: libpng warning: profile matches sRGB but writing iCCP instead (:0, ) 10:38:27.585 Debug: "exporting diagram \"HMI - Aansluiting - Scherm\"" [ Diagram(0x3c395db0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.658 Debug: "exporting diagram \"HMI - Materiaal - Behuizing\"" [ Diagram(0x3c395248) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.659 Debug: "exporting diagram \"HMI - Materiaal - Computer\"" [ Diagram(0x3c392938) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.679 Debug: "exporting diagram \"HMI - Materiaal - Kabels\"" [ Diagram(0x3c392b80) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.680 Debug: "exporting diagram \"HMI - Materiaal - Microfoon\"" [ Diagram(0x3c392dc8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.746 Debug: "exporting diagram \"HMI - Materiaal - Scherm\"" [ Diagram(0x3c393010) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.790 Debug: "exporting diagram \"HMI - Materiaal - Speaker\"" [ Diagram(0x3c393258) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.797 Warning: libpng warning: known incorrect sRGB profile (:0, ) 10:38:27.798 Warning: libpng warning: profile matches sRGB but writing iCCP instead (:0, ) 10:38:27.809 Debug: "exporting diagram \"HMI - Materiaal - Voeding\"" [ Diagram(0x3c3936e8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.840 Debug: "exporting diagram \"--- Product ---\"" [ Diagram(0x3c38e710) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.841 Debug: "exporting diagram \"Product - Loxone - Miniserver v2\"" [ Diagram(0x3c391020) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.904 Debug: "exporting diagram \"Product - Loxone - 1-Wire\"" [ Diagram(0x3c38ede8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.934 Debug: "exporting diagram \"Product - Loxone - Air\"" [ Diagram(0x3c390b90) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:27.994 Debug: "exporting diagram \"Product - Loxone - DI\"" [ Diagram(0x3c38f278) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.048 Debug: "exporting diagram \"Product - Loxone - Dimmer\"" [ Diagram(0x3c38f030) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.149 Debug: "exporting diagram \"Product - Loxone - Extension\"" [ Diagram(0x3c38e958) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.262 Debug: "exporting diagram \"Product - Loxone - Modbus\"" [ Diagram(0x3c3926f0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.294 Debug: "exporting diagram \"Product - Loxone - Multi Extension Air\"" [ Diagram(0x3c390270) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.511 Debug: "exporting diagram \"Product - Loxone - Relay\"" [ Diagram(0x3c38fde0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.676 Debug: "exporting diagram \"Product - Loxone - Tree\"" [ Diagram(0x3c38f4c0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.703 Debug: "exporting diagram \"--- Zelfbouw ---\"" [ Diagram(0x3c38f708) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.704 Debug: "exporting diagram \"Badkamer - Spiegel - Berekening\"" [ Diagram(0x3c391940) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.706 Debug: "exporting diagram \"Badkamer - Spiegel - Deelschema\"" [ Diagram(0x3c38f950) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.733 Debug: "exporting diagram \"--- Problemen ---\"" [ Diagram(0x3c391268) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.734 Debug: "exporting diagram \"Problemen - Opstarten Installatie\"" [ Diagram(0x3c38fb98) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.743 Debug: "exporting diagram \"Problemen - Afsluiten Installatie\"" [ Diagram(0x3c390028) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.752 Debug: "exporting diagram \"Problemen - SD Kaart\"" [ Diagram(0x3c3904b8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.754 Debug: "exporting diagram \"Problemen - Led-Status - Miniserver\"" [ Diagram(0x3c390700) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.757 Debug: "exporting diagram \"Problemen - Led-Status - Extensions\"" [ Diagram(0x3c391dd0) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.761 Debug: "exporting diagram \"Problemen - Led-Status - Air\"" [ Diagram(0x3c391b88) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.764 Debug: "exporting diagram \"Problemen - Led-Status - Tree\"" [ Diagram(0x3c390948) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) 10:38:28.768 Debug: "exporting diagram \"Problemen - 1-Wire\"" [ Diagram(0x3c3916f8) ] (../sources/qetproject.cpp:921, QDomDocument QETProject::toXml()) That was the last entry and it is gone! | ||||
You could share your project? |
I am afraid not because of customer data... Any clue what the issue might be based on the log file? |
Maybe in private to joshua and me ? scorpio@qelectrotech.org joshua@qelectrotech.org |
Just tried on old project with 111 folios work and save well. |
See mail in mailbox :) |
Please try with 64 bits installer 0.9-dev version. 32 bits version is only for very very old setup and little project. I'm thinking of abandoning 32-bit builds soon |
Fixed! The issue was caused by the 32-bit build, thanks for the help! The issue is resolved. |
| 2022-11-22 10:40 | mies-bvd | New Issue | |
| 2022-11-22 16:30 | scorpio810_mantis | Note Added: 0000592 | |
| 2022-11-22 22:17 | mies-bvd | Note Added: 0000594 | |
| 2022-11-23 10:07 | scorpio810_mantis | Note Added: 0000595 | |
| 2022-11-23 12:32 | scorpio810_mantis | Note Added: 0000597 | |
| 2022-11-23 12:32 | scorpio810_mantis | File Added: test.zip | |
| 2022-11-23 12:34 | scorpio810_mantis | Note Added: 0000598 | |
| 2022-11-23 12:35 | mies-bvd | Note Added: 0000599 | |
| 2022-11-23 16:45 | scorpio810_mantis | Note Added: 0000600 | |
| 2022-11-23 19:30 | mies-bvd | Note Added: 0000601 | |
| 2022-11-24 14:04 | scorpio810_mantis | Status | new => resolved |
| 2022-11-24 14:04 | scorpio810_mantis | Resolution | open => fixed |
